    Medeek Wall Plugin
    1.5k Posts 29 Posters 1.3m Views 28 Watching
      Charlie__V
      Nathaniel,
      I had some time today to try your wall plug-in.
      It appears to install just fine,(as admin/restart SU) but I have been unable to get it to function.
      All of the menus appear, and when I select the draw wall icon.....set wall parameters....click OK......attempt to draw wall....nothing happens....no indication from cursor....no snap point highlight or wireframe of wall appear.
      Perhaps this is a MS Windows 7 Pro limitation and/or an IE V11 thing? (see my machine spec's in sig.)
      Sorry to trouble you with this as I know you are incredibly busy......but figured if this is an MS/OS limitation maybe it should be posted here. (or further a compatibility note on download page)
      Thanks for your time.
      Edit:
      I have what I believe is the latest version. (June 6th)
      & License type is TRIAL and the text is green.
      Charlie
      • medeekM Offline
        medeek
        @charlie__v said:
        Nathaniel,
        Edit:
        Charlie
        Let me guess, the advanced wall options are turned off?
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          Charlie__V
          Advanced wall options are set to YES (in wall parameters window & global settings)
          C
          • medeekM Offline
            medeek
            C
            Open the Ruby Console, then duplicate the error and send me the error code nathan@medeek.com
            I made a number of improvements yesterday and I may have inadvertently broke the plugin with the latest release (0.7.6e).
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.7.6f - 06.07.2018
              • Added the ability to lock the cursor to the X or Y axis for the "Draw Wall Tool" (line and polyline) by pressing the SHIFT key.
              • Added the ability to lock the cursor to the 45 deg. and 135 deg. axis for the "Draw Wall Tool" (line and polyline) by pressing the CTRL key.
              Also note that I fixed a couple of bugs I accidentally created when making the code adjustments for version 0.7.6e, I managed to break the plugin for all TRIAL users.
              Therefore this is a critical update, please remove the prior version and install this version which will fix the error introduced last night. This is what happens when I try to get too much done in one day.
              Click on the image to view animation:
              design.medeek.com
                alpro
                Any chance to be able to add our own textures to the walls ? Would it be possible to just have a library that we could add too......would like to see that also in the roof textures with the truss tool.
                • medeekM Offline
                  medeek
                  When you say walls, are you talking about texturing the framing, cladding, sheathing or gypsum?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 0.7.7 - 06.08.2018
                    • Created the Medeek Wall Plugin LT, a lighter version of the plugin with internal wall framing, estimating and engineering removed.
                    • Horizontal and Vertical OSB sheathing materials added to the pre-installed plugin materials.
                    http://design.medeek.com/resources/images/wall_su97_800.jpg
                    Note that the June promo does not apply to the LT version of the plugin
                    design.medeek.com
                      alpro
                      As far as texturing I'm talking about cladding and gypsum so that I can show client specified materials and that I don't lose those materials when a client makes changes and the walls need rebuilt.
                        alpro
                        So finally had some time to really try this out and have run into 3 issues,
                        1)My global settings don't stick
                        2)No matter what settings I use or which direction that I draw the wall in the cladding always is inside.
                        3)Would be nice if last settings were remembered when drawing a new wall
                        • medeekM Offline
                          medeek
                          What version are you using?
                          Also only use the FRONT justification, the other two are currently flawed and I am working on them.
                          I will need more details on which global settings are taking and also your operating system.
                          The previous settings should be recalled when starting a new wall, however this issue was only recently addressed in 0.7.6f, be sure to install the latest version.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            I've been getting a lot of feedback on the UI lately, for good reason of course (it's terrible).
                            The wall draw tool with its multiple menus is what I am talking about.
                            After reviewing various suggestions and giving it some more thought I think the solution is two fold:
                            1.) Go to an HTML menu, similar in design to the current edit menu that remains open during wall creation and allows the user to make changes during wall creation with the polyline tool (ie. changing wall height on specific wall segments that are in a drop down living room).
                            2.) Enabling user presets where all of the basic and advanced parameters for a wall are saved to a user defined preset that can be instantly recalled within both the wall draw and edit menus. For example, this would allow the user to quickly define and then recall a 2x6 ext. wall with a 1" air gap and brick cladding, rather than having to peruse through all of the settings every time and recreating the wheel just to put together a standard wall type.
                            Certain parameters would not be saved as part of a wall preset. I haven't nailed down exactly which of those parameter to exclude but my first shot at it would be:
                            • Wall Length
                            • Wall Group
                            • Wall Framing (2D, 3D etc...)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I also really like the idea of having a user material library where you can just dump your pre-configured SKM files and the plugin then has the ability to pick and choose from these materials.
                              design.medeek.com
                                alpro
                                Ok nevermind on #1, didn't realize that I had to "save settings" on each page of the global settings, thought I could make all my changes and save settings just once.
                                  alpro
                                  Had an error running 2 45° bays, totally reproducible, happens every time.
                                  • medeekM Offline
                                    medeek
                                    Can you send me your model or at least the wall panel in question and the walls adjacent to this panel. I need to examine this further, and review my stud spacing algorithm especially how it is handling non-orthogonal walls.
                                    My email is nathan@medeek.com
                                    Don't erase this wall panel from your model, once I address the bug you can simply rebuild the wall with the updated plugin and will be resolved.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Does anyone have a good Tyvek house wrap material or texture that I can incorporate into the plugin?
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.7.7b - 06.09.2018
                                        • Horizontal and Vertical plywood sheathing materials added to the pre-installed plugin materials.
                                        http://design.medeek.com/resources/images/wall_su98_800.jpg
                                        http://design.medeek.com/resources/images/wall_su99_800.jpg
                                        I realize this a fairly insignificant item, but it was user requested and one of those things I could knock out in about 10 minutes or less.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I'm actually not a big fan of Tyvek, at least not in our marine environment on the beach out here in western Washington but I do know it gets used a lot. This is the OSB + TYVEK option:
                                          http://design.medeek.com/resources/images/wall_su100_800.jpg
                                          Only the outside face of the sheathing gets the Tyvek material and the sheathing group gets the generic OSB material.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            The updated main toolbar:
                                            http://design.medeek.com/resources/images/wall_su_menu_active.jpg
                                            I'm adding one extra icon for estimating, this will allow the user to create a bill of materials for one or more (multiple) wall panels.
                                            At this point I am not interested in developing a sophisticated estimating program with the ability to associate costs to various materials etc... Basically I just want the estimating feature to be able to spit out a CSV file with a comprehensive parts list that can then be dropped into any spreadsheet software (ie. Excel) and the user can take it from there.
                                            As an engineer I use Excel for a number of things including very complicated calculators. Spreadsheets are pretty much the bread and butter of any design professional, or someone working in the construction industry. With that being said a CSV file makes the most sense to me.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 77
                                            • 78
                                            • 13 / 78
