    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Just had an interesting conversation with a professional estimator about the plugin this morning.
      He reinforced what already I'm seeing with this plugin and how it relates to design, designers and architects.
      As I've mentioned previously the plugin audience is three fold and the design side probably will utilize the 2D and 3D (no framing) mode the most. The reason being is that most designers are not overly interested in how the structure goes together, their main concern is the layout and placement of windows and doors.
      The full framing mode will have more utility among the engineers, panel designers, estimators, contractors and DIYers.
      A building design is really no more than a concept and it takes a whole team of professionals to take something off of paper (or pdf) and make it into a physical reality.
      Once I have the design side of this software put together and reasonably solid I will begin focusing on the engineering and estimating pieces.
      This estimator talked at length about the disconnect between himself and the architects. My goal is to help heal this disconnect and get everyone on the same page, I think we can do this.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 0.7.6b - 06.05.2018
        • Auto-Corner Configuration algorithm revised to handle "stepped" walls.
        • Wall "Draw Tool" configured to retain most recent inputs from user. Parameters not shown in UI default to global settings.
        This sub. revision is actually fairly significant and worth upgrading to since it addresses a major flaw in the UI.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 0.7.6c - 06.05.2018
          • Added the option to toggle between standard stud sizes and custom (user defined width x depth) sizes with the "Walls" tab of the global settings.
          http://design.medeek.com/resources/images/wall_su95_800.jpg
          Note that within the wall edit menu the stud width and depth can be adjusted independently regardless of the standard stud size option being enabled.
          design.medeek.com
          • medeekM Offline
            medeek
            Updated the vendor page to reflect all of the products listed within the plugin:
            Medeek Design Inc. - Medeek Wall Plugin Vendors
            (design.medeek.com)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.7.6d - 06.05.2018
              • Fixed a bug with the wall sheathing and cladding so that door openings are properly cut out even when the vertical offset parameter is negative.
              http://design.medeek.com/resources/images/wall_su96_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                This morning I am spending a little extra time on the auto-corner config module and the related module that checks for tee intersections. It has been brought to my attention that this area of the plugin is not as robust as it needs to be. I've already made a number of minor corrections and augmentations but if anyone has a particular case that is throwing an error or unexpected result please send that information along.
                design.medeek.com
                • medeekM Offline
                  medeek
                  I need some feedback on another marketing strategy for the plugin. I'm thinking about creating a lite version Medeek Wall Plugin LT, this version would only have the 2D and 3D (no framing) mode available to it. The interior of the wall (framing, studs, headers etc...) would not be included in the LT version, nor would holdowns and any engineering or estimating features.
                  The LT version may be more suitable for some designers who do not want to be bothered with the details of the construction and are only interested in the layout.
                  The ability to insert windows and doors as well as all of the trim and casing options would still be available in the LT version.
                  What would you suggest as the regular price for an LT version? Is there any interest in this direction?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I am providing a few links for the plugin below:
                    Main Plugin Page:
                    (design.medeek.com)
                    Changlog:
                    Medeek Design Inc. - Medeek Wall Plugin Changelog
                    (design.medeek.com)
                    Vendors:
                    (design.medeek.com)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I've added the two beam icons to the columns toolbar:
                      http://design.medeek.com/resources/images/wall_beamscolumns_su_menu_active.jpg
                      The following beam types will be available:
                      • Glulam
                      • Sawn Lumber
                      • Timber (5"x5" and larger)
                      • SCL (LVL, PSL, LSL)
                      • Steel (W, C, L, HSS)
                      A placement parameter will allow one to specify Top Center or Bottom Center.
                      A ply (qty.) parameter will allow for multi-ply beams, this is typical for LVL beams and sawn lumber.
                      My idea on this draw tool is to have the HTML menu stay open allowing the user to draw as many beams as desired with the ability to change any of the settings within the HTML menu and then being able to resume drawing beams.
                      If this type of menu/tool system works well I will probably adopt something similar for the Wall Draw Tools.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Had an interesting email today on the complexity of the plugin. I agree that the menus are a bit daunting even for myself, and I even know what each parameter is and does.
                        I've discussed this previously in the thread with an idea to go to an HTML menu that hopefully might be less "scary".
                        The problem really is that to fully define a wall with all of the flexibility needed the number of parameters quickly goes through the roof. Case in point, look at the edit window menu here:
                        404 - File or directory not found.
                        (design.medeek.com)
                        People like the simplicity of SketchUp, that is what has drawn many of us to it. Then I turn around a throw a bunch of menus at you with 15-20 parameters each, I can understand how this can be a bit much for many people.
                        As I've been contemplating this problem and trying to find a solution (compromise) I've come up with the following idea.
                        Essentially have the draw wall tool present an HTML menu not to dissimilar from the current HTML edit menu. However organize the options that turn off the various advanced options into highlighted headers with all of the sub-details hidden unless those particular header items are enabled. It may take a few iterations to get this right but I think it would be better than the current system of multiple menus that pop up one after the other.
                        I'm not a software developer or a GUI expert but when I hit upon the right solution I will know when it is right.
                        As far as decreasing the depth of the plugin, that cannot be done. What can be improved upon is the ability to better manage that data and organize and present it in a more concise and clear fashion.
                        This is the reason for the extensive global settings, the user can enable or disable the default behavior for a number of parameters and options allowing the user to precisely determine to what level of granularity they wish to take their model.
                        For instance many people probably don't want to model the cavity insulation (personally I don't find it that useful) but if that level of detail is needed it can be turned on in the insulation tab of the global settings.
                        Please continue to send me your feedback. I have lots of ideas on how this plugin should go together but I've changed gears a few times already when shown a different way.
                        design.medeek.com
                          Charlie__V
                          Nathaniel,
                          I had some time today to try your wall plug-in.
                          It appears to install just fine,(as admin/restart SU) but I have been unable to get it to function.
                          All of the menus appear, and when I select the draw wall icon.....set wall parameters....click OK......attempt to draw wall....nothing happens....no indication from cursor....no snap point highlight or wireframe of wall appear.
                          Perhaps this is a MS Windows 7 Pro limitation and/or an IE V11 thing? (see my machine spec's in sig.)
                          Sorry to trouble you with this as I know you are incredibly busy......but figured if this is an MS/OS limitation maybe it should be posted here. (or further a compatibility note on download page)
                          Thanks for your time.
                          Edit:
                          I have what I believe is the latest version. (June 6th)
                          & License type is TRIAL and the text is green.
                          Charlie
                          • medeekM Offline
                            medeek
                            @charlie__v said:
                            Nathaniel,
                            Edit:
                            Charlie
                            Let me guess, the advanced wall options are turned off?
                            design.medeek.com
                              Charlie__V
                              Advanced wall options are set to YES (in wall parameters window & global settings)
                              C
                              • medeekM Offline
                                medeek
                                C
                                Open the Ruby Console, then duplicate the error and send me the error code nathan@medeek.com
                                I made a number of improvements yesterday and I may have inadvertently broke the plugin with the latest release (0.7.6e).
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 0.7.6f - 06.07.2018
                                  • Added the ability to lock the cursor to the X or Y axis for the "Draw Wall Tool" (line and polyline) by pressing the SHIFT key.
                                  • Added the ability to lock the cursor to the 45 deg. and 135 deg. axis for the "Draw Wall Tool" (line and polyline) by pressing the CTRL key.
                                  Also note that I fixed a couple of bugs I accidentally created when making the code adjustments for version 0.7.6e, I managed to break the plugin for all TRIAL users.
                                  Therefore this is a critical update, please remove the prior version and install this version which will fix the error introduced last night. This is what happens when I try to get too much done in one day.
                                  Click on the image to view animation:
                                  design.medeek.com
                                    alpro
                                    Any chance to be able to add our own textures to the walls ? Would it be possible to just have a library that we could add too......would like to see that also in the roof textures with the truss tool.
                                    • medeekM Offline
                                      medeek
                                      When you say walls, are you talking about texturing the framing, cladding, sheathing or gypsum?
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.7.7 - 06.08.2018
                                        • Created the Medeek Wall Plugin LT, a lighter version of the plugin with internal wall framing, estimating and engineering removed.
                                        • Horizontal and Vertical OSB sheathing materials added to the pre-installed plugin materials.
                                        http://design.medeek.com/resources/images/wall_su97_800.jpg
                                        Note that the June promo does not apply to the LT version of the plugin
                                        design.medeek.com
                                          alpro
                                          As far as texturing I'm talking about cladding and gypsum so that I can show client specified materials and that I don't lose those materials when a client makes changes and the walls need rebuilt.
                                            alpro
                                            So finally had some time to really try this out and have run into 3 issues,
                                            1)My global settings don't stick
                                            2)No matter what settings I use or which direction that I draw the wall in the cladding always is inside.
                                            3)Would be nice if last settings were remembered when drawing a new wall
                                            • 74
                                            • 75
                                            • 7 / 75
