    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 96.8k Views 14 Watching
    • JQLJ Offline
      JQL
      I did what you suggested. Erased the pbr plugin and folder from my appdata's plugins folder, restarted everything and installed, following all your suggestions.
      Still no good with 1.2.5:
      www.casca.pt
      Visit us on facebook!
      • samuel_tS Offline
        samuel_t
        @jql said:
        Hi JQL, please follow these new instructions:
        1. Close SketchUp if it's open.
        2. Open Windows's File Explorer.
        3. Go to %APPDATA%\SketchUp\SketchUp 2018\SketchUp\Plugins\pbr
        4. Right click on web_server.cmd file. Choose "Edit" in contextual menu.
        5. Replace this line:
        cd %~dp0 && cd Web Server
        by this line:
        cd /d "%~dp0%Web Server"
        1. "File" > "Save".
        2. "File" > "Exit".
        3. Open SketchUp.
        4. "Extensions" > "Physically-Based Rendering" > "Open Viewport".
        5. Do you see SketchUp model in PBR Viewport?
        • samuel_tS Offline
          samuel_t
          @jql said:
          Also, I found you removed support for emissive materials, which would be a shame, as I use them for all my lighting applications in Thea for Sketchup and would find them cool to test on this pbr plugin.
          Today, I think it's better to implement glTF KHR_lights extension. So PBR plugin users could:
          • Add and place lights in SketchUp (Maybe as hidden geometry? I'm looking for solutions.),
          • Set light type (point, spot, etc.) and properties (color, intensity, etc.) again in SketchUp,
          • Export lights (embedded in glTF file) to PBR Viewport and possibly to other platforms...
          • samuel_tS Offline
            samuel_t
            @jql said:
            It's easier for most users to have a separated roughness and metallic maps as they are very common, instead of the metallic-roughness map required by the plugin. [...] is there any chance the separated maps could be implemeted?
            ~~I agree it's easier but it's not so much long to pack metallic and roughness maps in third-party software. For example, it takes less than one minute in Photoshop following these instructions:
            1. Open roughness map in Photoshop.
            2. Convert Grayscale to RGB Color.
            3. Unlock (roughness) layer.
            4. Select (roughness) layer. Open Blending options.
            5. Uncheck all Channels except G(reen).
            6. Place Embedded... metallic map.
            7. Select metallic layer. Open Blending options.
            8. Uncheck all Channels except B(lue).
            9. Save as... metallic-roughness map.~~
            Update: Since PBR plugin v1.3.0, Metallic and Roughness maps are separated in PBR Material Editor. πŸ˜‰
            • JQLJ Offline
              JQL
              @samuel_t said:
              [*]Metallic & Roughness maps are separated in Material Editor.
              Good news indeed. Will try it again.
              www.casca.pt
              • samuel_tS Offline
                samuel_t
                Good news! PBR plugin becomes really handy with the new version (1.3.0).
                Features
                • Change environment map from SketchUp "Extensions" menu.
                  Tip : Changing environment map changes ambient light map.
                • Metallic & Roughness maps are separated in Material Editor.
                • Access online help document translated in FR from Viewport.
                Bugfixes
                • Fixes pan (middle button) control issue in Viewport on Firefox.
                • Fixes a little gamepad control bug. Improves maybe performance.
                ❗ As part of an update, remember to disable plugin before uninstalling-reinstalling it.
                • samuel_tS Offline
                  samuel_t
                  Next PBR plugin version will include a (micro) library of royalty-free PBR materials.
                  These will be available in "Materials" tray. Render-example with "Wooden Palisade 01":
                  Wooden Palisade 01
                  This should allow new users of plugin to become familiar with PBR materials.
                  • N Offline
                    nlipovac
                    Hi, I have one question.
                    What is stopping you in developing this plugin as synced rendering plugin for Sketchup (or maybe as an overlay to SU window)? Is this far-fetched for me to think like this?
                    • samuel_tS Offline
                      samuel_t
                      At dev. beginning, I've thinked about a PBR Viewport synced with SketchUp...
                      That implies using internal browser but external browser is more up-to-date.
                      • JQLJ Offline
                        JQL
                        Thea has viewport rendering which, for single monitors brings sketchup to life. Your plugin, as it is realtime, would be amazing with viewport rendering.
                        www.casca.pt
                        • N Offline
                          nlipovac
                          Right like that JQL, I am quite impressed by this plugin and like to Blender is Eevee this would be a great plugin for SU if it would be implemented as an overlay to SU.
                          • samuel_tS Offline
                            samuel_t
                            By "overlay", you mean a top window a bit like PBR Material Editor? Fullscreen or splitscreen?
                            • N Offline
                              nlipovac
                              This is Thea rendering in SU window, the same thing Vray have also.
                              • N Offline
                                nlipovac
                                • N Offline
                                  nlipovac
                                  It was just an idea, thank you for this that you already accomplished with this plugin. πŸ˜„
                                  • samuel_tS Offline
                                    samuel_t
                                    Overlay feature request is out of my skills for now. Maybe another dev can, since code is open-source.
                                    • samuel_tS Offline
                                      samuel_t
                                      Thank you for your idea. πŸ˜„
                                      • JQLJ Offline
                                        JQL
                                        I will talk about this case with someone...
                                        www.casca.pt
                                        • samuel_tS Offline
                                          samuel_t
                                          Yeah. There is an expensive workaround: to buy several monitors. πŸ˜† More seriously, I will try to find a way to synchronize PBR Viewport with SketchUp.
                                          • filibisF Offline
                                            filibis
                                            @samuel_t said:
                                            • Plugin comes with a tiny PBR materials library. Donate to make it grow!
                                            Take a look at these websites for free (CC0) textures: Pixel-Furnace, CC0Textures, freepbr. You can provide link to these sites maybe?
                                            I think you should indicate that we need to open a collection to use PBR materials you provided. People may not find PBR folder you generated easily.
                                            In addition to 'saving, opening and creating' a model, when we "apply all changes" in the PBR material editor, Chromium pops-up and updates the view as well.
                                            HDR images working fine πŸ‘ Can we rotate them somehow? That would be cool πŸ™‚
                                            • 3 / 6
