    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 710.2k Views 121 Watching
    • fredo6F Offline
      @paragao said:
      Hi all,
      I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
      This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
      By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
      • fredo6F Offline
        NEW RELEASE: FredoTools v3.2d - 09 Apr 18
        FredoTools 3.2d is about bug fixing in EdgeInspector.
        See FredoTools plugin home page for Download.
        See also main post of this thread for User Discussion.
        • JQLJ Offline
          JQL
          What exactly are we supposed to find in these models?
          www.casca.pt
          Visit us on facebook!
          • fredo6F Offline
            @jql said:
            Tiny edges, needle eyes, etc....
              Areczan
              Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
              Error: #<ArgumentError: wrong number of arguments (0 for 1)>
              c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
              c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
              c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in call'
              C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
              C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
              C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in register_extension'
              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in <top (required)>'
              • fredo6F Offline
                Do you have the problem if you disable VRay?
                  Areczan
                  No. But there's also no problem when I only disable Fredo Tools.
                  • fredo6F Offline
                    It's probably a conflict between Plugin (although I don't have it on my machine with VRay 3.6). So removing one or the other should eliminate the issue.
                      bharralure
                      Bonjour Fredo
                      Je viens de découvrir un petit problème avec les outils "Volume Solides" et "Étiqueter les Surfaces"(SketchUp Pro 2018).
                      Je ne peut plus sélectionner les valeurs affichées dans la boite de dialogue, pour les copier (Ctrl + C). Il me semble que le problème soit lié à la dernière mise à jour de Lib Fredo6 (v8.4d). En effet, je ne rencontre pas le problème dans SU Make 2017 que je n'ai mis à jour.
                      C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant.
                      • fredo6F Offline
                        @bharralure said:
                        Bonjour Fredo
                        Thanks for signaling. I identified it and will publish an update to fix it.
                        • X Offline
                          xroo2
                          When I download the .rbz file...it comes in as a PDF. What's up wtih that?
                            Gábor
                            Where did you download it from? Try from here: https://sketchucation.com/pluginstore?pln=FredoTools
                            • PixeroP Offline
                              Pixero
                              Maybe you have accidently chosen that rbz files shall open with Acrobat? In that case right click and open with and set it to always open .rbz with SketchUp instead.
                              • X Offline
                                xroo2
                                ..found out that it is just my computer which inserts Adobe icon and suffix for 'whatever' reason. The .rbz file opens find through Extension Manager 😕
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v3.3a - 21 Oct 18
                                  Requirement: LibFredo6 v8.6i or above
                                  FredoTools 3.3a fixes bugs in FredoTools::ReportLabelArea.
                                    Pascalou54
                                    Bonjour,
                                    J'ai toujours une erreur sur SU2017,
                                    "erreur de chargement du fichier Fredo6_FredoTools/__loader__FredoTools
                                    Could not find included file 'Fredo6_FredoTools/_loader__FredoTools"
                                    Dans quel répertoire doit on mettre \Fredo6_FredoTools
                                    -_v1.8c ?
                                    merci
                                      Il vaut mieux utiliser le Ruby rouge pour installer les plugins, comme cela aucun problème de savoir où il faut les installer, dans quels répetoires etc...dans cette jungle de windose! 💚 (bouton rouge [highlight=#ff4040:1j6ys88t]"Installer l'Extension"[/highlight:1j6ys88t] (bas de page)
                                      Il faut installer aussi la dernière Fredo Lib avant! 🤓 (avec le même Ruby rouge! 😉
                                      Toujours avec le Ruby rouge, il vaut mieux dé-installer les anciennes versions des plugins à venir avec la section "Gérer"! (haut de page)
                                      https://i.postimg.cc/GhZ8S2tW/red_ruby.jpg
                                        dedmin
                                        See the video. Windows 10, SU Pro - all up to date.
                                        https://imgur.com/a/jyUEA0P
                                        • fredo6F Offline
                                          This is fixed in [url=https://sketchucation.com/pluginstore?pln=LibFredo6:3fes6yqn]LibFredo6 8.6n[/url:3fes6yqn], just published.
                                            dedmin
                                            Thanks, Fredo.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 19 / 24
