    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 160 Posters 605.9k Views 159 Watching
      Jorgensen
      impressive work oxer!
      • Bob JamesB Offline
        Bob James
        Thank you, oxer
        • OxerO Offline
          Oxer
          You're welcome!
          • FrederikF Offline
            Frederik
            Learning something new everyday... πŸ˜„
            However, why can't I get this right...?
            Canvas-bag.skp
            Cheers
            Kim Frederik
            • OxerO Offline
              Oxer
              Care Frederik!! "The curiosity killed the cat" πŸ˜† πŸ˜†
              • OxerO Offline
                Oxer
                The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
                • HornOxxH Offline
                  HornOxx
                  thank you Oxer for your second sketch πŸ‘
                  I continue to fail at the simplest things 😳 How do I make cloth and Pin sticking together?
                  test 01.skp
                  never trust a skinny cook
                  • FrederikF Offline
                    Frederik
                    But seriously...
                    When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect... 😞
                    I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
                    I don't get the result HornOxx is showing in his animation... πŸ’š
                    I assume that's caused by the cloth isn't "inside" the frame...?!?
                    Cheers
                    Kim Frederik
                    • OxerO Offline
                      Oxer
                      HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
                      REMEMBER: The cloth should enter a little in the frame.
                      • FrederikF Offline
                        Frederik
                        But like I wrote...
                        I don't have the issue HornOxx is experiencing...
                        The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
                        Cheers
                        Kim Frederik
                        • OxerO Offline
                          Oxer
                          REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
                          • FrederikF Offline
                            Frederik
                            Ok... I've made the frame with 3 slats...
                            At first I couldn't make it work - because I had grouped them...
                            One IMPORTANT info is missing...
                            You need to move the frame-pins one by one...
                            It can't be done by moving all three in one go... πŸ€“
                            Cheers
                            Kim Frederik
                            • OxerO Offline
                              Oxer
                              Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
                              • FrederikF Offline
                                Frederik
                                Got it... πŸ‘
                                Hold down the shift-key when clicking the pins and then converge...! πŸ˜„
                                This gives me a ton of new options and ideas... πŸ˜„
                                Thanks, Oxer...! πŸ‘
                                Cheers
                                Kim Frederik
                                • PixeroP Offline
                                  Pixero
                                  For a non native english speaker. Could you explain what converge is?
                                  Googling it didnt help. πŸ˜•
                                  • BoxB Online
                                    Bring together.
                                    Move toward each other as if to become one.
                                    Two paths can converge into one and diverge back into two.
                                    • PixeroP Offline
                                      Pixero
                                      Thanks.
                                      • FrederikF Offline
                                        Frederik
                                        Strange...
                                        I get a lot of results - especially if I write "define: converge" in Google... πŸ˜„
                                        Even Google translate has a nice explanation...
                                        Cheers
                                        Kim Frederik
                                        • N Offline
                                          notareal
                                          Nice work with this!
                                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                          • PixeroP Offline
                                            Pixero
                                            Strange...
                                            What I meant was simply that I didn’t understood the meaning of the word using Google.
                                            • 34
                                            • 35
                                            • 7 / 35
