    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • fredo6F
      NEW RELEASE: Curviloft v1.7c - 27 Feb 18
      Curviloft 1.7c is a major maintenance release fixing bugs in the Edge Selection process
      In particular, Curviloft displays a message box whenever the contours are not complinat with a generation of geometry. This is the case for the Skinning tool when selected edges cannot be interpreted as sequences of 3 or 4 curve portions.
      IMPORTANT: It requires LibFredo6 v8.1c or above.
      See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
      Main post of this thread
      • JClementsJ
        JClements
        FYI, the last couple of weeks I have had numerous crashes. I,m not sure, but it could be when dealing with large- segmented curves or with very small curves whose segments or angles are beyond SU tolerances. I believe 2017 and 2018 will now warn if arc-segments are incompatible when trimming, for example, the corners of a rectangle. If. Curviloft doesn’t error check for this or other warnings could this could problems? There were cases last week when merely passing the Progflile’s cursor over an edge, without pressing the mouse, would crash SU.
        • E
          Einstein
          Hi!
          I want to post a quick movie and my model to illustrate a bug that I described some time ago but maybe didn't explain clearly.
          I had problems with curvilofting some more complicated contour sets, using Skin Contours. I was advised to draw manually "separation lines" at contour borders and that helped. But sometimes I forget or don't know that a certain set needs such separation, then I perform Skin Contours onto a problematic contour set and then Curviloft gets stucked. It endlessly shows yellow progress bar on top of viewport and doesn't let me back to settings (grey toolbar). Since this moment I cannot recover this toolbar with loft settings, until I restart SketchUp (which is very asspainful having almost 200 plugins installed).
          The model shows a few complicated sets of 4 curved contours. The video shows the issue which comes even with simple contours after a difficult skinning is performed. It happens even if I start a new model in SketchUp.
          Please tell me somebody if you also have this problem or is it just my computer...
          SketchUp 2017, Win7, 64bit
          curvissue.skp
          Curviloft issue.avi
          • E
            Einstein
            I also don't understand one thing. In the attached model I have four contours touching each other, each consists with 8 segments. So I perform Skin Contours and don't know why it adds some extra geometry. As if some of contours' segments were divided. But they're not. I'd expect 7 curves created along and 7 across the surface.
            In this case it's not even possible to match vertices in order to eliminate additional divisions.
            only 8 segments.skp
            • jgbJ
              jgb
              Curviloft does not align its lofted lines exactly to the vertices on the opposite side. If the spacing of the 2 opposite points are not aligned CL will just draw lines from each vertex to the opposite side on edge, and you get a lot of extra lines, some very close together.
              I spend a lot of time adjusting lines to reduce that overall line and face count.
              Use the ALT-Move Tool to move a vertex over to its closest partner. Pick the vertex on a perimeter that is on a straight portion of that segment.
              It IS tedious, but in many of my big drawings I really need to reduce line count.
              jgb
              • fredo6F
                I had no problem with the model....
                ....But it's true that Skinning has sometimes difficulty to find out the right cutting of contours.
                • fredo6F
                  Well, the issue is that if you join vertex to vertex, you get a skewed surface, even assuming the number of vertices on each opposite side matches.
                  So, there is no general solution to the problem, unless Curviloft does a resampling of the contours (which it does not do in the current version).
                  • E
                    Einstein
                    It's no problem that I spend extra time matching vertices but as you can see in the screenshot, in this case it's not even possible cuz I can only match vertices left-right while additional lines appear top-down. If I Swap Rails and Profiles, it's opposite. What if we could match both rails and profiles at the same time or force automatical matching vertex-to-vertex? In some cases Simplify parameter will work but not always, even if I set it to 80%. Maybe it would make sense to give us 100% as a maximum value? I don't know if it's mathematically possible.
                    In the second screenshot with red arrows I showed how the connection is done and in the third one with green arrow - how I'd imagine it.
                    I reinstalled Curviloft and still have this no-settings bug. What's more, it also affects Round Corner plugin so when I try to roundcorner some edges, it also omits settings 😞
                    • jgbJ
                      jgb
                      Fredo said... Well, the issue is that if you join vertex to vertex, you get a skewed surface, even assuming the number of vertices on each opposite side matches.
                      True, but I move all of the vertices along a line, not just at the perimeter. My surfaces end up smooth. But each line set has to be adjusted as it approaches the opposite perimeter line or as you said, the smoothness suffers. Usually around the middle of the set I do a 1/2 move to each side to avoid a skewed surface.
                      Like I said, it is tedious.
                      I really can't live without CL, even with all its worts. I have learned to live with them and get around most of them. Still far easier and smoother than manually lofting a surface.
                      Before and after moving endpoints
                      jgb
                      • E
                        ecs05norway
                        Trying to work out a way to build a surface between non-parallel lines. I've got an attachment here to show what I'm working with - basically, I've got four straight lines connecting to each other, none of which is parallel to any of the others. I want a smooth curve, but all I get is a corrugated surface or a sharp angle formed from a line directly bisecting the region. Or a stalled plugin.
                        Trying to complete the missing side of this, basically.
                        Curvy Triangle.skp
                        • fredo6F
                          [attachment=1:2802zlol]<!-- ia1 -->Curvy Triangle.jpg<!-- ia1 -->[/attachment:2802zlol]
                          You must use the SAMPLING and INTERPOLATE options to create intermediate lines, so that the surface is smoothed.
                          [attachment=0:2802zlol]<!-- ia0 -->Curviloft Sampling - Interpolate lines.png<!-- ia0 -->[/attachment:2802zlol]
                            AdriSonet
                            Hello Fredo, I'd love to know if you can extract the lines in between when you use loft by spline. I'm using two lines and the tool, I'd love to get the line.
                            https://i.imgur.com/D1TLId9.png
                            Those are the lines I want to get in order to create this kind of design.
                            https://i.pinimg.com/564x/f7/7d/1e/f77d1e96542765fa0c854430ecb85232.jpg
                            Thank you so much!
                            • fredo6F
                              In the button palette, you have a section titled "Geometry". The first two buttons gives options to keep only lines in one or the two directions (use the tooltips for details).
                              • E
                                Einstein
                                Thank you so much!
                                I think what yo want to achieve is something like Loop Selection in 3DSmax. You can use ThomThom's Quad Face Tools, convert your mesh to quads, then select quad loops.
                                There is also a small plugin by Blindcop "Extrapolate selected edge"
                                https://sketchucation.com/forums/viewtopic.php?f=323&t=61884
                                which will let you select continuation of an edge in a mesh. However, it doesn't manage triangulated faces well (or at all?).
                                  rv1974
                                  Fredo, could you please DISABLE Loft by spline tool working with PRE-selected set of edges?
                                  Or at least give some give pop-up warning (this operation will take a loot of time co compute blah blah blah)?
                                  So MANY times I have to shut down skp session (=loosing 15 min of work 😒 ) because it's freezing forever trying to guess the appropriate order
                                  • fredo6F
                                    Do you have a model example where this happens
                                      rv1974
                                      Select all 7 (not one by one), then run loft by spline-
                                      permanent freeze. Very common thing.
                                      dddd.skp1.skp
                                      • fredo6F
                                        This is just a bug, due to the fact that all contours is exactly spaced at the same distance.
                                        Thanks for signaling
                                        I fixed it in version 1.7d, just published.
                                        PS: Actually, the long waiting time you had is not infinite. After a number of seconds, you get back control. So there was no need to force an exit of Sketchup.
                                        • fredo6F
                                          NEW RELEASE: Curviloft v1.7d - 31 May 18
                                          Curviloft 1.7d is a maintenance release fixing a bug in the automatic ordering of contours for the Spline tool.
                                            rv1974
                                            Unprecedented responsiveness Fredo,many thanks!
                                            I'll test the update later today.
                                            Another imperfection (?, - maybe I just can't find right buttons) I encountered with Loft by spline is that
                                            the inter-medial segments can't keep exact dimensions of initial profiles (lowest and highest ones in attached example 12X81m*, storey height is 3.5m). Another issue is that segments are slightly OFFXY Plane.
                                            Is it possible to develop some special mode that'd keep segments exactly parallel to the input profiles, and if initial profiles are equal it'd keep their dimensions?
                                            • P.S. In this particular case of 50+ storey towers PlayitItAgain script helped a lot.
                                            dddd.skp1.skp2.skp
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 65
                                            • 66
                                            • 59 / 66
