    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      I've added a few FAQs here:
      Just a moment...
      (www.kickstarter.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        The default layers for the plugin will be the following:
        WALL LAYERS:
        wall_frame
        wall_sheath
        wall_clad
        wall_trim
        wall_gypsum
        wall_insul
        MISC LAYERS
        wall_hardware (straps and holdowns)
        If one want more granular control over the wall framing layers then the option will exist in the global settings to enable "advanced wall framing layers":
        ADV. WALL FRAMING LAYERS (ON/OFF)
        wall_header
        wall_plate
        wall_beam
        wall_column
        wall_king
        wall_trimmer
        I'm sure there will be other layers that will need to be added but these are the ones I've come up with for now.
        design.medeek.com
        • medeekM
          medeek
          Global settings:: Layer Tab:
          http://design.medeek.com/resources/images/wall_su6_800.jpg
          The Kickstarter campaign has met its goal of $2,500.00. I will be working on the wall plugin full time for the next month or two, until I have released the first public release of this new plugin.
          I would like to thank all who have pledged and supported the campaign and also those who may yet support the campaign.
          I am making solid progress on the Wall Plugin. All of the framework is now in place and the backend progamming (shopping cart, database, icons, images etc...) is now also complete.
          My ETA for the plugin is mid June but I think I will probably beat that self imposed deadline if I can keep at it full time like I have the last few days.
          design.medeek.com
          • jujuJ
            juju
            It’s great to see that you’re sticking to the ability to customize the layers where the various groups/components will be placed.
            • medeekM
              medeek
              I'm doing my best to stay consistent with the truss plugin and provide as many parallel features and also learn from my successes and failures.
              When the Wall Plugin is released it should be on par with the truss plugin, at least this is my objective.
              design.medeek.com
              • medeekM
                medeek
                The first menu for the rectangular wall tool, metric version is also complete (not shown):
                http://design.medeek.com/resources/images/wall_su7_800.jpg
                I've modifed the wall type parameter to include the following (3) options:
                Int-Int
                Int-Ext
                Ext-Ext
                I am still thinking about how best to accommodate custom stud sizes. I may make it possible to enter in custom sizes in the global settings so they can be permanently stored. I prefer that the wall dialogues simply show a stud size rather than breaking it down into depth and width, but ultimately those two dimensions are what is being controlled here.
                Working on the positioning tool portion, I will borrow from the timber truss module of the truss plugin to accelerate this coding task. Also working on the advanced wall options and its menus etc...
                Please let me know if you see something important that I am missing or if something can be made better. I am always open to suggestion.
                design.medeek.com
                • medeekM
                  medeek
                  In the global settings you can enable a 3D preview:
                  http://design.medeek.com/resources/images/wall_su8_800.jpg
                  The 2D preview is default, which just shows the footprint of the wall.
                  design.medeek.com
                  • medeekM
                    medeek
                    Within the global settings and also when you edit a wall you will be able to modify the corner treatment at the start and end of each wall segment, the parameters being:
                    Corner Stud Qty: 1,2,3,4
                    Corner Stud Thk. (in.): 1.5 (default), can be user defined to any value
                    Corner Treatment: California, None, etc...
                    Corner Angle (deg.): 90, can be user defined, 0 < x < 180
                    Corner Configuration: End, Outside Corner etc...
                    Corner Offset (in.): Stud Depth or numeric value (ie. 3.5, 5.5 7.25 etc...)
                    This will allow the user to utilize any combination of studs or timbers at each corner (ie. a 6x6 post) for a wall segment needing some serious shearwall action.
                    When you create a wall these three parameters will not be shown and will pass through from the global settings. If a wall needs to be modified then a simple right click and "edit wall assembly" will allow for changing up these settings for either end of the wall segment independently.
                    If holdowns are enabled then the placement of the holdowns (ie. HDU series) will be modified appropriately to rest against the innermost corner stud surface.
                    In addition to framed openings (ie. windows and doors) there may also be other misc. items associated with a wall segment:
                    • Wall Columns
                    • Beam Pockets
                    • Additional holdowns/straps for shearwall segments within a given wall
                    • Additional framing where a wall meets another wall mid-length (T intersection).
                    I will give these items some more thought as the development progresses and determine the best way to add these items into the UI.
                    As I imagined the complexity that can occur when framing a structure only gets more interesting the farther down the rabbit hole I go.
                    P.S. The numbers of parameters just grew from four to six, this now addresses non-orthogonal walls.
                    design.medeek.com
                    • medeekM
                      medeek
                      Global Settings:: Wall Corners:
                      http://design.medeek.com/resources/images/wall_su9_800.jpg
                      Within this tab the user can set the defaults for the wall corners.
                      These same settings can also be set for each wall segment with the "edit wall" tool.
                      design.medeek.com
                      • FrederikF
                        Frederik
                        This looks really interesting, however, when trying to download the trial version on your website (http://design.medeek.com/resources/medeekwallplugin.html) I get a "The page cannot be found" message...?!?
                        Furthermore there's another serious mistake on the page...
                        Purchase the full plugin ($5.00) at the following link:Purchase plugin
                        When users arrive at the order page, they don't see the price 5.00 USD, but 50.00 USD...
                        Cheers
                        Kim Frederik
                        • medeekM
                          medeek
                          I should probably temporarily disable the web page since the plugin has not yet been released yet, and yes you are correct, the listed price of $5.00 is incorrect.
                          design.medeek.com
                          • medeekM
                            medeek
                            I am now testing the stud placement and top and bottom plates:
                            http://design.medeek.com/resources/images/wall_su10_800.jpg
                            So far only the line tool is available but seems to work fairly robustly now.
                            Please download and comment on the model below:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            There are a few minor issues that need further attention:
                            1.) How to position studs with non-orthogonal walls, I could use some direction on this.
                            2.) I have California Corners enabled for outside corner and inside corners, what do you do when there is a clash between the nailer and the regular stud layout, see model for examples.
                            3.) When there is more than one top plate (2,3 etc...) I have them setup to lap each other. However multiple bottom plates do not lap, they are currently setup just to stack.
                            The items for tomorrow's programming todo list are:
                            • Setup the HTML form and backend for the wall edit feature.
                            • Finish cleaning up the global settings, HTML and backend.
                            • Further debugging and refinement of the stud placement module.
                            Future items:
                            • Addition of window and door modules (framed openings)
                            • Advanced wall options (sheathing, cladding, gypsum, insulation, trim, holdowns etc...)
                            • Window and Door Plugin
                            • Gable Wall Tool
                            • Polyline tool for Rectangular Wall Tool
                            I'm sure there are plenty of other items that don't come to mind right this minute, please feel free to pass along any thoughts, comments or suggestions.
                            design.medeek.com
                            • medeekM
                              medeek
                              Working on the advanced options this morning, I've added in sheathing, cladding and gypsum:
                              http://design.medeek.com/resources/images/wall_su11_800.jpg
                              As windows and doors are added to the wall they will automatically cut holes into the framing and these three other building layers. The code to cut holes in solids is actually not to difficult, I developed it with the foundation plugin when I needed to add foundation vents into stemwalls.
                              I will probably put the cavity insulation and the holdowns on the backburner for a a while as I focus on the wall edit function and the window and door (framed opening) module.
                              I've also added one additional (Tee Corner) corner configuration for each end of the wall.
                              I will also be adding in two additional parameters so when you edit a given wall panel you can offset the sheathing and cladding above or below the actual wall panel to tie into a rim joist above or below. Some contractors also like to lap the sheathing and cladding over the foundation rather than having it flush with the sill/bottom plate.
                              On a similar note it might also be useful to allow the user to set the bottom plate as pressure treated (ie. garages where the wall is directly in contact with the foundation). I'm not sure yet where I want to put this parameter.
                              design.medeek.com
                              • medeekM
                                medeek
                                PT bottom plate option added into the first menu.
                                The little structure below is not much to look at (no windows or doors yet) but it is the first time I've been able to create an entire building envelope with absolutely no manual editing of the SketchUp model. This in itself is a major break through for me. I used all three plugins to create the model: Foundation, Truss and Wall.
                                http://design.medeek.com/resources/images/wall_su12_800.jpg
                                http://design.medeek.com/resources/images/wall_su13_800.jpg
                                All principal architectural elements are there: sheathing, cladding, gypsum, anchor bolts, rebar, concrete, roof cladding, gutters etc...
                                The only items missing are exterior and interior trim/molding and of course the windows and doors.
                                My next push will be the windows and door module.
                                The time required to create the walls was under a minute however once I have the polyline tool enabled this will cut down the initial wall creation time to literally seconds.
                                Insertion of doors and windows will always take a bit longer primarily because the designer actually needs to determine where they want to place their openings. There is not much one can do about that other than to make the actual placement/insertion process as intuitive and automated as possible.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  The wall edit feature is now functional and seems to be fairly robust:
                                  http://design.medeek.com/resources/images/wall_su14_800.jpg
                                  The wall edit menu shown above.
                                  Originally I was going to have all the windows and doors load up within this same menu but given how big it has grown already I think a separate edit menu for door and windows would be more practical.
                                  I will also need to add in some additional code so that when certain parameters are modified in the wall edit menu those changes are then propagated to other wall panels that are assigned to the same wall group letter.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I've added mid-span blocking into the advanced options:
                                    http://design.medeek.com/resources/images/wall_su15_800.jpg
                                    View model here:
                                    3D Warehouse
                                    This option will probably need additional parameters (mid-span, 8' on center, 4' on center) to make it really useful but at least it is a placeholder for now.
                                    design.medeek.com
                                    • pbacotP
                                      Looks excellent!
                                      • medeekM
                                        medeek
                                        The cavity insulation option in the advanced options will fill in the wall cavities with insulation:
                                        http://design.medeek.com/resources/images/wall_su16_800.jpg
                                        http://design.medeek.com/resources/images/wall_su17_800.jpg
                                        This feature will only get more interesting as windows and doors are added.
                                        I supposed there will be some utility to this option for some since it will allow the designer/contractor to calculate the volume of insulation needed with fairly decent accuracy.
                                        I could use some better textures for my insulation, the ones shown are pink and yellow fiberglass, rockwool and cellulose. I also have a blown fiberglass (white) not shown.
                                        View model here:
                                        3D Warehouse
                                        I've now started wading into the window and door module, this may take me a 2-3 days to sort out since it is fairly complicated.
                                        design.medeek.com
                                        • facerF
                                          facer
                                          Looking good Medeek!
                                          • medeekM
                                            medeek
                                            The global settings will have two parameters:
                                            Blocking Height: Center or some numeric value
                                            Stagger Blocking: Yes / No
                                            Once you create the walls you can also change these two parameters up for each wall panel:
                                            http://design.medeek.com/resources/images/wall_su18_800.jpg
                                            See model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 80
                                            • 81
                                            • 4 / 81
