    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    (SOLVED) Prevent Component dialog box to open
    7 Posts 4 Posters 1.9k Views 4 Watching
      RueM
      I used to work on skp 2015, but recently upgraded to 2017.
      Before, i managed to make groups with a keyboard shortcut then right clic and selected "make component" to make one. This was quite fast in the process, as any dialog box opened.
      Now, when i right clic (or use shortcut) to make a component, the component dialog box opens and takes a while when I select "create". This makes my workflow uselessely being slower...
      Is someone knowing any trick to avoid that dialog box to open ?
      Thx
      • PixeroP Offline
        Pixero
        Your post reminded me that I too wanted this function so with help from TIG I made this little Plugin.
        To install put it in: C:\Users\Your user name\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins
        and start SketchUp. You'll find it under extensions -> To Component
        Add it to a shortcut and you will have a quick way of creating a component from the selected geometry.
        toComp.rb
          RBZ that and stick it on the ExtensionStore. It's a great utility.
          • PixeroP Offline
            Pixero
            Ok I will but I think I will see if I can add some features.
            I'm thinking how it works with ungrouped vs grouped entitys. As it is now if you run it on a group it will create a component with a group in it. I think it would be better if it just converted the group to a component.
            I'll see what I can do.
            • PixeroP Offline
              Pixero
              Here it is with some added features.
              Makes a component without the Component Dialog.
              If the selection is only 1 group it converts the group to a component.
              If the selection is more than 1 item, a component will be made with nested groups or components or loose geometry as they were.
              Add a shortcut for quick use.
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
              • BoxB Offline
                Nice
                  RueM
                  Thanks a lot, that's perfect.
                  Cheers
