    BricsCAD Shape
    extensions
    7 Posts 4 Posters 3.4k Views 4 Watching
      Free and looks like a friend you already know....
      https://www.bricsys.com/shape/
        At first view seems like your friend but alas after use not so easy than your friend! πŸ’š
          Keep your friends close and your enemies even closer!
            Neverless has cool functions! πŸ˜‰
            Perimeters can have any form! πŸ‘
            Here a circle but can be any polygons (without too many "inside" angles!)
            https://sketchucation.com/forums/download/file.php?id=150729
            Booleans are cool also!
            even they are curious ! πŸ˜„
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-trunc_orig.gif
              db11
              Thanks for posting Rich.
              This is one that I've been keeping an eye on since it was first announced in the fall. Will be interesting to see how it compares to SU in capability, workflow integration and ease-of-use. If nothing else, it will be good for SU to have some additional competition in the AEC space.
              Curious to check it out once my current deadline crunch clears.
                dedmin
                It is better to compare as a part of BricsCAD BIM. It is not intended to be used from start to finish like SU.
                "Your Shape model opens directly in BricsCAD BIM. Develop your design, while collaborating across disciplines using buildingSMART-certified IFC. And create construction drawings faster and easier than ever."
                  db11
                  I'm aware of the full BricsCAD workflow... that's part of the interest.
