    Ode to Carlo Scarpa
    13 Posts 8 Posters 2.6k Views 8 Watching
    • Criterion ArchitectureC Offline
      Hello All!
      I've been researching and analyzing the works of the Italian Master architect Carlo Scarpa and felt inclined to have a little fun and design a concept using similar style and aesthetics. Most ideas stemmed from his Olivetti and Brion Tomb and Sanctuary. I may produce more images from the model later.
      Thanks,
      Steve
      All modeled in SketchUp and rendered with Enscape.
      Attached is the model in white mode to understand geometries.
      Carlo Scarpa Inspired Living Space Render
      Carlo Scarpa Inspired Living Space Render Clay Model
      Instagram: @criterionarchitecture
        Brilliant, fantastic, wonderful renders. No model but those renders dood.....
        • majidM Offline
          majid
          Nice rendering job... well done!
          • pmolsonP Offline
            pmolson
            an artist you are.
            • boofredlayB Offline
              boofredlay
              Fantastic.
                Thanks everybody! I appreciate the response.
                • tuna1957T Offline
                  tuna1957
                  most excellant ! πŸ‘
                    A quick question, are we going to see the model in white? Not a problem if you changed your mind.
                    • hellnbakH Offline
                      hellnbak
                      From one Steve to another, I must say that this is one of the most impressive pieces of work I have seen here on the forums. You, sir, are an artist!
                        Sorry for not being clear Mike. I was referring to the clay model being in white mode, which is what Enscape calls the render mode.
                          No problem dood, I should have thought about this a bit more. Still marvelous.
                            Haha much appreciated Steve!
                            • Bryan KB Offline
                              Excellent work!
