    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 111.1k Views 43 Watching
    • jason_marantoJ Offline
      jason_maranto
      Both. Maxwell cameras always operate in 3-point perspective, so orthographic and 2-point perspectives are "approximate" matches... which is often close enough. The plugin should automatically make the adjustments for you.
      To be clear about what I said before: you can setup section cuts using SketchUp, but you would have to "bake" them into the geometry, either manually or via a plugin.
      Best,
      Jason.
      • utilerU Offline
        utiler
        Thanks Jason, you're da Maxwell Man!!!!!
        Just Curious...
        • peterboodtsP Offline
          peterboodts
          Small (dumb?) question.
          When I add a picture to an object in sketchup and render using Maxwell for Sketchup then the image doesn't render.
          Do I do something wrong ? or do I need to set some settings to make it work ?
          Peter
            jason_maranto
            Could you clarify exactly how you are adding the picture?
            Best,
            Jason.
            • utilerU Offline
              utiler
              Hi Jason, Is there a way to view the mxm files from the Insert dialog box? [See attached screenshot]
              Would be nice to know what the materials look like rather than relying in names...
              πŸ‘
              Just Curious...
                jason_maranto
                The full render suite installs a thumbnail viewer so that you can view the material previews like you would any other program thumbnail... however I'm pretty sure the stand-alone plugin does not have this due to the lack of MXED.
                I really feel like the lack of MXED is crippling to the stand alone version and I hope this is resolved somehow in future updates... as a user of the stand alone plugin my number one request would be to either improve the material editing controls in the plugin itself or include MXED in the package and I would make those requests directly here:
                301 Moved Permanently
                (www.maxwellrender.com)
                If enough users make the request I'm sure something would happen.
                Best,
                Jason.
                • utilerU Offline
                  utiler
                  Thanks mate, I will! πŸ‘
                  Another thing: attached is a screenshot of a render in progress. You'll see a png of a Fig tree in the model which I have wound back the opacity for clarity behind but when rendered the image almost doesn't show. Am I better off changing the opacity in the image itself prior to importing it in as a component?
                  πŸ‘
                  Just Curious...
                    jason_maranto
                    Yeah definitely, the way the plugin interprets SketchUp material Opacity is not good for this type of stuff -- partially because it always makes it shiny (to mimic glass).
                    Best,
                    Jason.
                    • utilerU Offline
                      utiler
                      ok, cheers. πŸ‘
                      Just Curious...
                        garystan
                        Jason_moranto :
                                     Apparently, Maxwell for Sketchup has been removed.  I tried your link, and I get an  "Ooops......" error page.   I tried looking for it and, again, it has been removed from the internet.
                                                  garystan
                        • tuna1957T Offline
                          tuna1957
                          garystan , get maxwell here...http://www.nextlimit.com . They have a 30 day demo version and the paid version.....
                            Better to use easy free Real Time render like SimLab Composer Lite (max 1920 * 1080)
                            http://www.simlab-soft.com/Simlabimages/Simlab_Composer/technologies/Features_images/Features_page/FreeFinal-min.jpg
                            • 11
                            • 12
                            • 13
                            • 9 / 13
