    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 145.8k Views 43 Watching
    • jason_marantoJ Offline
      jason_maranto
      Maxwell does not currently recognize section cuts (because they are not real geometry) -- Maxwell has something similar called Z-Clipping, which can be used for floor plans... however it's worth noting that Maxwell also has some issues with non-perspective based camera views. So a true floor plan would be tricky (though if you are willing to accept a slight fudge factor it can be done).
      Best,
      Jason.
      • utilerU Offline
        utiler
        Thanks Jason,
        Are you talking about the full Maxwell Suite or Maxwell for SketchUp?
        As for non perspective based views I guess I could wind out the FOV to near 0 and render..? πŸ‘
        Just Curious...
          jason_maranto
          Both. Maxwell cameras always operate in 3-point perspective, so orthographic and 2-point perspectives are "approximate" matches... which is often close enough. The plugin should automatically make the adjustments for you.
          To be clear about what I said before: you can setup section cuts using SketchUp, but you would have to "bake" them into the geometry, either manually or via a plugin.
          Best,
          Jason.
          • utilerU Offline
            utiler
            Thanks Jason, you're da Maxwell Man!!!!!
            Just Curious...
            • peterboodtsP Offline
              peterboodts
              Small (dumb?) question.
              When I add a picture to an object in sketchup and render using Maxwell for Sketchup then the image doesn't render.
              Do I do something wrong ? or do I need to set some settings to make it work ?
              Peter
                jason_maranto
                Could you clarify exactly how you are adding the picture?
                Best,
                Jason.
                • utilerU Offline
                  utiler
                  Hi Jason, Is there a way to view the mxm files from the Insert dialog box? [See attached screenshot]
                  Would be nice to know what the materials look like rather than relying in names...
                  πŸ‘
                  Just Curious...
                    jason_maranto
                    The full render suite installs a thumbnail viewer so that you can view the material previews like you would any other program thumbnail... however I'm pretty sure the stand-alone plugin does not have this due to the lack of MXED.
                    I really feel like the lack of MXED is crippling to the stand alone version and I hope this is resolved somehow in future updates... as a user of the stand alone plugin my number one request would be to either improve the material editing controls in the plugin itself or include MXED in the package and I would make those requests directly here:
                    WordPress.com β€” 404 Error
                    (www.maxwellrender.com)
                    If enough users make the request I'm sure something would happen.
                    Best,
                    Jason.
                    • utilerU Offline
                      utiler
                      Thanks mate, I will! πŸ‘
                      Another thing: attached is a screenshot of a render in progress. You'll see a png of a Fig tree in the model which I have wound back the opacity for clarity behind but when rendered the image almost doesn't show. Am I better off changing the opacity in the image itself prior to importing it in as a component?
                      πŸ‘
                      Just Curious...
                        jason_maranto
                        Yeah definitely, the way the plugin interprets SketchUp material Opacity is not good for this type of stuff -- partially because it always makes it shiny (to mimic glass).
                        Best,
                        Jason.
                        • utilerU Offline
                          utiler
                          ok, cheers. πŸ‘
                          Just Curious...
                            garystan
                            Jason_moranto :
                                         Apparently, Maxwell for Sketchup has been removed.  I tried your link, and I get an  "Ooops......" error page.   I tried looking for it and, again, it has been removed from the internet.
                                                      garystan
                            • tuna1957T Offline
                              tuna1957
                              garystan , get maxwell here...http://www.nextlimit.com . They have a 30 day demo version and the paid version.....
                                Better to use easy free Real Time render like SimLab Composer Lite (max 1920 * 1080)
                                http://www.simlab-soft.com/Simlabimages/Simlab_Composer/technologies/Features_images/Features_page/FreeFinal-min.jpg
                                • 11
                                • 12
                                • 13
                                • 13 / 13
