    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 162.3k Views 43 Watching
    • pbacotP
      Is the requirement for Silverlight 4 with Fire going to end soon? I now have the choice to watch movies or run Maxwell... πŸ˜• Whereas it's so slow I would like to do both at once πŸ˜„
      • jason_marantoJ
        jason_maranto
        Silverlight is being phased out -- the Grass palette is a preview of this, as per this post: http://www.maxwellrender.com/forum/viewtopic.php?p=357436#p357436
        Best,
        Jason.
        • pbacotP
          Thanks Jason! That's interesting and good to hear. Peter
          • utilerU
            utiler
            Am I right in saying that Maxwell doesn't recognize section cuts and hence won't render floor plans?
            Just Curious...
            • jason_marantoJ
              jason_maranto
              Maxwell does not currently recognize section cuts (because they are not real geometry) -- Maxwell has something similar called Z-Clipping, which can be used for floor plans... however it's worth noting that Maxwell also has some issues with non-perspective based camera views. So a true floor plan would be tricky (though if you are willing to accept a slight fudge factor it can be done).
              Best,
              Jason.
              • utilerU
                utiler
                Thanks Jason,
                Are you talking about the full Maxwell Suite or Maxwell for SketchUp?
                As for non perspective based views I guess I could wind out the FOV to near 0 and render..? πŸ‘
                Just Curious...
                • jason_marantoJ
                  jason_maranto
                  Both. Maxwell cameras always operate in 3-point perspective, so orthographic and 2-point perspectives are "approximate" matches... which is often close enough. The plugin should automatically make the adjustments for you.
                  To be clear about what I said before: you can setup section cuts using SketchUp, but you would have to "bake" them into the geometry, either manually or via a plugin.
                  Best,
                  Jason.
                  • utilerU
                    utiler
                    Thanks Jason, you're da Maxwell Man!!!!!
                    Just Curious...
                    • peterboodtsP
                      peterboodts
                      Small (dumb?) question.
                      When I add a picture to an object in sketchup and render using Maxwell for Sketchup then the image doesn't render.
                      Do I do something wrong ? or do I need to set some settings to make it work ?
                      Peter
                      • jason_marantoJ
                        jason_maranto
                        Could you clarify exactly how you are adding the picture?
                        Best,
                        Jason.
                        • utilerU
                          utiler
                          Hi Jason, Is there a way to view the mxm files from the Insert dialog box? [See attached screenshot]
                          Would be nice to know what the materials look like rather than relying in names...
                          πŸ‘
                          Just Curious...
                          • jason_marantoJ
                            jason_maranto
                            The full render suite installs a thumbnail viewer so that you can view the material previews like you would any other program thumbnail... however I'm pretty sure the stand-alone plugin does not have this due to the lack of MXED.
                            I really feel like the lack of MXED is crippling to the stand alone version and I hope this is resolved somehow in future updates... as a user of the stand alone plugin my number one request would be to either improve the material editing controls in the plugin itself or include MXED in the package and I would make those requests directly here:
                            http://www.maxwellrender.com/forum/viewforum.php?f=127
                            If enough users make the request I'm sure something would happen.
                            Best,
                            Jason.
                            • utilerU
                              utiler
                              Thanks mate, I will! πŸ‘
                              Another thing: attached is a screenshot of a render in progress. You'll see a png of a Fig tree in the model which I have wound back the opacity for clarity behind but when rendered the image almost doesn't show. Am I better off changing the opacity in the image itself prior to importing it in as a component?
                              πŸ‘
                              Just Curious...
                              • jason_marantoJ
                                jason_maranto
                                Yeah definitely, the way the plugin interprets SketchUp material Opacity is not good for this type of stuff -- partially because it always makes it shiny (to mimic glass).
                                Best,
                                Jason.
                                • utilerU
                                  utiler
                                  ok, cheers. πŸ‘
                                  Just Curious...
                                  • G
                                    garystan
                                    Jason_moranto :
                                                 Apparently, Maxwell for Sketchup has been removed.  I tried your link, and I get an  "Ooops......" error page.   I tried looking for it and, again, it has been removed from the internet.
                                                              garystan
                                    • tuna1957T
                                      tuna1957
                                      garystan , get maxwell here...http://www.nextlimit.com . They have a 30 day demo version and the paid version.....
                                        Better to use easy free Real Time render like SimLab Composer Lite (max 1920 * 1080)
                                        http://www.simlab-soft.com/Simlabimages/Simlab_Composer/technologies/Features_images/Features_page/FreeFinal-min.jpg
                                        • 11
                                        • 12
                                        • 13
                                        • 13 / 13
