    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.2k Views 121 Watching
    • OxerO Offline
      Oxer
      Yes, If I press Enter over a textured face the gizmo is stable. When click down the gizmo appears but it disappear immediately (1 second).
      • fredo6F Offline
        NEW RELEASE: FredoTools v3.1g - 11 Nov 17
        FredoTools 3.1g fixes a bug in FredoTools::ReportLabelArea, for the CSV export in non-English languages.
        See FredoTools plugin home page for Download.
        See also main post of this thread for User Discussion.
        • Mousa_SAM Offline
          Mousa_SA
          Hello Fredo,
          Is the thrupaint bugsplat fixed in "FredoTools v3.1g - 11 Nov 17" release?
          It still occur on some of my machines!
          Any suggestion is much appreciated.
          • fredo6F Offline
            NEW RELEASE: FredoTools v3.2a - 24 Feb 18
            FredoTools 3.2a is about bug fixing and introduction of FaceTriangulator.
            • fredo6F Offline
              NEW RELEASE: FredoTools v3.2b - 27 Feb 18
              FredoTools 3.2b is about a small adjustment in FaceTriangulator and some bug fixing.
                rv1974
                May I ask, what is the main purpose of triangulator?
                • fredo6F Offline
                  Just to divide a face into triangles, which is useful in some situations. Actually FaceTriangulator is just a byproduct of another plugin to come.
                  Note that there exists other plugins for face trinagulation (at least one by TIG). FaceTriangulator gives the same result, but you can impose triangulation points as Construction Points on the face.
                  • Mousa_SAM Offline
                    Mousa_SA
                    Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
                    • fredo6F Offline
                      Which version of Sketchup? Your profile says SU2016.
                      • Mousa_SAM Offline
                        Mousa_SA
                        That occur on SketchUp 2018 and SketchUp 2017, I didn't test it on 2016.
                        • fredo6F Offline
                          I know there is this random bugsplat, but I am unable to reproduce it in my own environment.
                          If you have it, could you send a report to Sketchup in the bugsplat window, note the bugsplat record number and post or send this crash number to me.
                          • Mousa_SAM Offline
                            Mousa_SA
                            I thought this update has a fix for these random bugsplat. The Bugsplat record number is #37782
                            I have sent the bugsplat report to you as a PM.
                            • fredo6F Offline
                              NEW RELEASE: FredoTools v3.2c - 12 Mar 18
                              FredoTools 3.2c fixes a major bug in the calculation of volume in SolidVolume
                                rv1974
                                Fredo, in this particular model reverse\ orient tool fails to exit with savedresult. could you take a look? Thanks!
                                kkk.rar
                                • fredo6F Offline
                                  I tried on your model but AutoOrientFaces does the job and performs correctly the reversing.
                                  The issue with your model is that each of the 12 subgroups have a quite large number of faces. In particular the two wheels which have 3,218 faces. The whole model would probably need a rework, because the number of faces seems oversized for a rather boxy shape.
                                  I would probably need to optimize the algorithm. The white screen is just when processing the two wheels.
                                  • JQLJ Offline
                                    JQL
                                    Hi Fredo,
                                    I've noticed that your tools don't follow the convention for selecting a surface with a single click.
                                    The selection method is assuming two or more faces connected by a hidden edge to be a surface, while sketchup convention assumes a surface to be at least two faces connected by a soft edge.
                                    Is this by design?
                                    Thanks,
                                    João
                                    www.casca.pt
                                    Visit us on facebook!
                                    • fredo6F Offline
                                      @jql said:
                                      Hi Fredo,
                                      Is this by design?
                                      Thanks,
                                      João
                                      In general I assume that if you don't see the edge on the screen, the bounding faces are part of the same click-selection. When Geometry Hidden is turned on, then faces behave as separate.
                                      This may not be what the user wants in some occasions; this is why I also have explicit options with palette buttons.
                                      Which tool of FredoTools are you referring to ?
                                      • JQLJ Offline
                                        JQL
                                        I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
                                        I often require the use of surfaces and treat them as such in Sketchup. But for JPP, reverse/orient faces, or thrupaint, I often had problems and didn't understand why. So I started selectin the surfaces first, with regular sketchup selection tool. So I only recently found out what was happening...
                                        www.casca.pt
                                        • fredo6F Offline
                                          Is this now as you expect?
                                          • Rich O BrienR Online
                                            Fredo,
                                            Is it possible to add Cast Shadows On/Off to the Face Triangulator tool?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 23
                                            • 24
                                            • 15 / 24
