    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Instead of save, SU asking for "Save AS",
    8 Posts 3 Posters 4.1k Views 3 Watching
    • I Offline
      iamraj
      New to Sketchup.
      1. I need help as whenever i try to save any of my SU file, the "save AS" dialogue box appears and then 2nd diaologue box appears which says "File not found, Check the file name and try again".
        https://imgur.com/a/M7nvr
      Simultaneously
      2) i am having similar un-resolved issue to this (https://forums.sketchup.com/t/cfileexception-2-when-trying-to-save-in-sketchup/1457)when i open my previous file and try to save them.
      What system variable kind of setting i need to check?
      SU 2017. V-Ray 3.4.
      Windows 10 64 bit OS.
      System Intel i3,
      4GB RAM, 1TB HDD.
      Redone Graphic Card.
      (No data plan on Desktop).
      • pbacotP Offline
        Doesn't sound to me like a SketchUp setting issue. Does this happen repeatedly? Moving a file to a different directory might cause this, but that would only be once....
          This sounds to me as if you've not installed SketchUp correctly. Try repairing the installation by finding the installer exe file, right clicking on it and selecting Run as administrator. Then choose the Repair option. Of course before doing this you need to quit SketchUp so it isn't running on your machine.
          • I Offline
            iamraj
            Yes! it is happening repeatedly, not a single file i could save after reformatting and installing SU again.
            SU 2017. V-Ray 3.4.
            System Intel i3,
            4GB RAM, 1TB HDD.
            • I Offline
              iamraj
              Actually my window was unaccessible so i forced to format it and reinstalled SU (as an admin) then after realizing the issue i reinstalled SU again but the problem still persist. Before this formatting, SU was working well withouot any issue.
              i'll take extrra precaution to follow your steps and let you know here.
              SU 2017. V-Ray 3.4.
              System Intel i3,
              4GB RAM, 1TB HDD.
              • I Offline
                iamraj
                i reinstalled it 3rd & 4th time by deleting all the files from C drive but no luck ๐Ÿ˜ž
                SU 2017. V-Ray 3.4.
                System Intel i3,
                4GB RAM, 1TB HDD.
                • I Offline
                  iamraj
                  i got formatted the machine's C drive again, and re-installed it, the problem still persist.
                  i installed earlier version as well, but result is the same.
                  SU 2017. V-Ray 3.4.
                  System Intel i3,
                  4GB RAM, 1TB HDD.
                  • I Offline
                    iamraj
                    Update: It got corrected by itself, I don't know how; might be Windows 10 update.
                    Thanks for your support
                    SU 2017. V-Ray 3.4.
                    System Intel i3,
                    4GB RAM, 1TB HDD.
