    3D Truss Models
    1.5k Posts 31 Posters 976.9k Views 30 Watching
    • medeekM Offline
      medeek
      I've been thinking about adding in the option to show H1 ties for rafters and trusses:
      https://embed.widencdn.net/img/ssttoolbox/ztwjogo5os/500px@1x/H1 (inst).jpeg?quality=80&u=cjmyin&crop=0
      I've seen them mounted both on the exterior and the interior with the flanges facing both inward and outward, four possible configurations. Any preference on how these are typically installed. I'm sure there is probably not much call for these but it isn't a big deal to add in the option for those that would like to use it.
      I am currently featuring Simpson Strong-Tie hardware in the Truss Plugin, not because I am specifically endorsing their products or the brand but because that is what I am most familiar with and their products are readily available in the US and Canada. Mitek also makes comparable hardware and probably has better availability outside of the US and Canada.
      I'm also thinking about allowing the user to choose between and H1 or H2.5A:
      https://images-na.ssl-images-amazon.com/images/I/41Q4wRZDHEL._SX385_.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've had a number of new and existing clients who are running SU2018 on MacOS who are reporting that they are unable to save global settings for the plugin. The problem is that no one is seeing any errors generated in the ruby console so I am currently at a loss on the exact problem and how to solve it.
        Has anyone seen a similar issue and have been able to resolve it?
        The code to write the global settings is very simple, an example below:
        # Writes Materialsoption Setting
        @Materialsoption_write_result = Sketchup.write_default "MEDEEK_TRUSS_PLUGIN", "MATERIALS_OPTION", @Materialsoption_new
        Why would this stop working on SU2018 running on MacOS?
        design.medeek.com
        • medeekM Offline
          medeek
          Per the discussion in my previous post, I've shown two H1 Clips both attached to the exterior of the wall. One is oriented with the flanges inward and the other with the flanges outward. Notice the placement of the bird blocking next to the clips. My question is what is the preferred orientation of the H1 clip?
          H1 Clips
          Model can be viewed here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          Based on my discussion with other engineers and architects so far it would seem that the best placement of the clips is on the exterior of the wall as shown.
          design.medeek.com
          • medeekM Offline
            medeek
            Testing out the H1, H2.5A and H10A hurricane clips:
            http://design.medeek.com/resources/images/truss_su327_800.jpg
            The plugin is now able to insert hurricane ties. I've currently set it up so that they are installed on the exterior of the framed wall with the flanges inward. Shown below is a Simpson H1 with angled vent blocks.
            Here is an example using the Simpson H10A with vertical heel blocks and a raised heel truss connected to a masonry or concrete wall.
            Ignore the vent holes in the blocking, I will provide additional options for venting in the near future.
            Note that plugin automatically inserts these ties into the truss component, one on each end. The simplified H10A component is based on the official Simpson model found at the 3DWarehouse and is dimensionally accurate but with a much lower polygon count and hence much more lightweight.
            http://design.medeek.com/resources/images/truss_su328_800.jpg
            Here is an example using the Simpson H2.5A hurricane tie. The upper tab is facing outward by default. The tie on the other end of the truss is positioned on the opposite of the truss to this one.
            http://design.medeek.com/resources/images/truss_su329_800.jpg
            I will roll it out for trusses first and then rafter roofs at a later date.
            I've specifically created simplified, lightweight versions of the hardware, so that the polygon count is minimal. With so many components I think it is imperative that the model is carefully constructed so as to minimize its polygon count and keep it as lightweight as possible.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.1.3 - 12.31.2017
              • Enabled hurricane ties for fink and howe common trusses.
              design.medeek.com
              • medeekM Offline
                medeek
                Medeek Design Inc. - Medeek Truss Plugin Vendors
                (design.medeek.com)
                List of material suppliers and vendors featured in the Medeek Truss Plugin.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Does anyone have some shop drawings of a dutch gable or half hip roof? I am looking at adding in the truss sets for these two variants.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    The last few days I've been spending some time tightening up the code for the attic truss module. I will be adding in the heel wedge and slider option for raised/energy heels for this truss type as well as bringing it up to speed with other options.
                    If I get ambitious I will also add in gable end trusses and plates.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.1.4 - 01.20.2018
                      • Completed energy/raised heels for attic trusses (2 variants: wedge and slider).
                      • Added floor sheathing and attic gypsum for attic trusses.
                      • Created a separate HTML menu for advanced options of attic trusses.
                      • Enabled gable end trusses for attic trusses.
                      • Hurricane ties enabled for attic trusses.
                      http://design.medeek.com/resources/images/truss_su330_800.jpg
                      The gable end trusses for attic truss sets currently do not have any vertical studs as of yet, however the actual truss component is unique and different from the common attic trusses.
                      I also need to add in some logic for the gable end wall framing which is still absent. I am curious if anyone has experience or examples of this framed out, do you use a single or double top plate? I don't see a reason to use a double top plate in this situation.
                      Naturally the gable end wall may involve some windows or doors so there will be some overlap with the wall plugin, I am still thinking about how best to integrate the two plugins.
                      View model here:
                      3D Warehouse
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Typical application involving an attic truss over a large open space like a garage.
                        View model here:
                        3D Warehouse
                        https://scontent-sea1-1.xx.fbcdn.net/v/t1.0-9/26814594_10214010513444220_3797151775182127747_n.jpg?oh=0967ba8f84edf12f436381e3b4ffc0de&oe=5AD9BA26
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Thinking about attending the SketchUp 3DBasecamp (2018) this year, is anyone else planning on going?
                          https://blog.sketchup.com/article/save-date-3d-basecamp-2018-coming
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Had to take a break from programming for a few days because of family reasons (ie. medical emergencies), sometimes life happens.
                            The break though has let me take a step back and reconsider some of the items on my various "todo" lists.
                            I'm beginning to realize that the plugin has quite a following in locations other than the US so it is imperative that the metric menus are fully up to speed with all of my imperial menus and options. I will be going back through my code and checking all of the metric menus to make sure that they are up-to-date and fully functional.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Bill Allen sent me this model today, and gave me permission to post about it. The structure has the following assemblies:
                              (3) attic trusses
                              (2) common trusses
                              (1) mono pitch truss
                              (1) scissor truss
                              (1) tail bearing truss
                              (3) valley sets
                              (1) gable roof rafter set
                              I was really quite impressed by the complexity of the model and the various roof lines. This model is just one of a number of iterations.
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                A slightly better rendering of the previous roof:
                                design.medeek.com
                                • facerF Offline
                                  facer
                                  Medeek,
                                  Rendering without shadows may give a clearer picture (rendering) of a complex model ๐Ÿ˜„
                                  • medeekM Offline
                                    medeek
                                    I've been thinking about offering training for $25.00 to $30.00 per hour. Basically one-on-one where I utilize a join.me session and share my desktop and have the ability to walk the user through a number of details and scenarios with the plugin.
                                    Do you think there would be any interest in this?
                                    design.medeek.com
                                    • pbacotP Offline
                                      You might find a few pros who want to learn some advanced techniques, maybe help with learning code, and would pay so much. Judging by comments on this site, I gather most people would not pay so much. By "most people" I don't mean all sketchUp users (which is obvious), I'm thinking of those who would be seriously considering your offer.
                                      • medeekM Offline
                                        medeek
                                        I've had an ongoing issue with Mac users who are running SU2018. I still have not determined the underlying cause but when the user enters in their serial number it will not save.
                                        With SU 2018 the .plist file is no longer relevant and I think this may be why the plugin is having problems saving the serial number.
                                        The current workaround is:
                                        For Mac latest OS, you hold down the option key and then click GO menu. The Go Menu displays.
                                        In the Go Menu there is a menu item named โ€œLibraryโ€
                                        Click on Library and the hidden library folder opens.
                                        Then you can access application support, SketchUP2018/Sketchup/Plugins/PrivatePreferences.json.
                                        OpenPrivatePreferences.json in BBEdit, add the license number and replace the word "TRIAL", then save your changes and open SketchUP 2018 and check the plugins license status in the global settings.
                                        I am currently working on a more permanent resolution for this problem.
                                        I sincerely apologize for the inconvenience this has caused some of our Mac users and I hope to role out a resolution with the next version release.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.1.4b - 01.28.2018
                                          • Added a graphical user interface for (metric) advanced options of truss roofs.
                                          design.medeek.com
                                          • facerF Offline
                                            facer
                                            Medeek,
                                            Current version available for download from your site is:
                                            (Version 2.1.4 - 01/20/2018)
                                            Could you please include a few screenshots to give us a heads up on what has been added
                                            to Version 2.1.4b.
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 75
                                            • 76
                                            • 42 / 76
