    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Just some minor bug fixes for 2.1.2b, I will probably address some other minor issues brought to my attention in the next couple of days.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I've been thinking about adding in the option to show H1 ties for rafters and trusses:
        https://embed.widencdn.net/img/ssttoolbox/ztwjogo5os/500px@1x/H1 (inst).jpeg?quality=80&u=cjmyin&crop=0
        I've seen them mounted both on the exterior and the interior with the flanges facing both inward and outward, four possible configurations. Any preference on how these are typically installed. I'm sure there is probably not much call for these but it isn't a big deal to add in the option for those that would like to use it.
        I am currently featuring Simpson Strong-Tie hardware in the Truss Plugin, not because I am specifically endorsing their products or the brand but because that is what I am most familiar with and their products are readily available in the US and Canada. Mitek also makes comparable hardware and probably has better availability outside of the US and Canada.
        I'm also thinking about allowing the user to choose between and H1 or H2.5A:
        https://images-na.ssl-images-amazon.com/images/I/41Q4wRZDHEL._SX385_.jpg
        design.medeek.com
        • medeekM
          medeek
          I've had a number of new and existing clients who are running SU2018 on MacOS who are reporting that they are unable to save global settings for the plugin. The problem is that no one is seeing any errors generated in the ruby console so I am currently at a loss on the exact problem and how to solve it.
          Has anyone seen a similar issue and have been able to resolve it?
          The code to write the global settings is very simple, an example below:
          # Writes Materialsoption Setting
          @Materialsoption_write_result = Sketchup.write_default "MEDEEK_TRUSS_PLUGIN", "MATERIALS_OPTION", @Materialsoption_new
          Why would this stop working on SU2018 running on MacOS?
          design.medeek.com
          • medeekM
            medeek
            Per the discussion in my previous post, I've shown two H1 Clips both attached to the exterior of the wall. One is oriented with the flanges inward and the other with the flanges outward. Notice the placement of the bird blocking next to the clips. My question is what is the preferred orientation of the H1 clip?
            H1 Clips
            Model can be viewed here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            Based on my discussion with other engineers and architects so far it would seem that the best placement of the clips is on the exterior of the wall as shown.
            design.medeek.com
            • medeekM
              medeek
              Testing out the H1, H2.5A and H10A hurricane clips:
              http://design.medeek.com/resources/images/truss_su327_800.jpg
              The plugin is now able to insert hurricane ties. I've currently set it up so that they are installed on the exterior of the framed wall with the flanges inward. Shown below is a Simpson H1 with angled vent blocks.
              Here is an example using the Simpson H10A with vertical heel blocks and a raised heel truss connected to a masonry or concrete wall.
              Ignore the vent holes in the blocking, I will provide additional options for venting in the near future.
              Note that plugin automatically inserts these ties into the truss component, one on each end. The simplified H10A component is based on the official Simpson model found at the 3DWarehouse and is dimensionally accurate but with a much lower polygon count and hence much more lightweight.
              http://design.medeek.com/resources/images/truss_su328_800.jpg
              Here is an example using the Simpson H2.5A hurricane tie. The upper tab is facing outward by default. The tie on the other end of the truss is positioned on the opposite of the truss to this one.
              http://design.medeek.com/resources/images/truss_su329_800.jpg
              I will roll it out for trusses first and then rafter roofs at a later date.
              I've specifically created simplified, lightweight versions of the hardware, so that the polygon count is minimal. With so many components I think it is imperative that the model is carefully constructed so as to minimize its polygon count and keep it as lightweight as possible.
              design.medeek.com
              • medeekM
                medeek
                Version 2.1.3 - 12.31.2017
                • Enabled hurricane ties for fink and howe common trusses.
                design.medeek.com
                • medeekM
                  medeek
                  404 - File or directory not found.
                  (design.medeek.com)
                  List of material suppliers and vendors featured in the Medeek Truss Plugin.
                  design.medeek.com
                  • medeekM
                    medeek
                    Does anyone have some shop drawings of a dutch gable or half hip roof? I am looking at adding in the truss sets for these two variants.
                    design.medeek.com
                    • medeekM
                      medeek
                      The last few days I've been spending some time tightening up the code for the attic truss module. I will be adding in the heel wedge and slider option for raised/energy heels for this truss type as well as bringing it up to speed with other options.
                      If I get ambitious I will also add in gable end trusses and plates.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.1.4 - 01.20.2018
                        • Completed energy/raised heels for attic trusses (2 variants: wedge and slider).
                        • Added floor sheathing and attic gypsum for attic trusses.
                        • Created a separate HTML menu for advanced options of attic trusses.
                        • Enabled gable end trusses for attic trusses.
                        • Hurricane ties enabled for attic trusses.
                        http://design.medeek.com/resources/images/truss_su330_800.jpg
                        The gable end trusses for attic truss sets currently do not have any vertical studs as of yet, however the actual truss component is unique and different from the common attic trusses.
                        I also need to add in some logic for the gable end wall framing which is still absent. I am curious if anyone has experience or examples of this framed out, do you use a single or double top plate? I don't see a reason to use a double top plate in this situation.
                        Naturally the gable end wall may involve some windows or doors so there will be some overlap with the wall plugin, I am still thinking about how best to integrate the two plugins.
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM
                          medeek
                          Typical application involving an attic truss over a large open space like a garage.
                          View model here:
                          3D Warehouse
                          https://scontent-sea1-1.xx.fbcdn.net/v/t1.0-9/26814594_10214010513444220_3797151775182127747_n.jpg?oh=0967ba8f84edf12f436381e3b4ffc0de&oe=5AD9BA26
                          design.medeek.com
                          • medeekM
                            medeek
                            Thinking about attending the SketchUp 3DBasecamp (2018) this year, is anyone else planning on going?
                            https://blog.sketchup.com/article/save-date-3d-basecamp-2018-coming
                            design.medeek.com
                            • medeekM
                              medeek
                              Had to take a break from programming for a few days because of family reasons (ie. medical emergencies), sometimes life happens.
                              The break though has let me take a step back and reconsider some of the items on my various "todo" lists.
                              I'm beginning to realize that the plugin has quite a following in locations other than the US so it is imperative that the metric menus are fully up to speed with all of my imperial menus and options. I will be going back through my code and checking all of the metric menus to make sure that they are up-to-date and fully functional.
                              design.medeek.com
                              • medeekM
                                medeek
                                Bill Allen sent me this model today, and gave me permission to post about it. The structure has the following assemblies:
                                (3) attic trusses
                                (2) common trusses
                                (1) mono pitch truss
                                (1) scissor truss
                                (1) tail bearing truss
                                (3) valley sets
                                (1) gable roof rafter set
                                I was really quite impressed by the complexity of the model and the various roof lines. This model is just one of a number of iterations.
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM
                                  medeek
                                  A slightly better rendering of the previous roof:
                                  design.medeek.com
                                  • facerF
                                    facer
                                    Medeek,
                                    Rendering without shadows may give a clearer picture (rendering) of a complex model 😄
                                    • medeekM
                                      medeek
                                      I've been thinking about offering training for $25.00 to $30.00 per hour. Basically one-on-one where I utilize a join.me session and share my desktop and have the ability to walk the user through a number of details and scenarios with the plugin.
                                      Do you think there would be any interest in this?
                                      design.medeek.com
                                      • pbacotP
                                        You might find a few pros who want to learn some advanced techniques, maybe help with learning code, and would pay so much. Judging by comments on this site, I gather most people would not pay so much. By "most people" I don't mean all sketchUp users (which is obvious), I'm thinking of those who would be seriously considering your offer.
                                        • medeekM
                                          medeek
                                          I've had an ongoing issue with Mac users who are running SU2018. I still have not determined the underlying cause but when the user enters in their serial number it will not save.
                                          With SU 2018 the .plist file is no longer relevant and I think this may be why the plugin is having problems saving the serial number.
                                          The current workaround is:
                                          For Mac latest OS, you hold down the option key and then click GO menu. The Go Menu displays.
                                          In the Go Menu there is a menu item named “Library”
                                          Click on Library and the hidden library folder opens.
                                          Then you can access application support, SketchUP2018/Sketchup/Plugins/PrivatePreferences.json.
                                          OpenPrivatePreferences.json in BBEdit, add the license number and replace the word "TRIAL", then save your changes and open SketchUP 2018 and check the plugins license status in the global settings.
                                          I am currently working on a more permanent resolution for this problem.
                                          I sincerely apologize for the inconvenience this has caused some of our Mac users and I hope to role out a resolution with the next version release.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.1.4b - 01.28.2018
                                            • Added a graphical user interface for (metric) advanced options of truss roofs.
                                            design.medeek.com
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 76
                                            • 77
                                            • 51 / 77
