    Help with Modelling a Chair
    15 Posts 6 Posters 3.5k Views 6 Watching
      Rick Posthumus
      I'm new to modelling furniture so I'm struggling with this one. I've downloaded Curviloft to help but I'm still not sure what the best way to go about tackling this would be. I've attached a picture of the chair, sorry it's so small - it's the only reference I have. Any tips or suggestions will be appreciated.
        You can also use round corners by Fredo will be sufficient for your models above
        And for more organic furnitures SubD + Vertex Tools By Thomthom and / Or Artisan by Dale Martens
        • alvisA Offline
          alvis
          I would do it so.
          • alvisA Offline
            alvis
            And quick renders
              Rick Posthumus
              Yours looks quite a bit better than mine. Could you give a point form explanation as to how you went about achieving that?
                I second that, would be greatly appreciated. Very impressive πŸ‘
                • alvisA Offline
                  alvis
                  • tuna1957T Online
                    tuna1957
                    alvis , great how to video πŸ‘
                      Secrets of a Master! 😎
                      At the end it's Artisan by Dale Martens who is used for subdivide the model! πŸ€“
                        Rick Posthumus
                        Alvis you're a legend, thanks for your tutorial!
                        Thanks Pilou for your insight as well.
                        • alvisA Offline
                          alvis
                          Cheers!
                            Hi Alvis, i wathed the vid, you are a legend. How did you make the crease (where the 2 parts of the real chair meet) or did I miss somthing?
                              rv1974
                              Alvis, great video!
                              @2.15, why not just JPP (noborders mode) to offset she shell?
                              2nd question: How would you make (KEPENG A GOOD TOPOLOGY)this groove between 2 parts?
                              Could you add this part to the vid?
                              Thanks in advance
                              • alvisA Offline
                                alvis
                                I missed this step. It's a little secret. Just have separated from the back the sitting. And filled the gap . After a little push out.
                                skin contours
                                pushed
                                subdivided
                                • alvisA Offline
                                  alvis
                                  @rv1974 said:
                                  Alvis, great video!
                                  Thanks in advance
                                  Yes It would be a solution to use the JPP. But the toplogy is distorted.
