    3D Truss Models
    1.5k Posts 31 Posters 937.1k Views 30 Watching
    • medeekM Offline
      medeek
      Version 2.1.2 - 12.18.2017
      • Enabled vertical and angled heel blocking within the advanced options for truss roofs.
      http://design.medeek.com/resources/images/truss_su325_800.jpg
      If you choose to enable vent holes the heelblock menu will prompt for the hole diameter. The vent hole algorithm will place vent holes in the heel blocking per the truss spacing:
      < 12 in. = 1 vent hole
      < 16 in. = 2 vent holes
      16 in. or greater = 3 vent holes
      Let me know if this makes sense, I can always modify it to meet any criteria. If this sort of thing varies a lot per locale I can also make it more user definable.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        This type of heel blocking is very typical in my locale (Western Washington State):
        http://design.medeek.com/resources/images/truss_su326_800.jpg
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        design.medeek.com
        • medeekM Offline
          medeek
          To end off the year with a bang and to thank our truss plugin clientele I have decided to reduce the license renewal fee for the Medeek Truss Plugin to $10.00 USD. This promotion will run until the end of this year (Dec. 31, 2017) and then the renewal price will return to its usual price of $20.00 USD.
          This year has been very busy with further developments of the truss and foundation plugins. I am looking forward to the new year and another full year of new features and even new plugins and tools.
          I've really appreciated all those who have actively contributed to the recent developments of the plugin, especially the translations.
          A Merry Christmas to all and a Happy New Year.
          design.medeek.com
            Sorry but a more complete French translation will be at the beginning of the next year : no more free times for the moment! 😞
            Have happy new year! 😎
            • medeekM Offline
              medeek
              Just some minor bug fixes for 2.1.2b, I will probably address some other minor issues brought to my attention in the next couple of days.
              design.medeek.com
              • medeekM Offline
                medeek
                I've been thinking about adding in the option to show H1 ties for rafters and trusses:
                https://embed.widencdn.net/img/ssttoolbox/ztwjogo5os/500px@1x/H1 (inst).jpeg?quality=80&u=cjmyin&crop=0
                I've seen them mounted both on the exterior and the interior with the flanges facing both inward and outward, four possible configurations. Any preference on how these are typically installed. I'm sure there is probably not much call for these but it isn't a big deal to add in the option for those that would like to use it.
                I am currently featuring Simpson Strong-Tie hardware in the Truss Plugin, not because I am specifically endorsing their products or the brand but because that is what I am most familiar with and their products are readily available in the US and Canada. Mitek also makes comparable hardware and probably has better availability outside of the US and Canada.
                I'm also thinking about allowing the user to choose between and H1 or H2.5A:
                https://images-na.ssl-images-amazon.com/images/I/41Q4wRZDHEL._SX385_.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  I've had a number of new and existing clients who are running SU2018 on MacOS who are reporting that they are unable to save global settings for the plugin. The problem is that no one is seeing any errors generated in the ruby console so I am currently at a loss on the exact problem and how to solve it.
                  Has anyone seen a similar issue and have been able to resolve it?
                  The code to write the global settings is very simple, an example below:
                  # Writes Materialsoption Setting
                  @Materialsoption_write_result = Sketchup.write_default "MEDEEK_TRUSS_PLUGIN", "MATERIALS_OPTION", @Materialsoption_new
                  Why would this stop working on SU2018 running on MacOS?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Per the discussion in my previous post, I've shown two H1 Clips both attached to the exterior of the wall. One is oriented with the flanges inward and the other with the flanges outward. Notice the placement of the bird blocking next to the clips. My question is what is the preferred orientation of the H1 clip?
                    H1 Clips
                    Model can be viewed here:
                    3D Warehouse
                    Based on my discussion with other engineers and architects so far it would seem that the best placement of the clips is on the exterior of the wall as shown.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Testing out the H1, H2.5A and H10A hurricane clips:
                      http://design.medeek.com/resources/images/truss_su327_800.jpg
                      The plugin is now able to insert hurricane ties. I've currently set it up so that they are installed on the exterior of the framed wall with the flanges inward. Shown below is a Simpson H1 with angled vent blocks.
                      Here is an example using the Simpson H10A with vertical heel blocks and a raised heel truss connected to a masonry or concrete wall.
                      Ignore the vent holes in the blocking, I will provide additional options for venting in the near future.
                      Note that plugin automatically inserts these ties into the truss component, one on each end. The simplified H10A component is based on the official Simpson model found at the 3DWarehouse and is dimensionally accurate but with a much lower polygon count and hence much more lightweight.
                      http://design.medeek.com/resources/images/truss_su328_800.jpg
                      Here is an example using the Simpson H2.5A hurricane tie. The upper tab is facing outward by default. The tie on the other end of the truss is positioned on the opposite of the truss to this one.
                      http://design.medeek.com/resources/images/truss_su329_800.jpg
                      I will roll it out for trusses first and then rafter roofs at a later date.
                      I've specifically created simplified, lightweight versions of the hardware, so that the polygon count is minimal. With so many components I think it is imperative that the model is carefully constructed so as to minimize its polygon count and keep it as lightweight as possible.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.1.3 - 12.31.2017
                        • Enabled hurricane ties for fink and howe common trusses.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Medeek Design Inc. - Medeek Truss Plugin Vendors
                          (design.medeek.com)
                          List of material suppliers and vendors featured in the Medeek Truss Plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Does anyone have some shop drawings of a dutch gable or half hip roof? I am looking at adding in the truss sets for these two variants.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              The last few days I've been spending some time tightening up the code for the attic truss module. I will be adding in the heel wedge and slider option for raised/energy heels for this truss type as well as bringing it up to speed with other options.
                              If I get ambitious I will also add in gable end trusses and plates.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.1.4 - 01.20.2018
                                • Completed energy/raised heels for attic trusses (2 variants: wedge and slider).
                                • Added floor sheathing and attic gypsum for attic trusses.
                                • Created a separate HTML menu for advanced options of attic trusses.
                                • Enabled gable end trusses for attic trusses.
                                • Hurricane ties enabled for attic trusses.
                                http://design.medeek.com/resources/images/truss_su330_800.jpg
                                The gable end trusses for attic truss sets currently do not have any vertical studs as of yet, however the actual truss component is unique and different from the common attic trusses.
                                I also need to add in some logic for the gable end wall framing which is still absent. I am curious if anyone has experience or examples of this framed out, do you use a single or double top plate? I don't see a reason to use a double top plate in this situation.
                                Naturally the gable end wall may involve some windows or doors so there will be some overlap with the wall plugin, I am still thinking about how best to integrate the two plugins.
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Typical application involving an attic truss over a large open space like a garage.
                                  View model here:
                                  3D Warehouse
                                  https://scontent-sea1-1.xx.fbcdn.net/v/t1.0-9/26814594_10214010513444220_3797151775182127747_n.jpg?oh=0967ba8f84edf12f436381e3b4ffc0de&oe=5AD9BA26
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Thinking about attending the SketchUp 3DBasecamp (2018) this year, is anyone else planning on going?
                                    https://blog.sketchup.com/article/save-date-3d-basecamp-2018-coming
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Had to take a break from programming for a few days because of family reasons (ie. medical emergencies), sometimes life happens.
                                      The break though has let me take a step back and reconsider some of the items on my various "todo" lists.
                                      I'm beginning to realize that the plugin has quite a following in locations other than the US so it is imperative that the metric menus are fully up to speed with all of my imperial menus and options. I will be going back through my code and checking all of the metric menus to make sure that they are up-to-date and fully functional.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Bill Allen sent me this model today, and gave me permission to post about it. The structure has the following assemblies:
                                        (3) attic trusses
                                        (2) common trusses
                                        (1) mono pitch truss
                                        (1) scissor truss
                                        (1) tail bearing truss
                                        (3) valley sets
                                        (1) gable roof rafter set
                                        I was really quite impressed by the complexity of the model and the various roof lines. This model is just one of a number of iterations.
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          A slightly better rendering of the previous roof:
                                          design.medeek.com
                                          • facerF Offline
                                            facer
                                            Medeek,
                                            Rendering without shadows may give a clearer picture (rendering) of a complex model πŸ˜„
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 72 / 76
