    Ctrl S Deletes Text?
    9 Posts 2 Posters 959 Views 2 Watching
    • Joe WoodJ Offline
      Joe Wood
      This is weird, when I do a Crtl + S, it deletes some of the text on the right?
      using SUp 2015
      Joe Wood
      woodsshop.com/
        Could you try to reinstall SketchUp v2015 ?
        If you have the original installer's exe file in your Downloads folder, then try this...
        Close SketchUp [v2015] and find the v2015 installer's exe file.
        Select it and Right-click > Context-menu > "Run as administrator..."
        When prompted choose "Repair"
        Restart SketchUp any improvement ?
        This is an off the wall idea, but incorrect installations are well known to result in all sorts of unexpected and weird issues............
        • Joe WoodJ Offline
          Joe Wood
          I've been having other weird things going on too. Darn don't have the installation file ..
          Joe Wood
          woodsshop.com/
            Perhaps one of these installer-links here ?
            https://help.sketchup.com/en/article/60107
            • Joe WoodJ Offline
              Joe Wood
              seems so drastic, re installing!
              you know what, I ran Wise Care https://www.wisecleaner.com/wise-care-365.html two days ago, for the first time, could that have messed something up because I'm also seeing image exports take way too long?
              Joe Wood
              woodsshop.com/
                If you to 'run the installer as admin', then choose 'Repair', it simply sets up SketchUp properly.
                All of your shortcuts, installed Plugins etc should NOT be affected...
                Trust me πŸ˜‰
                • Joe WoodJ Offline
                  Joe Wood
                  I should probably end task for those three SUp processes in task manager?
                  Joe Wood
                  woodsshop.com/
                    I recommend that you have NO 'SketchUp' related processes running when you try a re-install...
                    • Joe WoodJ Offline
                      Joe Wood
                      Thanks for the hand holding Tig πŸ™‚ Repair sounded a lot better then re install!
                      Looks like it helped, exporting is back to how it should be but those measurements are gone, but the problem is probably fixed!
                      Joe Wood
                      woodsshop.com/
