    Hidden lines not visible in Layout
    layout
    24 Posts 5 Posters 10.9k Views 5 Watching
    • pbacotP
      Wow. Great help! Dave's ended up writing a full article.
        dpressm
        Unbelievably great answer. I shall read it multiple times to make sure I get it all.
          Thank you, gentlemen.
          • P
            pipingguy
            I'm a little confused. How can two different styles exist on one skp screen? Or is it a LO screencap with two overlapping VP's with each having different styles? The axis lines makes me think the former.
              Are you referring to the different appearance between the assembled model in the foreground and the exploded one on the background? Or are you talking about the different appearance in the screen shot with the axes visible and the one without?
              If it's the former, there's only one style being displayed; Hidden Line with Back Edges turned on. Theres a large surface between the two copies of the model so when rendered as Vector in LO, the components in the rear are not visible.
              • P
                pipingguy
                see below.........
                  As I said, that's the view in the SketchUp file. There is only one style being displayed. It isn't possible to show more than one style in a single scene in SketchUp.
                  • P
                    pipingguy
                    I agree. So how are two different styles being displayed? What am I not comprehending?
                      What two different styles? There's only one style shown in that screen shot; Hidden Line with Back Edges turned on.
                      I can't figure out how to make it any more clear.
                      • C
                        Charlie__V
                        I think the exploded view “beyond” is what is a bit confusing? (Perceived 2 “styles”)
                        C
                          C
                          As I already wrote, though...
                          @dave r said:
                          there's only one style being displayed; Hidden Line with Back Edges turned on. There's a large surface between the two copies of the model so when rendered as Vector in LO, the components in the rear are not visible.
                          Maybe this will make it clearer?
                          • P
                            pipingguy
                            OK Dave....now I understand what's going on. At first, I thought the foreground object had a style that shows both solid and dashed lines, and the other one had a style with dashed lines only - although I am not aware of any such style. But your opaque screen is what gives the effect to the latter - not a separate style. This post piqued my interest because it just so happens I had to generate a CD for a steel angle iron frame a few days ago. But I became frustrated at not being able to find a style/render combo to clearly display dashed line back edges. Raster/back edges works, but gives a fuzzy result. And as was mentioned in the post, dashed lines need to be manually traced onto the canvas with LO's line tool. Not something I care to do since several modifications to the object's design often take place which requires time-consuming manual re-tracing updates in LO.
                              Remember, when you are looking at the Raster-rendered viewports on screen, you are probably using less than the maximum quality rendering. When you export to PDF, you can export at the high quality setting.
                              Another thing to consider is stacking viewports for the same scene. You can render the top one as Vector and leave the bottom one as Raster. That will give you a combination of vector edges with only the back edges displayed as raster and it will allow you to maintain the dynamic link from the scenes so changes will show up automatically (as long as you don't make them modified in LO).
                              don't stack the viewports on the same layer. Rather use two layers with the upper layer showing the vector rendered viewports.
                              • 2 / 2
