    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 458.6k Views 70 Watching
      Garry K
      Antonis - Please email me at gkernan@telus.net and I will be happy to help.
        Garry K
        You can now adjust pullout width and position using hinge allowance. The red arrows are showing the extra clearance for hinges.
          Garry K
          Here is an example of the new drawer system where you can specify at the project level a system for drawers and pullouts
          You will be able to (very soon) add finished fronts to pullouts
            Garry K
            I'm pleased to announce a major CabMaker release version 3.0.102 in conjunction with a major release for CutMaster 3.0.1.60.
            This includes the Drawer / Pullout subsystem. I now support Blum metabox, Grass, Zargen, DynaPro etc.
            You may have choose a Drawer system at the Project level or override it at on a per cabinet basis. You can also choose a Pullout system at the Project level and it does not have to be the same system as Drawers.
            Here is the template for the Metabox
            And here it is for the Zargen
              Garry K
              The new release also has many smaller features such as edging more or less of the RAW exposed edges.
              The Skins entry area controls how much of the cabinet is edged.
              These settings give you a cabinet with as little extra edging as possible allowing you to control costs.
              You can edge just the top of the side panels and if you want you can edge the top edge of the hanger (nailer strip)
              Here is the backside of the cabinet with the same settings.
              In high humidity areas you may need to edge all exposed raw edges which will seal them against panel swelling caused by wicking.
                Garry K
                CutMaster reads in all the parts including edging information and adjusts the part dimensions based on the thickness of the edging. All drilling and grooving details automatically compensate.
                The top door has 3mm edging on all 4 edges.
                The bottom door is full size (edging thickness set to 0)
                  Garry K
                  CabMaker 3.0.102 is now available in 2 flavors. CabMaker Design (formally Pro) and CabMaker Build (formally Gold)
                  Version 3.0.102 – Dec 9, 2017
                  1. Changed CabMaker Pro to CabMaker Design and CabMaker Gold to CabMaker Build.
                  2. There is a new Drawers Tab for the new Drawer / Pullout Sub System.
                  3. Updated reports to provide CutMaster with information for new Drawer / Pullout Sub
                    System.
                  4. Added ā€œEdge Exposed Edgesā€.
                  5. Now including Jquery within cabmaker. CabMaker is no longer going to the internet
                    every time.
                  6. Fixed Integrated kicks when dadoing Sides for Fixed Shelves.
                  CutMaster 3.0.1.60 is now available in 2 flavors. CutMaster Plan (formally Pro) and CutMaster CNC (formally Gold)
                  Version 3.0.1.60 Dec 9, 2017
                  1. Modified the layout of Options.
                  2. You can now have multiple Drawer / Pullout Subsystems.
                  3. Added more parameters to allow configuration of Zargen, Metabox etc.
                    abdalmalki
                    What about DxfConfig ?
                      Garry K
                      I haven't had anyone requesting updates to dxfconfig. I think it has outlived its usefulness. Since Cutmaster is now showing immediate changes to drilling and grooving options it is now in the work flow.
                      Create 1 cabinet. Click reports. CutMaster Pops up, import and optimize. Then go into CNC options and play around. You can now save your choice and see the results immediately on screen.
                      You can also now click on a part and everything is synchronized. Right click on part and choose CAD and view the DXF (after you have clicked DXF button)
                        Garry K
                        Prior to CabMaker 3 CabMaker was going to googleapis for the JQuery library. Earlier Windows would just cache it and wouldn't have to make an internet call - just once - the very first time. With many Windows security updates Windows no longer caches the library. This meant the CabMaker would make a call out to the internet EVERY time the dialog box opened.
                        With CabMaker 3 the Jquery is shipped with the install and now NEVER needs to grab the library over the internet.
                          Garry K
                          I am looking into an alternative licensing strategy which will include a hardware dongle. Please provide me with feedback on what you think of this option.
                          It will allow you to run CabMaker on as many computers as you want - providing that the dongle is connected to the computer.
                          This strategy means you will never have to connect to the internet.
                            abdalmalki
                            I strongly support this option.
                            Your software will become more reliable for cabinet making business.
                              Garry K
                              I am also considering creating an install package (Windows only) that will correctly install CabMaker without the bad side effects of the Extension Manager.
                              Download cabmaker 3 installation package
                              Right Click and choose "Run as Administrator"
                              Choose which version of Sketchup that you want it installed in SU 2016, SU 2017 or SU 2018 and it installs and preserves your previous templates.
                                Miked12
                                I hate the dongle option, I make it a point to never own software with this option...I think this would be a step backwards for an otherwise great plugin...just my point of view
                                  joewood
                                  I agree. I couldn't say it any better.
                                  .... joe
                                    Garry K
                                    Sorry I wasn't completely clear. I am simply offering the Dongle as a second OPTION. Users that choose not to have the Dongle will continue with once a week license authentication over the internet.
                                    However there are users in parts of the world who have very poor internet connections. It is this group of users that the Dongle is targeting.
                                      bwoh21
                                      Dear,
                                      I have tried to use trial version.
                                      At first I met to message below;
                                      "undefined method 'each_pair' for nil:NiClass"
                                      How can I solve this problem?
                                        Garry K
                                        Essentially some panel is ending up with 0 width or 0 height. Please rub Ruby Console before trying to create a cabinet and then email me directly with the information that is in the Ruby Console. It will give us an indication to where the problem is.
                                        gkernan@telus.net
                                        • N Offline
                                          NBG
                                          HEllo,
                                          I'm a cabinet maker and a newbie regarding this plugin, but I've spent several hours on it to try to see if it could work for me. So I already have 2 questions:
                                          1. IS there a way to prevent modifications to "disappear" when i update something with the edit windows? I know I should try to use the edit tools as much as possible, but I guess it is not always doable. For example, I did this with a tall cabinet. I looked for a while and I think this is not doable in edit mode.
                                          but now, if i open the edit mode to change a little thing, it will re-asign the cabinet type template and my vertical divider will be back in the center, from bottom to top, my shelves shortened to havf the cabinet and my larger fixed shelve (that i copied from the top) will disappear. I started with a tall cabinet with a "left closet" type.
                                          And now I want to move one of my handle (heigth). But when i see how this is handled by the plugin, it seems to me I'll have the same problem.
                                          1. Is there a way to make real flush back? I did it selecting "back dado: 18mm", "slide in" and "extend back upper". But maybe there is another way? It is not perfect, because doing it my way the sides will be to deep. The plugin consider that I will make a groove, but I wont.
                                          best regards,
                                            Garry K
                                            Let's first set up a plant on back. The solution is to set the back offset to 0 and to set the dado depth to the same value as the thickness of the sides.
                                            Here I have 19 mm sides and a 12 mm back.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
