    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.4k Views 71 Watching
    • G
      Garry K
      Currently with adjustable shelves if you want 6 inch space between shelves and you are using 3/4 inch material then you would enter 5 for number of shelves and 6 3/4 inches for the first position. Leave the rest of the spaces at 0. CabMaker will then position all shelves with 6 inches of space between them.
      • G
        Garry K
        What I think I'm hearing is that users would like to control the space between the shelves.
        With first cabinet the user types in 6 and cabmaker calculates the spacing and positions the shelves evenly within the opening.
        With the second cabinet the user types in 6 and types in 6 inches in the first positional spot and cabmaker spaces places each shelf so that there is 6 inches between shelves.
        With the third cabinet the user types in 6 and then 12 inches in the first positional spot and 6 inches in the second. CabMaker then places the first shelf with a 12 inch space and all the rest with a 6 inch space.
        • G
          Garry K
          CabMaker version 2.0.98 is now available for download
          1. Added Fixed count for Fixed shelves
          2. Modified the way fixed shelves and adjustable shelves work. They are not consistent.
          3. Added overrides at the cabinet level for legs.
          4. You can now adjust left and right Finished panels independently.
          5. Added bottom offset for Finished Backs.
          6. You can now control adjustable shelves, fixed shelves and pullouts for Mid section of
            Tall cabinets.
          7. Added an Extend Kicks. You can now choose to have them extende out to the fillers or
            not.
          8. Added Sink Stretchers to materials. You can now create Sink cabinet without drawer
            fronts and independently texture the Sink Stretcher.
          9. Added a rule for edging Sink Stretchers.
          CutMaster version 2.0.1.57 is now available for download
          1. Parts are now clickable
          2. Added CAD support for current parts or nested dxf for Gold version.
          3. Added Auto Depth for drilling.
          4. Added an Edge Banding usage report in Gold version.
          5. Completed Dxf Tall Partition for Tall cabinets in Gold version.
            Antonis777
            Hello, could you please help me? I downloaded cabmaker 2.0.98 trial version for sketchup 2016 and when I try to make a cabinet I get an error ''nil can't be coerced into float''. I don't know how to solve this. Very glad if you helped. Thank you.
              Antonis777
              • G
                Garry K
                Antonis - Please email me at gkernan@telus.net and I will be happy to help.
                • G
                  Garry K
                  You can now adjust pullout width and position using hinge allowance. The red arrows are showing the extra clearance for hinges.
                  • G
                    Garry K
                    Here is an example of the new drawer system where you can specify at the project level a system for drawers and pullouts
                    You will be able to (very soon) add finished fronts to pullouts
                    • G
                      Garry K
                      I'm pleased to announce a major CabMaker release version 3.0.102 in conjunction with a major release for CutMaster 3.0.1.60.
                      This includes the Drawer / Pullout subsystem. I now support Blum metabox, Grass, Zargen, DynaPro etc.
                      You may have choose a Drawer system at the Project level or override it at on a per cabinet basis. You can also choose a Pullout system at the Project level and it does not have to be the same system as Drawers.
                      Here is the template for the Metabox
                      And here it is for the Zargen
                      • G
                        Garry K
                        The new release also has many smaller features such as edging more or less of the RAW exposed edges.
                        The Skins entry area controls how much of the cabinet is edged.
                        These settings give you a cabinet with as little extra edging as possible allowing you to control costs.
                        You can edge just the top of the side panels and if you want you can edge the top edge of the hanger (nailer strip)
                        Here is the backside of the cabinet with the same settings.
                        In high humidity areas you may need to edge all exposed raw edges which will seal them against panel swelling caused by wicking.
                        • G
                          Garry K
                          CutMaster reads in all the parts including edging information and adjusts the part dimensions based on the thickness of the edging. All drilling and grooving details automatically compensate.
                          The top door has 3mm edging on all 4 edges.
                          The bottom door is full size (edging thickness set to 0)
                          • G
                            Garry K
                            CabMaker 3.0.102 is now available in 2 flavors. CabMaker Design (formally Pro) and CabMaker Build (formally Gold)
                            Version 3.0.102 – Dec 9, 2017
                            1. Changed CabMaker Pro to CabMaker Design and CabMaker Gold to CabMaker Build.
                            2. There is a new Drawers Tab for the new Drawer / Pullout Sub System.
                            3. Updated reports to provide CutMaster with information for new Drawer / Pullout Sub
                              System.
                            4. Added ā€œEdge Exposed Edgesā€.
                            5. Now including Jquery within cabmaker. CabMaker is no longer going to the internet
                              every time.
                            6. Fixed Integrated kicks when dadoing Sides for Fixed Shelves.
                            CutMaster 3.0.1.60 is now available in 2 flavors. CutMaster Plan (formally Pro) and CutMaster CNC (formally Gold)
                            Version 3.0.1.60 Dec 9, 2017
                            1. Modified the layout of Options.
                            2. You can now have multiple Drawer / Pullout Subsystems.
                            3. Added more parameters to allow configuration of Zargen, Metabox etc.
                              abdalmalki
                              What about DxfConfig ?
                              • G
                                Garry K
                                I haven't had anyone requesting updates to dxfconfig. I think it has outlived its usefulness. Since Cutmaster is now showing immediate changes to drilling and grooving options it is now in the work flow.
                                Create 1 cabinet. Click reports. CutMaster Pops up, import and optimize. Then go into CNC options and play around. You can now save your choice and see the results immediately on screen.
                                You can also now click on a part and everything is synchronized. Right click on part and choose CAD and view the DXF (after you have clicked DXF button)
                                • G
                                  Garry K
                                  Prior to CabMaker 3 CabMaker was going to googleapis for the JQuery library. Earlier Windows would just cache it and wouldn't have to make an internet call - just once - the very first time. With many Windows security updates Windows no longer caches the library. This meant the CabMaker would make a call out to the internet EVERY time the dialog box opened.
                                  With CabMaker 3 the Jquery is shipped with the install and now NEVER needs to grab the library over the internet.
                                  • G
                                    Garry K
                                    I am looking into an alternative licensing strategy which will include a hardware dongle. Please provide me with feedback on what you think of this option.
                                    It will allow you to run CabMaker on as many computers as you want - providing that the dongle is connected to the computer.
                                    This strategy means you will never have to connect to the internet.
                                      abdalmalki
                                      I strongly support this option.
                                      Your software will become more reliable for cabinet making business.
                                      • G
                                        Garry K
                                        I am also considering creating an install package (Windows only) that will correctly install CabMaker without the bad side effects of the Extension Manager.
                                        Download cabmaker 3 installation package
                                        Right Click and choose "Run as Administrator"
                                        Choose which version of Sketchup that you want it installed in SU 2016, SU 2017 or SU 2018 and it installs and preserves your previous templates.
                                          Miked12
                                          I hate the dongle option, I make it a point to never own software with this option...I think this would be a step backwards for an otherwise great plugin...just my point of view
                                            joewood
                                            I agree. I couldn't say it any better.
                                            .... joe
                                            With your input, this post could be even better šŸ’—
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 31
                                            • 32
                                            • 22 / 32
