    Importing pages from different Layout files
    layout
    17 Posts 3 Posters 5.4k Views 3 Watching
      CJRyan
      @pbacot said:
      I guess it's not clear to me what you are trying to do or what you would copy or paste. On the Mac anyway, you can open another layout file you can copy a scene from one LO file and paste it to another (how does this help your problem) or you can make a copy of the layout file and modify that choosing a new scene. You can have both open at the same time.
      Also not sure why you are seeing such a slow down during porting scenes to LO. For working in LO you can set the SU model quality in LO to low under Preferences / Paper / Rendering Resolution / Display resolution
      pbacot,
      Sorry, I wasn't clear, let me rethink my problem and repost it.
      I'm not saying it isn't there in the windows version of SU, but I'll be darned if I can find "Preferences / Paper / Rendering Resolution / Display resolution" in Layout 2017.
        @cjryan said:
        However, my question was “Are there native leaders in Layout that I’m not aware of?”
        What are "native leaders"?
        @cjryan said:
        As a novice using Layout, I find it quirky. This is why I posted the question.
        Learning a few very important basics and applying them will help with that.
        @cjryan said:
        I would be happy to sent you the file, perhaps that would give me more insight as to why it updates/renders so slowly.
        I figured seeing your file would help give you some ideas about the rendering time as well as help you with those basics. You can upload the LO file here or, if you prefer not sharing it publicly, you can send it to me in a private message. If it's too large to upload here, you canupload it to Drop Box and share the link to the folder its in.
        For Paper size and rendering quality settings, look in File>Document SetUp>Paper.
        • pbacotP Offline
          Often referred to as chiefs.
          Sorry yes it's not "Preferences" it's "Document Setup". Wrong window.
            I just blew alfredo sauce out my nose!
              CJRyan
              Thanks Dave,
              The file is rather large, 40 MB.
              There are lots of clipping masks to show detail. I think that's why the file is so large and slow.
              After playing with the clipping masks, it would seem that each in still contains an entire scene. So, on some of my pages, I have five copies of one scene
              People like Geronimo, Victorio, Bull Chief to name a few. But I meant just a leader other than "Tag".
              I've read through Matt Donley's SketchUp to Layout several times, as well as most of "Creating Documents in Layout" on the SketchUp Help Center.
              With the help of those two sources, I've usually managed to get what I needed to do done.
              Thank you for directing me to the paper size settings. Mine seem to be correct.
              I've uploaded this to Dropbox. This is the link (I think anyway).
              https://www.dropbox.com/s/6y1r3o5wc7kmoc2/Manual%202.layout?dl=0
              Thank you, Dave, for taking the time to look at it.
                CJRyan
                You beat me to that one!
                I had Daves post open since this morning, trying to decide what to say.
                No problem on the wrong window, I figured it was a Mac thing.
                  Just heading out for some dinner. I've started the download and will look at it when I get back.
                    CJRyan
                    Enjoy!
                      Thanks.
                      Ok. so I've had a quick look at some of your LO file as well as the SketchUp file. The model looks interesting and complex.
                      One key thing I noticed in your LO file that is almost always problem causing is that the viewports all show their scenes as modified. This effectively breaks the link to the scenes in SketchUp which means scene specific changes you make in the SketchUp file won't be reflected in the viewports. Best practice is to avoid making them modified.
                      It's OK to have more than one viewport on a page containing the same scene. Just don't make them modified. Resizing viewports and adding clipping masks do not make them show as modified in the scenes list.
                      As for the labels, I'm not seeing "Tag" so I'm not sure what that means. You don't have to use the Auto text function when you create them. If you start typing while the initial text is highlighted, LO won't attempt to highlight the label to be reconnected later.
                      I would strongly suggest that you use layers in LO for the different types of entities.This is the layers stack for a typical project I do in SketchUp. I have two layers for model viewports here but I often have several more for stacked viewports.
                      Although I mentioned it earlier, please do take the time when you are modeling to give your components useful names. If you're going to use groups I would suggest giving them names, too. That'll make the Outliner more useful as well as allow you to make use of auto text for labels. When you have a whole bunch of different things with the same name, a tool like Outliner is nearly useless.
                      There's some stuff I would do differently regarding nesting of components and groups such as reduce the amount of nesting. I would also suggest that you don't nest loose geometry along with groups and/or components because this can case issues when editing your model. It also makes it difficult to create accurate reports if you want to take advantage of that sort of thing.
                      Keep plugging away. You'll get the hang of it.
                        CJRyan
                        Thanks Dave.
                        A few follow up questions.
                        “One key thing I noticed in … that the viewports all show their scenes as modified.”
                        I’ve noticed that in many of the LO files I’ve done. It is not intentional; I’ve tried to be very careful not to change the perspective in the view port. I have however had to zoom and pan to get the model “centered” in the view port. Am I doing this backwards? Should I be moving the viewport to the model? No matter how carefully I positon my scenes in SU, they never come in in the view port centered.
                        “If you start typing while the initial text is highlighted, LO won't attempt to highlight the label to be reconnected later.”
                        Thank you for clarifying that, believe me, I looked for that answer before I asked.
                        “I would strongly suggest that you use layers”
                        “…take the time when you are modeling to give your components useful names.”
                        I completely agree! But some of the things I was modeling I didn’t even know what I was going to call them, until after they were done, lol.
                        “There's some stuff I would do differently regarding nesting of components and groups such as reduce the amount of nesting. I would also suggest that you don't nest loose geometry along with groups…”
                        Points well taken!
                        One last thing, my original question was can I work in two different layout files, a “slim” one with just the page I’m working on and then export/copy/paste it into the final document? I’ve been afraid to try this for fear it will corrupt my final copy.
                        Thank you Dave.
                        “The model looks interesting and complex.” Thank you I take that as a complement.
                        No one asked me in advance for advice as to what I might need to pull this off. I was shown a “hole in a concrete wall and informed “make it as thin as possible” now do it!
                          Not backwards, just incorrectly. The easiest thing would be to create scenes in SU that show exactly what you want to show in the viewport but that can get to involve a large number of scenes. You can change the cropping and size of the viewport by simply dragging the edges or corners of the viewport. Drag the corner to make a larger viewport which also enlarges the model view on the page. When you have it large enough tick the box for Preserve Scale on Resize in the SketchUp Model inspector window. Then you can drag the sides of the viewport to crop the view as needed. This procedure effectively gives you zoom and pan control without creating a modified scene.
                          Just don't double click on the viewport as that will cause it to be modified. If you need to change the camera's position by orbiting, do that in SU and update the scene or create a new scene.
                          I get that frequently in the furniture pieces I model for plans. I usually guess at a name or wait until I get clarification from my editor. Then I go back and rename the components. It's easy to find the ones that need correcting in the Outliner because they have names like 'Component#4' or 'Thingummy'.
                          It shouldn't but you shouldn't need to do that in the first place. One thing to watch out for is the references to the Sketchup file. If you copy from one LO doc and paste to another one, you will probably get another SKP file reference. If you have multiple references listed that all point at the same SKP file, things can get corrupted. I've seen LO files that were damaged by multiple references to the same SKP file. Better to keep it to a single reference.
                          It was a compliment. Well done.
                            That turned out pretty cool. Thanks for the video clip.
                              CJRyan
                              Thanks again Dave.
                              You've been a great help!
                              Just in case you are curious. As to how the actual project turned out.
                              https://www.dropbox.com/s/mw2mdlwzvdwj4s1/Hidden%20Door%202.mp4?dl=0
                              Now I need to finish my "Owners Manual".
                              Oh, and I'm glad I ended up in the "right" room! 😉
