    [Plugin] jf_get_dimensions.rb
    61 Posts 21 Posters 68.5k Views 21 Watching
    • Z Offline
      Zacchia
      About the Icon: I found out that I muddle up the get dimensions plugin with the resizer plugin from Sahi... this one has Icon...
        bleiente
        @ll: wow ... nice features, but in the old get_dimensions.rb by 'CptanPanic' its possible to get the area in m² and the volume m³.
        area = dims[2].to_m * dims[1].to_m volume = dims[2].to_m * dims[1].to_m * dims[0].to_m
        does anyone put that feature in rb-scripts here?
        sorry for the bad english.
        thx so far and best regards
        a.
          Boiseux
          Original plugin from first post works just fine for me !
          Very, very usefull to rapidly check if everything's OK after resizing, fredoscale, or yust quickly see the dimensions of a particular piece of "wood".
          Thanks so much !
            Thanks so much !
            It has an entry in the PluginStore http://sketchucation.com/pluginstore?pln=jf_get_dimensions
            So you can get it as an RBZ archive for auto-installation.
            Manually installing RB files can be risky.
            Also note that this script is five years old and much has changed in SketchUp since then - however, simple well written older scripts like this can often work across many versions...
            Almost all scripts are now available in RBZ format making installation less fraught if you have >= v8M2...
              moabie
              Is it possible to rewrite the plugin to make it installable from sketchup plugin center?
              Is it possible to make it look different - more modern, not as ugly popup window,
              for example: show in window dimensions (as we made height depth lenght measurement tool) and make the plugin 'active' or 'not active' so that every model i click shows its dimensions?
              Anyway, great tool, grats!
                It's already available in the Sketchucation Plugin Store. What more do you need? 😒
                Get the SCF Plugin Store extension and use it to install this plugin or just download the .rbz file and use Install Extension.
                  ritchey
                  This is the best extension ever. Thumbs up thousand times.
                  • Y Offline
                    yossku
                    Thank you very much! Extremely helpful plugin! 😄
                      pipinek
                      @dedmin said:
                      Here is a new version that displays the dimensions on the status bar
                      [attachment=1:2up1m3b2]<!-- ia1 -->Screen.png<!-- ia1 -->[/attachment:2up1m3b2]
                      Made by a russian guy called 'newsposting'
                      [attachment=0:2up1m3b2]<!-- ia0 -->GetDimensions.rb<!-- ia0 -->[/attachment:2up1m3b2]
                      Greetings.
                      Alas it does not work with SU 2017 as far as I experience.
                      Should it be any equivalent or a version of that plugin for 2017 release?
                      Thank t=you in advance
                        What do you mean it doesn't work? I've been using Jim's Get Dimensions all along and it works just fine for me.
                        In fact, here's an example I made just now with SketchUp 2017.
                          Laurenceau
                          it doesn't work with 2018 version
                          plugin .rb instead of .rbz
                            It works just fine in SketchUp 2018.
                            You can either install the RB file manually or get the RBZ version here and use Install Extension or better, install the Sketchucation Extension Store tool and use it to automatically install the plugins and extensions host here on Sketchucation.
                            • dereiD Offline
                              derei
                              [attachment=0:25dij2zt]<!-- ia0 -->Screenshot - 12_5_2017 , 4_11_42 AM.png<!-- ia0 -->[/attachment:25dij2zt]
                              Can't seem to find the plugin in Extension Store... is still available, or was removed?
                                It seems that Jim has removed most if not all of his plugins.
                                  bsfranza
                                  hi there together,
                                  is there a working version of the plugin? or any alternative? because it seems its still gone from the extension store and sketchucation store 😕
                                  V 1 Reply Last reply Reply Quote 0
                                    As I wrote back in April of last year, Jim has withdrawn his extensions and plugins and they aren't available anymore. Get Dimensions was a useful one for me but I've not seen a similar one by any other author.
                                      dedmin
                                      Here we go:
                                      [mod=:1m1nlxa4]Edited to remove the file. It is up to the original author to share their plugins and extensions.[/mod:1m1nlxa4]
                                      • I Offline
                                        iamblindtoo
                                        Any upgrade on this?
                                          What sort of upgrade are you wanting for a plugin that has been withdrawn and is not available?
                                          • V Offline
                                            vasia7777
                                            This is "GetDimentions" plugin modified by russian guy which does work well with SU2014Pro on WinXPSP3 with out "Bug repot" window after exiting of SU14.
                                            It was founded on YouTube channel "Geometry of Comfort".
                                            GetDimentions_by Geometry of Comfort _SU2014.zip
                                            Another version (it may matchs for more newer SU) was published here:
                                            https://community.sketchucation.com/post/1239480
                                            • 3 / 4
