North Angle.rbz
I have it installed and see the three little icons, but haven't figured out how to change the North angle in my model,
or can I with this extension / whatever it's called??
Hover over the Icons, the tooltips are self-explanatory. Remember to update your scene if you want the angle to 'stick'.
Yes I see Toggle Animation, Save the North Angle, and the List for Scenes, but how to I change the North angle?
Forgot to say I'm using SUp 2015, in SUp Ver 5 we were able to change the North angle, I forget how though.
If you're on Pro - you can download the SolarNorth plugin by SketchUp. With that one, you can easily set the north angle.
Did you install North Angle Animator from here on Sketchucation? If so, the instructions are in the first post of this thread: http://sketchucation.com/forums/viewtopic.php?f=323&t=66074
