    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 30.5k Views 6 Watching
    • pbacotP
      that might be reasonable, while keeping the model as clean and simple as possible. You can make a component of the section--also it would need to start as a full shape to get it right and you'd need to keep it geometrically correct so it aligns perfectly. With components you can have all the identical parts in the model and see how they work together as you go...I see some people doing this sort of work sometimes use larger sections sometimes smaller to be able to model consistent with the overall shape.
      • macleeM
        maclee
        @pbacot said:
        it has to be 3d pattern? , Cutouts? I am not sure how best to do the deformation (Flowify plugin? Shapebender?), but I think there needs to be a unique way this pattern fits, based on the size and for it to work it would be symmetrical. So I would, if it were me.... decide how I wanted the pattern to fit first of all, then work on a section that can be mirrored and duplicated. It may even seem to be half of pattern, if you know what I mean, so you are only working on a small slice that is repeatable by mirroring and rotating.
        Depending on the scale, you'll be adding a lot of smaller detail, so probably making sure the object is large enough before you work on it will help SU which cannot make tiny faces and will help you be able to "manually" fix things as you go. You can scale it up then down to the right size in the end to print.
        Okay so I have reached another wall. I had it all figured out in my head but I can't seem to make it work. I have created the pattern so that I can drape it over the curved edge (I have a square in this picture just to test it out). Then I was going to copy the curved surface to form a circle. The problem I am having is the drape won't work. I watched numerous videos and did exactly what you are supposed to but nothing seems to work. The drape function just doesn't work for me. What am I doing wrong? Does anybody have any advice to get this pattern to drape on the face? I must be missing something important.
        Attached is an image of what I am trying to do and if you want to see for yourself here is the file: https://www.dropbox.com/s/vm3rrv9vit12pty/pattern_v3.skp?dl=0
        I also tried draping from above, as a group and as a component, still nothing works...
        Thanks for any help!
        Lee
        Obstacles do not block the path, they are the path.
        • boofredlayB
          boofredlay
          This one stumped me but I think I figured out one way to do it. Here is an image of the finished object. I will try to post up a how to here soon...
          • macleeM
            maclee
            OMG! That is IT! You are amazing. I am still struggling with this 3 days in... lol
            Can't wait to see how you did it!
            Thanks so much!
            Lee πŸŽ‰ 😲 β˜€ πŸ˜„
            • pbacotP
              Nice!
              • boofredlayB
                boofredlay
                Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
                This is one way to do it. I am sure there are probably others.
                Here are the plugins if you need them.
                Joint Push Pull Interactive:
                https://sketchucation.com/plugin/715-jointpushpull
                Mirror:
                https://sketchucation.com/plugin/762-mirror
                • macleeM
                  maclee
                  Mirror:
                  Wow boofredlay, that is incredible. I will give it a try although I think I have to watch your video a few times! lol Thank you so much for taking the time to do this. I really helped seeing such a Pro tackle this concept that I have been thinking about for ages! Finally being so close is great! Now lets see if I can pull it off... lol
                  Thanks again and great work!
                  • boofredlayB
                    boofredlay
                    Happy to help. Good luck.
                    • JQLJ
                      JQL
                      The pattern isn't right but it was a 15 minute doodle.
                      Using a single plugin: shape bender. Some kind of steped tutorial inside Skp.
                      Shape Bender.skp
                      www.casca.pt
                      Visit us on facebook!
                      • macleeM
                        maclee
                        [attachment=0:3gpqdurf]<!-- ia0 -->Shape Bender.skp<!-- ia0 -->[/attachment:3gpqdurf]
                        [attachment=1:3gpqdurf]<!-- ia1 -->Shape Bender.jpg<!-- ia1 -->[/attachment:3gpqdurf]
                        Oh wow JQL another great idea! I tried shape bender originally but was going about it all wrong, I had created a kind of flattened pattern of it and then I tried to roll it up along the edge of the circumference, but that was a disaster as I couldn't get the pattern right. I even tried "unwrapping" the simple model to get the flattened object thinking that I could flatten it, punch the pattern in and then wrap it up again, but I couldn't get that plugin to work, it kept unwinding it for some reason instead of unwrapping it, so I gave up! lol
                        This is a very clever way of using the shape bender and then tapering that edge on the bottom, very smart! And very helpful also to share the .skp file. Thanks so much! Great to see the starting point with the tile.
                        This forum is GREAT! I was just about ready to give up...
                        Lee πŸ˜„
                        • JQLJ
                          JQL
                          Lee πŸ˜„
                          Please don't... Stick around until the point you will be able to help others as others helped you.
                          The cycle must not stop πŸ˜„
                          www.casca.pt
                          • macleeM
                            maclee
                            @jql said:
                            Lee πŸ˜„
                            haha, right! I have a feeling I will be posting quite often... Sketchup is such a fun program to learn and even more so when you have people helping you when you get stuck!
                            • boofredlayB
                              boofredlay
                              Using a single plugin: shape bender...
                              JQL, how did you go from the step on the right to the one on the left?
                              Also, your final shape has quite a bit of overlap. I assume this is not ideal for a 3d print. Curious.Capture2.JPG
                              • JQLJ
                                JQL
                                I used shape bender using the arc of rhe pie.
                                In the end there's cleaning up to do to reach the last step as shape bender wasn't able to compress the bottom center part to an edge.
                                www.casca.pt
                                • boofredlayB
                                  boofredlay
                                  πŸ‘ Cheers.
                                  • ntxdaveN
                                    ntxdave
                                    I have used Shape Bender many times but not sure I fully get this part. Fully comprehend doing the curve to obtain the shape of the vessel but do not fully comprehend how to perform the taper.
                                    Press F1...thank me later
                                    • macleeM
                                      maclee
                                      When I bend my shape many of my petal cutouts get messed up, do you think it could be because I am working in real scale and I should start larger and then shrink it down? Yours stayed so perfect!
                                      My real scale is bottom c=22cm top c=64cm height 24cm
                                      • JQLJ
                                        JQL
                                        That should be the issue. Try scaling it up by 10 and then 10 again until Shape Bender doesn't cause issues.
                                        www.casca.pt
                                        • JQLJ
                                          JQL
                                          The trick with shape bender is that the edge that is parallel with the component, must be in the vertical projection of the component's X axis. Then you can control the final result precisely like this (click the gif):
                                          www.casca.pt
                                          • macleeM
                                            maclee
                                            Using a single plugin: shape bender...[/quote]
                                            [attachment=1:3hjnzs8x]<!-- ia1 -->Capture.JPG<!-- ia1 -->[/attachment:3hjnzs8x]
                                            It looks like perhaps he scaled it to match the size of the triangle?
                                            • 1 / 3
