    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 141.7k Views 39 Watching
    • P
      Pants
      Thanks, Fredo...I look forward to punching with surgical precision.
        VisuHole only accepts to drill if the pivot point is inside the shape.
        Aaaaaaaaaaaaaah! Damned! Un effet collatĂ©ral! 😆
        ça progresse, ça progresse! ☀
        • P
          Pants
          Fredo,
          Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display.
          I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway.
          Mahalo - Dave
          • fredo6F
            Dave,
            I would need to have your model with
            • the shape to drill
            • the set of faces to be used as a stencil.
            That would help me to troubleshoot
            • P
              Pants
              @fredo6 said:
              Dave,
              I just PM'd you...thanks - Dave
              • T
                thorx
                Hi to every one, only to mention that the last version of visuhole(1.3a) crashed in sketchup 2016 last version for mac and the way to replicate the issue is this:
                1. Make a cube
                2. Make a little circle to use with drill option
                3. Put the circle at the corner vertex of the cube to make some kind of chamfer effect by clicking twice (to fix position and establish the axis).
                4. Make the procedure number 3 one more time in another corner vertex of the cube and... that's it!, sketchup 2016 (last ver.19913 for mac) completely crashed and bugsplat appears.
                To be sure that the problem isn't for incompatibility with another plugin, I disabled all other stuff before test the plugin and the same thing occurred.
                Anyway, the whole collection of fredo6 plugins are the best I have seen, I know this is only a stupid bug that could be fix it soon...
                Thanks for your wonderful work and the spectacular plugins you do guys.
                My Machine:
                Macbook pro (mid-2012) with OS X El Capitan 10.11.2
                8GB RAM
                1GB Nvidia 650gt
                512GB SSD
                  Hello Fredo
                  No progress in this domain ?
                  Will be fine for Grooves with complex path! 😄
                  • fredo6F
                    Pilou,
                    That would be a different plugin, because groove have a 3D shape in general.
                    I think sdmitch has done something already.
                      rv1974
                      Grooving (edge extruding) is for sure in Top of the most missing features (among true curves,saving in background, and multiple curves as one profile path for example). None of existing scripts is close to workable level (say, comparable to JPP)
                      • kenK
                        ken
                        I am having problems with this program in drilling more that one hole. I have a pair of 4x4x1/2 angles next to each other, 1" apart. I mark each hole location with a guide point. I can make one hole, but cannot make any other of the holes.
                        I would like to mark all the holes, like 10 to 20 and just run down the line drilling holes into the angle at each guide point location.
                        Things I have tried.
                        1. guide points in and out of group selection and using a line end to mark the locations.
                        2. Separte groups selected or grouping both angle group in one large group.
                        3. If I click on the "Recurse from..." selection after each hole I can continue making one another hole. After this new hole I need to click on one of the "Recurse from..." to make another hole.
                        4. Note, if I make a the second selection that is not on a guide point I can make a hole, but I cannot make two selections using the guide points as reference.
                        • fredo6F
                          Ken,
                          Could you post the model.
                          I am not sure I understand well, so it will help me to figure out.
                          Many thanks
                          • kenK
                            ken
                            OK, here is the model. It has four version of the angles.
                            1. Blue is the two angles 1" apart
                            2. Yellow is the angles with a guide line and guide points where the holes are to be drilled
                            3. Red is the failure, after one hole on the guide points.
                            4. Green is what success should looks like. I can continue making holes if I keep selecting the "Recurse...." option. If I don't do the re-clicking of the "Recurse..." button, I never get the blue bonding box of a group, just the ghost lines. With the ghost lines I cannot make another hole.
                            Hope this help.
                            Angle Iron w holes.skp
                            • fredo6F
                              Ken,
                              OK. Got it. and it makes a lot of sense.
                              Just a bug I will fix.
                              Thanks for signaling.
                              • fredo6F
                                NEW RELEASE: VisuHole v1.4b - 12 Oct 17
                                VisuHole 1.4b is a miantenance release:
                                • fix a problem where pre-selection was lost after an operation
                                • certified SU2017
                                • Support of Hi-res screen
                                • compatibility OSX High Sierra
                                Note: v1.4a, published also on 12 Oct had a bug left. So better take v1.4b
                                The fix for Pre-selection concerns a bug signaled by Ken.
                                See main post of this thread for Download of VisuHole.
                                • kenK
                                  ken
                                  Thanks you Fredo. It works just like I need.
                                  Short story. I have had this plugin on my computer for sometime, I never could get it to drill consistance holes. So I started this new project and I have way to many holes to drill holes as I have been doing. So I made a concerted effort to learn the plugin. I knew the problem was with me, because no one else was complaining. Than I found one of my problems, the "group in" and "group out". Didn't quite understand what was happening there. Figured that out and watch the video over and over. Trying to see the exact setup in the menu.
                                  The other times I just gave up, had stuff to do. But this time I just kept at it. Then I found the post about guidelines and guide points. Then I knew it should work with more that one guideline or point. So now I knew I wasn't the problem.
                                  I am grateful for all of your plugins.
                                  • B
                                    bharralure
                                    2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpgBonjour Fredo,
                                    Juste un souhait qui n'est peut-ĂȘtre pas rĂ©alisable : est-il possible que VisuHole n'explose pas les courbes, arcs et autre cercles, et ainsi ne pas perdre les infĂ©rences et autres renseignements disponibles dans "Info sur l'entitĂ©" ?
                                    D'avance merci.
                                    • fredo6F
                                      @bharralure said:
                                      [attachment=0:2s4g1kip]<!-- ia0 -->2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpg<!-- ia0 -->[/attachment:2s4g1kip]Bonjour Fredo,
                                      D'avance merci.
                                      Not obvious, but I'll think of it in a next version.
                                      • B
                                        bharralure
                                        Bonjour Fredo, et merci d'avoir bien voulu prendre ma demande en considération, mais sachez que ce n'est pas une obligation, mais simplement une suggestion, surtout qu'il est possible de ressouder manuellement ces arcs et cercles, pour retrouver facilement, par inférence, leur centre par exemple (trÚs utile, entre autre, pour la cotation).
                                          rv1974
                                          cutting crossing window\polyline would be amazing spin-off.
                                          • fredo6F
                                            And on top of that, it does a chamfering of the intersection!
                                            ...and keep everything as a solid!
                                            what else?
                                            • 3 / 6
