    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 141.7k Views 39 Watching
    • T
      thorx
      Hi to every one, only to mention that the last version of visuhole(1.3a) crashed in sketchup 2016 last version for mac and the way to replicate the issue is this:
      1. Make a cube
      2. Make a little circle to use with drill option
      3. Put the circle at the corner vertex of the cube to make some kind of chamfer effect by clicking twice (to fix position and establish the axis).
      4. Make the procedure number 3 one more time in another corner vertex of the cube and... that's it!, sketchup 2016 (last ver.19913 for mac) completely crashed and bugsplat appears.
      To be sure that the problem isn't for incompatibility with another plugin, I disabled all other stuff before test the plugin and the same thing occurred.
      Anyway, the whole collection of fredo6 plugins are the best I have seen, I know this is only a stupid bug that could be fix it soon...
      Thanks for your wonderful work and the spectacular plugins you do guys.
      My Machine:
      Macbook pro (mid-2012) with OS X El Capitan 10.11.2
      8GB RAM
      1GB Nvidia 650gt
      512GB SSD
        Hello Fredo
        No progress in this domain ?
        Will be fine for Grooves with complex path! 😄
        • fredo6F
          Pilou,
          That would be a different plugin, because groove have a 3D shape in general.
          I think sdmitch has done something already.
            rv1974
            Grooving (edge extruding) is for sure in Top of the most missing features (among true curves,saving in background, and multiple curves as one profile path for example). None of existing scripts is close to workable level (say, comparable to JPP)
            • kenK
              ken
              I am having problems with this program in drilling more that one hole. I have a pair of 4x4x1/2 angles next to each other, 1" apart. I mark each hole location with a guide point. I can make one hole, but cannot make any other of the holes.
              I would like to mark all the holes, like 10 to 20 and just run down the line drilling holes into the angle at each guide point location.
              Things I have tried.
              1. guide points in and out of group selection and using a line end to mark the locations.
              2. Separte groups selected or grouping both angle group in one large group.
              3. If I click on the "Recurse from..." selection after each hole I can continue making one another hole. After this new hole I need to click on one of the "Recurse from..." to make another hole.
              4. Note, if I make a the second selection that is not on a guide point I can make a hole, but I cannot make two selections using the guide points as reference.
              • fredo6F
                Ken,
                Could you post the model.
                I am not sure I understand well, so it will help me to figure out.
                Many thanks
                • kenK
                  ken
                  OK, here is the model. It has four version of the angles.
                  1. Blue is the two angles 1" apart
                  2. Yellow is the angles with a guide line and guide points where the holes are to be drilled
                  3. Red is the failure, after one hole on the guide points.
                  4. Green is what success should looks like. I can continue making holes if I keep selecting the "Recurse...." option. If I don't do the re-clicking of the "Recurse..." button, I never get the blue bonding box of a group, just the ghost lines. With the ghost lines I cannot make another hole.
                  Hope this help.
                  Angle Iron w holes.skp
                  • fredo6F
                    Ken,
                    OK. Got it. and it makes a lot of sense.
                    Just a bug I will fix.
                    Thanks for signaling.
                    • fredo6F
                      NEW RELEASE: VisuHole v1.4b - 12 Oct 17
                      VisuHole 1.4b is a miantenance release:
                      • fix a problem where pre-selection was lost after an operation
                      • certified SU2017
                      • Support of Hi-res screen
                      • compatibility OSX High Sierra
                      Note: v1.4a, published also on 12 Oct had a bug left. So better take v1.4b
                      The fix for Pre-selection concerns a bug signaled by Ken.
                      See main post of this thread for Download of VisuHole.
                      • kenK
                        ken
                        Thanks you Fredo. It works just like I need.
                        Short story. I have had this plugin on my computer for sometime, I never could get it to drill consistance holes. So I started this new project and I have way to many holes to drill holes as I have been doing. So I made a concerted effort to learn the plugin. I knew the problem was with me, because no one else was complaining. Than I found one of my problems, the "group in" and "group out". Didn't quite understand what was happening there. Figured that out and watch the video over and over. Trying to see the exact setup in the menu.
                        The other times I just gave up, had stuff to do. But this time I just kept at it. Then I found the post about guidelines and guide points. Then I knew it should work with more that one guideline or point. So now I knew I wasn't the problem.
                        I am grateful for all of your plugins.
                        • B
                          bharralure
                          2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpgBonjour Fredo,
                          Juste un souhait qui n'est peut-être pas réalisable : est-il possible que VisuHole n'explose pas les courbes, arcs et autre cercles, et ainsi ne pas perdre les inférences et autres renseignements disponibles dans "Info sur l'entité" ?
                          D'avance merci.
                          • fredo6F
                            @bharralure said:
                            [attachment=0:2s4g1kip]<!-- ia0 -->2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpg<!-- ia0 -->[/attachment:2s4g1kip]Bonjour Fredo,
                            D'avance merci.
                            Not obvious, but I'll think of it in a next version.
                            • B
                              bharralure
                              Bonjour Fredo, et merci d'avoir bien voulu prendre ma demande en considération, mais sachez que ce n'est pas une obligation, mais simplement une suggestion, surtout qu'il est possible de ressouder manuellement ces arcs et cercles, pour retrouver facilement, par inférence, leur centre par exemple (très utile, entre autre, pour la cotation).
                                rv1974
                                cutting crossing window\polyline would be amazing spin-off.
                                • fredo6F
                                  And on top of that, it does a chamfering of the intersection!
                                  ...and keep everything as a solid!
                                  what else?
                                    rv1974
                                    actually when I thought for 2nd time (after first wows!) I realized it hardly can be a precise tool- not so suitable for archviz (my case). could be good for conceptual doodling.
                                      rv1974
                                      what else?
                                      hehe don't you start..
                                      from 31m00s- grooving 😲
                                      or even better:
                                      • fredo6F
                                        I feel like playing in the schoolyard when seeing these videos.
                                        Must be a trick, because the first time I played with Blender, I gave up after 2 hours and never came back.
                                          rv1974
                                          well after watching those ones I have rough idea what indians felt seenig gunned conquistadors on horses for a first time 😆
                                            jtri
                                            I have some some great uses for this plugin in my modeling, thanks. But when using Drill thru with nested components I get expected results. When using carve I do not see the colors of the nested components. To see the colors I would need to go clean up the model. Is this to be expected with this plugin or operator error? Top model in my example has been cleaned up.
                                            Visuhole.skp
                                            • 3 / 6
