    3D Truss Models
    1.5k Posts 31 Posters 869.8k Views 30 Watching
    • medeekM Offline
      medeek
      Price dropped to $15.00 for a new license and $10.00 for a renewal.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.0.3 - 10.13.2017
        • Added the option to provide a face mount hanger for inset floor joists with ledgers.
        • Added the option to provide a top flange hanger for inset floor joists without ledgers.
        • Added an option in the global settings to enable or disable manufacturer's logos.
        design.medeek.com
        • medeekM Offline
          medeek
          The ITS hanger family:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          The following hangers are included:
          ITS1.81/9.5
          ITS1.81/11.88
          ITS1.81/14
          ITS1.81/16
          ITS2.06/9.5
          ITS2.06/11.88
          ITS2.06/14
          ITS2.06/16
          ITS2.37/9.5
          ITS2.37/11.88
          ITS2.37/14
          ITS2.37/16
          ITS2.56/9.5
          ITS2.56/11.88
          ITS2.56/14
          ITS2.56/16
          ITS3.56/9.5
          ITS3.56/11.88
          ITS3.56/14
          ITS3.56/16
          And now part of the truss plugin.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.0.3b- 10.14.2017
            • Face mount hangers added for solid sawn floor joists.
            http://design.medeek.com/resources/images/truss_su285_800.jpg
            http://design.medeek.com/resources/images/truss_su286_800.jpg
            LUS24
            LUS26
            LUS28
            LUS210 (this hanger used by both 2x10 and 2x12 joists)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.0.3c- 10.14.2017
              • Added Red Built Red-I™ I-joists: 45, 65, 90, 90H, 90HS.
              http://design.medeek.com/resources/images/truss_su287_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 2.0.3d - 2017.10.15
                • Added PinkWood SAFEjoists™ I-joists: PKI 10, PKI 20, PKI 23, PKI 35Plus, PKI 40, PKI 50.
                http://design.medeek.com/resources/images/truss_su288_800.jpg
                This I-joist manufacturer has a pink protective coating on the ends. The purpose of the end coating is to protect the joist against moisture penetration.
                In addition, PinkWood offers Class A and Class B Fire Rated joists often referred to as "SAFEJoists". These joists are protected with an intumescent Fire Rated Coating, and have tan colored coating on the web.
                Manufactured in Calgary, Alberta, Canada.
                Now that I've got things configured correctly it is quite easy for me to add in new manufacturers and their entire series of I-joists. If you are interested in seeing a particular brand added to the plugin please feel free to contact me.
                design.medeek.com
                • medeekM Offline
                  medeek
                  http://design.medeek.com/resources/images/truss_su289_800.jpg
                  design.medeek.com
                  • pbacotP Offline
                    Thanks for the note on those trusses. Always looking for reasonable 1 hr. 2 hr. assemblies.
                    • medeekM Offline
                      medeek
                      I drop the price and sales decrease rather than increase, this just doesn't make any sense.
                      Some sort of reverse psychology I guess.
                      p.s. I moved the price up slightly to $20.00 and $15.00 for the renewal and sales are picking up again.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        A request today for the barrel vault truss. I had been working on the algorithm for this truss type about 18 months ago but the lack of interest caused me to stop. Below is a matrix of potential configurations:
                        http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA2.jpg
                        If anyone has some shop drawings for this truss type that they are willing to share I would be grateful.
                        I will try and knock this one out next week. I will probably utilize an html/svg UI since the look and feel of this truss type will be important to the designer (barrel height and barrel width).
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          I've got some direction on how to deal with engineering for beams and joists, not high on the priority list right now but I've been giving it some thought:
                          Intersecting Faces or Edges
                          In the model below you can see that the I-joist is supported or touches three separate faces (surfaces). I am trying to figure out a way to code an algorithm that lets me know all of the bearing points along a beam o…
                          SketchUp Community (forums.sketchup.com)
                          At first gathering the geometric information from the model seemed the most challenging aspect of this problem but after giving it more thought, dealing with multi-span beams with various distributed and point loads is also not a trivial problem. My current beam calculator is very limited in this respect and can only handle very simple loading on a single span.
                          Medeek Beam Calculator
                          (design.medeek.com)
                          And yet even with the simplicity of the span and loading the logic and calculations required is fairly substantial. The output of the beam calculator will attest to this.
                          To properly analyze a multi-span beam with complex loading requires some magic from my engineering texts (ie. matrix analysis). Since beams and joists are one dimensional as compared with trusses (two dimensional) the math is not nearly as cumbersome but it should prove to be a bit of a challenge.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            The updated truss menu:
                            http://design.medeek.com/resources/images/truss_su293_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.0.4 - 10.21.2017
                              • Added Parallel Chord (vaulted) truss type, configurations: (2/2, 4/4, 6/6).
                              http://design.medeek.com/resources/images/truss_su291_800.jpg
                              http://design.medeek.com/resources/images/truss_su292_800.jpg
                              http://design.medeek.com/resources/images/truss_su294_800.jpg
                              I will still need to enable structural outlookers and plates for this truss type, but everything else should be there:
                              • Roof Cladding
                              • Roof Sheathing
                              • Gable Wall Cladding
                              • Gable Wall Sheathing
                              • Ceiling Gypsum
                              • Ridge Cap
                              etc...
                              View model here:
                              3D Warehouse
                              design.medeek.com
                                dpaul
                                I have been hoping for the parallel chord truss. Just great.
                                Thanks...!
                                • medeekM Offline
                                  medeek
                                  All you have to do is ask.
                                  This truss type is relatively close to the scissor truss so I was able to bring it together fairly quickly. If there is anything I'm missing on this truss type please let me know. I can also add the 8/8 and 10/10 configuration if requested
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.0.4b - Added the 8/8 configuration:
                                    http://design.medeek.com/resources/images/truss_su295_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      People have often asked why there is always a guy shown in various screen shots for the plugins next to the truss, foundation or building displayed. The reason for the person in the picture is to give the geometry some sense of scale. I've also received comments as to why the "old guy"? Some have even complained about it. Each release of SketchUp features a new default person for that release. The 2015 release featured an older gentleman. Since most of my audience is architects and designers who are the predominantly of the male gender perhaps it would be more fitting to use a female model to indicate the scale?
                                      http://design.medeek.com/resources/images/truss_su296_800.jpg
                                      Conclusion: The problem with the female model is she is too distracting. The audience will naturally focus on the model and not on the product I am selling which is architectural modeling software (BIM). The model should only function as a yard stick and should remain secondary to the structure or building component displayed. Bottom line I won't be switching to a female model anytime soon.
                                      Another point worth noting is that a well designed truss or roof is already a thing of beauty, no further marketing gimmicks required.
                                      design.medeek.com
                                        MtnArch
                                        Spoken like a true engineer!
                                        Highest Regards,
                                        Alan T. Hendry, RA
                                        Architect
                                        • medeekM Offline
                                          medeek
                                          I've been slowing chewing away at the straight skeleton algorithm and still working out some of the kinks, there is a lot of logic dealing with how the rafters intersect various valleys and ridges. I will continue to hammer away at this over the next couple of weeks and hopefully have something to release by the end of November or sooner.
                                          On a slightly different note I've been examining Vali Architects Instant Roof plugin and looking at how it generates gutters. Is this something that people would be interested in seeing added to the plugin?
                                          I don't think it would be too much of a stretch to add this feature in.
                                          I would probably start with the standard 5" K-style gutter where one could fine tune the dimensions within the global settings.
                                          https://www.guttersupply.com/file_area/public/categories/ImageUrl4_1297790173_1813.jpg
                                          I'm assuming one would just want to draw this a surface and not a solid?
                                          design.medeek.com
                                          • pbacotP Offline
                                            I think you'd have to use as a surface to keep the polycount down. VA Roof plugin is very good and I use it especially for quickly adding the materials and features like gutters. The gutters and caps are not all that accurate,but OK for an overall building model. For ogee gutters I use my own geometry with Followme etc. I do not worry about having it open on top as it hardly affects the appearance of most views to the model and the solid shape is easier to work with. In sections, you might prefer it open for realism. I also add downspouts.
                                            BTW I don't often use the actual roof forms of InstantRoof because I don't seem to have roof designs that work well. There's always something unusual about the roofs. I figure (since you go for accurate framing) your plugin has also solved the issue of accurate placement of the roof planes in relation to the plate height, which is my problem with most roof plugins.
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 74
                                            • 75
                                            • 38 / 75
