    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • G
      glro
      @medeek said:
      But then again perhaps I have hit an actual saturation point, where "real" users have all been potentially exposed to the plugin and everyone else is just testing it out but never will purchase it for serious use.
      Ultimately, I am just trying to find a way to monetize my efforts more and somehow enable myself to spend even more time developing this plugin and all of others I've started cooking up.
      10 000 downloads is a lot! but your extension is a very specific and professional one; so, what percentage of the 10 000 downloads correspond to professional users?
      my understanding is that you are confused between a hobby and a professional use
      i doubt lowering the price of your extension would change anything; because it is not an extension for a hobb
      my guess is you rather need a partner, to help you with the marketting, so you can reach only the professional users, and get real income from your work.
      The logo you recently added on the beams might be an opportunity to contact the manufacturers; maybe they would be interested in paying you to work on there product.
      because technical tools help to sell products also
      • medeekM
        medeek
        @juju said:
        Can one switch off those logos? It is of little use to the rest of the world (or other areas where the brands are not represented).
        Valid point. I will add an option in the global settings to toggle on/off all branding (logos). Even if it is applicable some users may not want to display the logos, I need to give them that option.
        2.0.3 will have that option added in as well as the rest of the ITS series of hangers.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Top flange hangers without a ledger, just a sill plate:
          http://design.medeek.com/resources/images/truss_su284_800.jpg
          This is a Simpson ITS1.81/9.5, this is the equivalent to the the IUS series but in top flange configuration. Again there are 20 different configurations for this hanger type.
          design.medeek.com
          • medeekM
            medeek
            my guess is you rather need a partner, to help you with the marketing, so you can reach only the professional users, and get real income from your work.
            I guess that is my question, if I where to lower the price to make it feasible for the "DIY'er, Hobbyist etc..." would they jump on board. I realize that the professional market of SketchUp designers and architects is somewhat limited. The number of non-professional users far outweigh the professional, partly due to SketchUp Make being free and also because the learning curve of SketchUp is so much better than competing products.
            Would the casual user be willing to pay $5-$10 for a plugin that could help with their one off project?
            design.medeek.com
              dpaul
              I do not believe the solution can ever be to lower the price of your plugin to attract MAKE users.
              You are in the process of crafting a remarkable professional plugin, and to my mind, you have to stay the course with that group of purchasers and users.
              An observation from my little perch: purchasers are not drying up, they are WAITING. They are waiting for the plugin (floors, trusses and the WALL plugin as combined...!!!) to mature for daily professional use.
              Your own notes clearly tell us what we already know about the present limitations and how much more coding is required:
              The plugin as a whole has quite of bit of functionality but it also is very limited in many respects. This really jumps out at me when I try to model up some recent homes that I did structural work on a few months ago. The biggest issues seem to be:
              • Inability to cut holes in floors or create polygon floor outlines.
              • The same issue with roofs in that the plugin is only really good at rectangular roof outlines. The straight skeleton implementation will address this, at least for rafter roofs initially, truss roofs will be a much bigger problem.
              • There is no function for editing a roof or floor assembly, it's fire and forget. This feature would be particularly useful when you botched one parameter and just need to go back and edit something minor rather than recreating the entire assembly (not that this is too difficult).
              • I'm missing a good staircase creator/editor.
              • Not all of the truss types are up to speed with all the recent advanced options, so much to do.
              • The manual is almost non-existent.
              The list of limitations goes on. The plugin has potential but its certainly a work in progress and far from the polished gemstone it needs to be.
              In truth, it is almost as if you have no choice but to go 'underground', complete all of the coding required (as per the essential list above), only coming back out to the marketplace when you have a robust finished product in hand. From there, us professional users, aware of what we already see (and further imagine) could be a world-class addition to Sketchup, will willingly support your marketing efforts.
              I am encouraged to read you are not selling the code, but will continue, regardless. You show an entrepreneurs' courage. For this alone, I wish you ever possible success.
              • medeekM
                medeek
                The plugin is targeted at the professional designer. The complexity and level of detail it affords is the primary reason some designers find it useful. However, this level of detail does not automatically preclude it from being used by the casual user. Typically one can leave most of the setting at their default values and use the plugin with little to no effort and special building knowledge. A completed manual would of course help with the learning curve.
                The casual user base would subsidize the more intense development and ultimately the end product that the design professionals can take advantage of.
                Its really just a numbers game, if the volume is there then the price can decrease. In the end my development costs are the same whether I have 400 users or 4,000 users. To develop this full time for a couple years is going to cost between $80,000 to $100,000 at an average of $45,000 per year. I figure I'm going to need at least two more years of full time development to make this thing into something fairly substantial.
                design.medeek.com
                • medeekM
                  medeek
                  Price dropped to $15.00 for a new license and $10.00 for a renewal.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.0.3 - 10.13.2017
                    • Added the option to provide a face mount hanger for inset floor joists with ledgers.
                    • Added the option to provide a top flange hanger for inset floor joists without ledgers.
                    • Added an option in the global settings to enable or disable manufacturer's logos.
                    design.medeek.com
                    • medeekM
                      medeek
                      The ITS hanger family:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      The following hangers are included:
                      ITS1.81/9.5
                      ITS1.81/11.88
                      ITS1.81/14
                      ITS1.81/16
                      ITS2.06/9.5
                      ITS2.06/11.88
                      ITS2.06/14
                      ITS2.06/16
                      ITS2.37/9.5
                      ITS2.37/11.88
                      ITS2.37/14
                      ITS2.37/16
                      ITS2.56/9.5
                      ITS2.56/11.88
                      ITS2.56/14
                      ITS2.56/16
                      ITS3.56/9.5
                      ITS3.56/11.88
                      ITS3.56/14
                      ITS3.56/16
                      And now part of the truss plugin.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.0.3b- 10.14.2017
                        • Face mount hangers added for solid sawn floor joists.
                        http://design.medeek.com/resources/images/truss_su285_800.jpg
                        http://design.medeek.com/resources/images/truss_su286_800.jpg
                        LUS24
                        LUS26
                        LUS28
                        LUS210 (this hanger used by both 2x10 and 2x12 joists)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.0.3c- 10.14.2017
                          • Added Red Built Red-I™ I-joists: 45, 65, 90, 90H, 90HS.
                          http://design.medeek.com/resources/images/truss_su287_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.0.3d - 2017.10.15
                            • Added PinkWood SAFEjoists™ I-joists: PKI 10, PKI 20, PKI 23, PKI 35Plus, PKI 40, PKI 50.
                            http://design.medeek.com/resources/images/truss_su288_800.jpg
                            This I-joist manufacturer has a pink protective coating on the ends. The purpose of the end coating is to protect the joist against moisture penetration.
                            In addition, PinkWood offers Class A and Class B Fire Rated joists often referred to as "SAFEJoists". These joists are protected with an intumescent Fire Rated Coating, and have tan colored coating on the web.
                            Manufactured in Calgary, Alberta, Canada.
                            Now that I've got things configured correctly it is quite easy for me to add in new manufacturers and their entire series of I-joists. If you are interested in seeing a particular brand added to the plugin please feel free to contact me.
                            design.medeek.com
                            • medeekM
                              medeek
                              http://design.medeek.com/resources/images/truss_su289_800.jpg
                              design.medeek.com
                              • pbacotP
                                Thanks for the note on those trusses. Always looking for reasonable 1 hr. 2 hr. assemblies.
                                • medeekM
                                  medeek
                                  I drop the price and sales decrease rather than increase, this just doesn't make any sense.
                                  Some sort of reverse psychology I guess.
                                  p.s. I moved the price up slightly to $20.00 and $15.00 for the renewal and sales are picking up again.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    A request today for the barrel vault truss. I had been working on the algorithm for this truss type about 18 months ago but the lack of interest caused me to stop. Below is a matrix of potential configurations:
                                    http://design.medeek.com/resources/truss/BARREL_VAULT/BARRELVAULT_STUDY1_REVA2.jpg
                                    If anyone has some shop drawings for this truss type that they are willing to share I would be grateful.
                                    I will try and knock this one out next week. I will probably utilize an html/svg UI since the look and feel of this truss type will be important to the designer (barrel height and barrel width).
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I've got some direction on how to deal with engineering for beams and joists, not high on the priority list right now but I've been giving it some thought:
                                      Intersecting Faces or Edges
                                      In the model below you can see that the I-joist is supported or touches three separate faces (surfaces). I am trying to figure out a way to code an algorithm that lets me know all of the bearing points along a beam o…
                                      SketchUp Community (forums.sketchup.com)
                                      At first gathering the geometric information from the model seemed the most challenging aspect of this problem but after giving it more thought, dealing with multi-span beams with various distributed and point loads is also not a trivial problem. My current beam calculator is very limited in this respect and can only handle very simple loading on a single span.
                                      404 - File or directory not found.
                                      (design.medeek.com)
                                      And yet even with the simplicity of the span and loading the logic and calculations required is fairly substantial. The output of the beam calculator will attest to this.
                                      To properly analyze a multi-span beam with complex loading requires some magic from my engineering texts (ie. matrix analysis). Since beams and joists are one dimensional as compared with trusses (two dimensional) the math is not nearly as cumbersome but it should prove to be a bit of a challenge.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        The updated truss menu:
                                        http://design.medeek.com/resources/images/truss_su293_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 2.0.4 - 10.21.2017
                                          • Added Parallel Chord (vaulted) truss type, configurations: (2/2, 4/4, 6/6).
                                          http://design.medeek.com/resources/images/truss_su291_800.jpg
                                          http://design.medeek.com/resources/images/truss_su292_800.jpg
                                          http://design.medeek.com/resources/images/truss_su294_800.jpg
                                          I will still need to enable structural outlookers and plates for this truss type, but everything else should be there:
                                          • Roof Cladding
                                          • Roof Sheathing
                                          • Gable Wall Cladding
                                          • Gable Wall Sheathing
                                          • Ceiling Gypsum
                                          • Ridge Cap
                                          etc...
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                            dpaul
                                            I have been hoping for the parallel chord truss. Just great.
                                            Thanks...!
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 76
                                            • 77
                                            • 45 / 77
