    Dwg import failed
    8 Posts 5 Posters 12.8k Views 5 Watching
      KristienDC
      Hello Sketchucation,
      I don't know if you have a separate "import failed" section?
      I have a 2d dwg-file that i need to import,but sketchup keeps telling me "import failed" without any further details. It's not a big file, and other dwg's always imported perfectly. So it is the dwg-drawing that needs to be adjusted but I don't know in what way or how.
      When I open the file in autocad, it tells me that shx-files are missing. I tell autocad to ignore these and the dwg opens in autocad. I then tried several things, save it again as dwg (as now maybe the missing shx-files are ignored?), save it as an dxf, and export it to stl.
      The new dxf and dwg also give the same message "import failed" in sketchup
      The stl-file was no created because I have to do another step and I don't know what πŸ˜• , I know nothing about autocad.
      Can you help me?
      thnx
      Kristien
        You could try sharing the file to see if someone can import it?
        • sketch3d.deS Offline
          sketch3d.de
          open in the free Teigha Viewer and save down to the DWG v2000 format.
          • jujuJ Offline
            juju
            Draftsight also works very well, and it has a free version.
              sketch3d.de
              the Teigha Viewer is free, a full blown CAD system overkill for doing this... especially with DraftSight (OEM Graebert CAD) using the Teigha DXF/DWG engine anyhow.
                KristienDC
                Thanks for the tip on the Teigha viewer. I converted all the files. And autocad or dwgviewer do not give any erros anymore. However. The sketchup import still fails.
                I want to share an example file, but it will give errors because you won't have the necessary x-refs. So I would have to send the complete dossier and that would be confidential 😞.
                Any other ideas?
                  KristienDC
                  Hey, thanks for the Teigha viewer tip. I installed it and converted all the files. The dwf viewer does not give any errors anymore so I figured it would work in sketchup too. Unfortunately it didn't. I don't know why. I would like to share the file but then I would would have to share all the xrefs, and i'm afraid it would be confidential.
                  Any other ideas?
                  • I Offline
                    infovanderwoude.nl
                    Hello,
                    I know this topic is open a long time but i had the same problem and i found out that when you "explode" all your lines in the AutoCad drawing and then save the drawing again it will load into SketchUp when imported as a DWG-file.
