    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.9k Views 109 Watching
      @c3dx
      These read_/write_default errors [and many more] might be because you have not initially installed SketchUp correctly.
      Thereby stopping you/SketchUp accessing the Registry properly.
      Here is how to install SketchUp properly...
      Find the SketchUp installer's exe file - probably in your Downloads folder.
      Select its icon, right-click, context-menu, "Run as administrator"...
      This will ensure it's correctly installed, and that you and the app now have proper permissions set up.
      If you already have SketchUp installed you probably do not need to uninstall/reinstall it - firstly try this...
      Close SketchUp.
      Use "Run as administrator" on the installer's exe file, as explained above...
      When prompted choose "Repair"...
      This should fix issues.
      Report back...
      • C
        c3dx
        @tig said:
        @c3dx
        Close SketchUp.
        Report back...
        Thanks Tig
        But i just reinstall it with the repair option as administrator but i still have the same result...
        i will try to uninstall everything and try it again....
        i don't know if it can have something to do with it , i had system mechanic running on it before, may be it did change some rule somewhere about the ability to read the registry....
        • C
          c3dx
          @pilou said:
          Works fine for me with new Window 10 "creative" (French) not Pro but Familly! πŸ˜„
          Have you some accents on the paths Folders ?
          Have you install it from the "Red Ruby" Menu from Sketchup ?
          [attachment=0:2yws8aqg]<!-- ia0 -->red ruby.jpg<!-- ia0 -->[/attachment:2yws8aqg]
          [attachment=1:2yws8aqg]<!-- ia1 -->floor01.jpg<!-- ia1 -->[/attachment:2yws8aqg]
          Yes i did install it with the Red Ruby Menu from sketchup, i have a lap top and its not working there to, same result.... i really dont know why, this plugin can really help me....if i can make it work
          I dont have any accent in my path....
            Your earlier post suggested that you have messed around with the Registry settings.
            SketchUp, and some of its plugins need to write and read values from the Registry - so they are remembered across sessions...
            If that ability has been limited you will get problems !
            What did you do 😲
            • sdmitchS
              sdmitch
              Previous versions of SDM_FloorGenerator had a problem with reading defaults from the registry when new pattern options had been added but I believe I finally fixed that problem in the May2017 release. Make sure you have the latest version.
              http://sdmitch.blogspot.com/
              • utilerU
                utiler
                Hi Sam, just have a question about what's going on here...
                When I select the random texture option and select the source of the textures, I select a .skm file then I get a material picker dialogue box showing on the screen that has nothing but a select button.
                Any suggestions?
                Edit: I have loaded the latest rbz file by the way....
                Floorgen-FileError.wmv
                Just Curious...
                • sdmitchS
                  sdmitch
                  Any suggestions?
                  The random texture option is not designed to use .skm files only .jpg,.png,.etc.
                  • utilerU
                    utiler
                    No worries. ta.
                    Just Curious...
                    • C
                      c3dx
                      What did you do 😲
                      I really dont know, i never go in there to change value or key's, that's why i suspect System Mechanic
                      • G
                        gizeh33
                        doesnt work on sketchup 17 mac os. it is installed but starting the tool results in nothing
                        • sdmitchS
                          sdmitch
                          Any errors output to the Ruby Console?
                            Areczan
                            Hello everyone.
                            I'm trying to figure out what I'm doing wrong using Floor Generator. I wanted to apply a pack of textures to random tiles using BRICK function. However, what i get is not exactly what I need. The texture seems to be rotated which is not cool as I'm using 550x3402 pix images and want to create 194x1200 mm tiles.
                            My settings and the view from Sketchup in files attached.
                            I'm using SU 2017
                            Thanks for any ideas for what I could do differently here.
                            Settings
                            Skechup view
                            • W
                              wingedhippo
                              Hello, I understand that Floor Generator is no longer being developed, but I would like to ask how to override or turn off "clapboard pattern can only be placed on a vertical face"? I have a model that is created from rotated and/or scaled components to save building time, so while the faces are "vertical" in appearance they may not be according to Sketchup axis... Even when exploding I still get this error (blue axis is up)...
                              • Z
                                Zin Min Tun
                                Thanks you SDM.But I cannot download it.
                                • E
                                  Einstein
                                  Hi! I think I had the same problem as c3dx and gizeh33 - nothing happened when I clicked the toolbar button. Now I downloaded the latest version from http://sdmitch.blogspot.com/ and it's working. Please update the newest version into Plugin Store if you can.
                                  • sdmitchS
                                    sdmitch
                                    The plugin store and blog versions are the same.
                                    • T
                                      TraxXx
                                      Hi Sam !
                                      Thanks for the wonderful plugin first of all, that's really helpful ! I have two questions concerning the wood pattern, would it be possible to make continuous wood planks without any cuts ? I tried to increase the lenght value so it's higher than the maximum height of my volume to cover with planks but I'm still getting cuts.
                                      I'm actually working on a house project extension. The original house has single lenghts planks going from floor to roof with three differents width of 7, 13 and 20 cm. Yet, your plugin seems to be the most appropriate to complete this task regarding the fact that I need the same spacing between the planks. But i'm looking for a way to lay planks of these precise widths, randomly against my volume. Your plugin is creating random width which provides me with a close result but not what I meant to do. I hope I'm being clear in my explanation...
                                      I guess there must be a way to achieve that with maybe several plugins, but couldn't find the way. I also tried creating these 3 different planks as components and spray them along line with compospray, but this one doesn't allow me to control the spacing and doesn't adjust the planks top to my shape as your plugin does... Each plugin shows limits for this task and I'm afraid my request is a bit too difficult to solve... But still I'm asking in case of I can avoid making planks one by one πŸ˜„
                                      Hope you can help πŸ˜„ Thanks !
                                      Wood planks created against a not parallel shape
                                      • sdmitchS
                                        sdmitch
                                        One should never say never but modifying FloorGenerator to allow multiple wood widths is as close as you can get. Sorry but I just don't see it happening.
                                        • T
                                          TraxXx
                                          At least I tried ! πŸ˜„ And what about the gaps ? Can I avoid them to happen on the planks smallest sides ? Like continuous planks from floor to roof ? Or does it have to be necessarily linked to the longest sides gaps value ?
                                          • sdmitchS
                                            sdmitch
                                            Yes, the gap is the same on all sides.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
