    HTMLDialog vs WebDialog?
    23 Posts 5 Posters 7.5k Views 5 Watching
    • medeekM
      medeek
      I have some issues with Mac users and my webdialogs. Unfortunately, I don't have a Mac computer at my disposal so I can't directly test and debug the issues but it appears to be some behavior with the blocking not working correctly in MacOS.
      Does anyone have any suggestions on a work around for this problem.
      I've been tempted to switch to HTMLDialog from WebDialog but I have too many people using the plugins who have older versions of SU.
      I also don't see any distinct advantage to switching unless it will fix my MacOS problem.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Here is my code for my webdialog for the timber truss feature that I recently added. I think the issues with Mac users may have to do with the dialog not being "modal" even though I am using the show_modal method:
        # Create the WebDialog instance
        if @Licensemode == "trial"
          dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin - (trial version)", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
        else
          dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
        dlg1.add_action_callback("PUSHTOHTML_SETTINGS") {|dialog, params|
          js_command = 'pushdata( "' + @Trusstype.to_s + '|' ....  .... '|' + @Panel.to_s + '" );'
          # puts js_command
          dialog.execute_script(js_command)
        dlg1.add_action_callback("GET_SETTINGS") {|dialog, params|
          params = params.to_s
          # puts params
          paramlist = []
          paramlist = params.split("|")
          @Trusstype = paramlist[0]
          @Span = paramlist[1]
          if @Span == ""
            @Span = @TrussSpan_ft
          else
            @Span = @Span.to_f
          @Panel = paramlist[20]
          if @Panel == ""
            @Panel = @Span * 12.0 * 0.25
          else
            @Panel = @Panel.to_f
        dlg1.add_action_callback("CLOSE_DIALOG") {|dialog, params|
          dialog.close
        # Find and show our html file
        dlg1.set_file File.dirname(__FILE__) + "/html/web_dialog_timber_truss.html"
        dlg1.show_modal()
        design.medeek.com
          driven
          can you add a link to the version showing issues...
          without the html and params it's impossible to guess the issue...
          I doubt it has anything to do with modality of the window...
          • medeekM
            medeek
            The html code is rather large due to the insane amount of javascript that is used to generate the SVG preview so rather than post it on the board it can be viewed here:
            404 - File or directory not found.
            (design.medeek.com)
            Just take a look at the source code of this page.
            The version of the plugin having the issues is 1.9.8, download here:
            (design.medeek.com)
            design.medeek.com
              driven
              are they seeing errors like this?
              the `onLButtonDown' doesn't finalise before the dialog shows, and then creates and new dialog when you click again...
              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
              • medeekM
                medeek
                I will check with the user who reported the error and see what I come back with. Thank-you for helping me look into this.
                design.medeek.com
                • medeekM
                  medeek
                  Error; #<NoMethodError; undefined method `*' for nil;NilClass>
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1064;in `create_timber_geometry'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
                  Error; #<TypeError; String can't be coerced into Float>
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `+'
                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `create_timber_geometry'
                  design.medeek.com
                  • medeekM
                    medeek
                    The error codes posted above.
                    design.medeek.com
                    • Dan RathbunD
                      Dan Rathbun
                      ... are occurring (according to your error messages,) in " medeek_roof_truss.rbs", line 5726, in callback method onLButtonDown.
                      In the first you are calling a *() method upon an object that is referencing the global singleton nil object. Since the NilClass does not have an "asterisk" method, a NoMethodError is raised.
                      The second method is caused by your code expecting a Float object, but getting a String object instead.
                      The answer is simple. Whenever an object reference could reference disparate types (classes) of obejcts, use a combination of type validation and Ruby rescue clauses with the onLButtonDown callback method.
                      I'm not here much anymore.
                      • medeekM
                        medeek
                        Okay 95% of that just went over my head, but I'll try and decipher into terms I can understand.
                        But why would this error only be raised for SketchUp running on MacOS and not Windows?
                        design.medeek.com
                        • Dan RathbunD
                          Dan Rathbun
                          Basically I'm trying to prompt you to learn how to read Ruby error and backtrace messages.
                          “filename:lineNo: inmethod”‘ or “filename:lineNo.”`
                          http://ruby-doc.org/core-2.2.4/doc/syntax/exceptions_rdoc.html
                          http://ruby-doc.org/core-2.2.4/Exception.html
                          Data validation - Wikipedia
                          (en.wikipedia.org)
                          An example in Ruby of testing if an object reference is pointing at an object of a certain class:
                          if obj.is_a?(NilClass)
                          ... or ...
                          if obj.is_a?(Float)
                          An example in Ruby of validating that an object reference call responds to a certain method call:
                          if obj.respond_to?(:methname)
                          ... and testing for the "asterisk" method specifically:
                          if obj.respond_to?(:*)
                          I don't know (offhand) as I avoid Macs myself. (But OSX and MS Windows use different sets of keycodes.)
                          Actually, looking at the backtraces (in your original error listing) the errors are kicked off by a LButtonDown keypress, but are occurring in the `` create_timber_geometry()`' method, lines 1064 and 1355.
                          • 2 / 2
