    HTMLDialog vs WebDialog?
    23 Posts 5 Posters 7.0k Views 5 Watching
    • medeekM
      medeek
      Here is my code for my webdialog for the timber truss feature that I recently added. I think the issues with Mac users may have to do with the dialog not being "modal" even though I am using the show_modal method:
      # Create the WebDialog instance
      if @Licensemode == "trial"
        dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin - (trial version)", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
      else
        dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
      dlg1.add_action_callback("PUSHTOHTML_SETTINGS") {|dialog, params|
        js_command = 'pushdata( "' + @Trusstype.to_s + '|' ....  .... '|' + @Panel.to_s + '" );'
        # puts js_command
        dialog.execute_script(js_command)
      dlg1.add_action_callback("GET_SETTINGS") {|dialog, params|
        params = params.to_s
        # puts params
        paramlist = []
        paramlist = params.split("|")
        @Trusstype = paramlist[0]
        @Span = paramlist[1]
        if @Span == ""
          @Span = @TrussSpan_ft
        else
          @Span = @Span.to_f
        @Panel = paramlist[20]
        if @Panel == ""
          @Panel = @Span * 12.0 * 0.25
        else
          @Panel = @Panel.to_f
      dlg1.add_action_callback("CLOSE_DIALOG") {|dialog, params|
        dialog.close
      # Find and show our html file
      dlg1.set_file File.dirname(__FILE__) + "/html/web_dialog_timber_truss.html"
      dlg1.show_modal()
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        driven
        can you add a link to the version showing issues...
        without the html and params it's impossible to guess the issue...
        I doubt it has anything to do with modality of the window...
        • medeekM
          medeek
          The html code is rather large due to the insane amount of javascript that is used to generate the SVG preview so rather than post it on the board it can be viewed here:
          404 - File or directory not found.
          (design.medeek.com)
          Just take a look at the source code of this page.
          The version of the plugin having the issues is 1.9.8, download here:
          (design.medeek.com)
          design.medeek.com
            driven
            are they seeing errors like this?
            the `onLButtonDown' doesn't finalise before the dialog shows, and then creates and new dialog when you click again...
            /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
            /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
            /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
            /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
            /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
            • medeekM
              medeek
              I will check with the user who reported the error and see what I come back with. Thank-you for helping me look into this.
              design.medeek.com
              • medeekM
                medeek
                Error; #<NoMethodError; undefined method `*' for nil;NilClass>
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1064;in `create_timber_geometry'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
                Error; #<TypeError; String can't be coerced into Float>
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `+'
                /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `create_timber_geometry'
                design.medeek.com
                • medeekM
                  medeek
                  The error codes posted above.
                  design.medeek.com
                  • Dan RathbunD
                    Dan Rathbun
                    ... are occurring (according to your error messages,) in " medeek_roof_truss.rbs", line 5726, in callback method onLButtonDown.
                    In the first you are calling a *() method upon an object that is referencing the global singleton nil object. Since the NilClass does not have an "asterisk" method, a NoMethodError is raised.
                    The second method is caused by your code expecting a Float object, but getting a String object instead.
                    The answer is simple. Whenever an object reference could reference disparate types (classes) of obejcts, use a combination of type validation and Ruby rescue clauses with the onLButtonDown callback method.
                    I'm not here much anymore.
                    • medeekM
                      medeek
                      Okay 95% of that just went over my head, but I'll try and decipher into terms I can understand.
                      But why would this error only be raised for SketchUp running on MacOS and not Windows?
                      design.medeek.com
                      • Dan RathbunD
                        Dan Rathbun
                        Basically I'm trying to prompt you to learn how to read Ruby error and backtrace messages.
                        “filename:lineNo: inmethod”‘ or “filename:lineNo.”`
                        http://ruby-doc.org/core-2.2.4/doc/syntax/exceptions_rdoc.html
                        http://ruby-doc.org/core-2.2.4/Exception.html
                        Data validation - Wikipedia
                        (en.wikipedia.org)
                        An example in Ruby of testing if an object reference is pointing at an object of a certain class:
                        if obj.is_a?(NilClass)
                        ... or ...
                        if obj.is_a?(Float)
                        An example in Ruby of validating that an object reference call responds to a certain method call:
                        if obj.respond_to?(:methname)
                        ... and testing for the "asterisk" method specifically:
                        if obj.respond_to?(:*)
                        I don't know (offhand) as I avoid Macs myself. (But OSX and MS Windows use different sets of keycodes.)
                        Actually, looking at the backtraces (in your original error listing) the errors are kicked off by a LButtonDown keypress, but are occurring in the `` create_timber_geometry()`' method, lines 1064 and 1355.
                        • 2 / 2
