    HTMLDialog vs WebDialog?
    23 Posts 5 Posters 7.5k Views 5 Watching
      driven
      @garry k said:
      I use JQuery - not JsFiddle.
      JsFiddle is an online test environment...
      you can even test your jQuery in it...
      if you launch it from within SU it quickly shows if code works in the SU browser of your running [IE/Safari/CEF]...
      to test you use set_url and add code too see what flies...
      both your issues work in CEF using vanilla js inside SU, so are most likely jQuery needing updating...
      • Dan RathbunD
        Dan Rathbun
        @garry k said:
        Also the Enter key doesn't trap while you are inside a drop down list.
        But when the user (in CEF) hits ENTER on an <select><option>, that changes the selection does it not ? And therefore it should fire the some event ?
        I just tested in normal Chrome and the ENTER key works fine.
        http://jsfiddle.net/wkpeq/73/
        <!DOCTYPE html>
        <html>
            <head>
                <script>
                    function CheckKey(e) {
                        var code = e.keyCode ? e.keyCode ; e.which;
                        if(code === 13) {
                          alert("You press Enter key.");
                    function SubstanceChangeHandler(val) {
                      alert("New substance chosen; "+val);
                      txtTest.value= val;
                </script>
            </head>
            <body>
                <input name="txtTest"  type="text" id="txtTest" onkeyup="CheckKey(event)"/>
                <select onchange="SubstanceChangeHandler(this.value);">
                  <optgroup label="Alkaline Metals">
                    <option>Lithium (Li)</option>
                    <option>Sodium (Na)</option>
                    <option>Potassium (K)</option>
                  </optgroup>
                  <optgroup label="Halogens">
                    <option>Fluorine (F)</option>
                    <option>Chlorine (Cl)</option>
                    <option>Bromine (Br)</option>
                  </optgroup>
                </select>
            </body>
        </html>
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @garry k said:
          Also I moved the form while the drop down list is open and now you can't tell which drop down I was in. The difference is IE closes the drop down when you click and drag the form - chrome does not.
          Let us try some tests to see if we can get Chrome to close the <select> droplists.
           <body onmouseout="document.blur();" onmouseover="document.focus();">
          I'm hoping this will cause the current active selection element to lose focus and have it's blur event fire.
          If this does not work, then perhaps keep track of the current object that has focus:
          <!DOCTYPE html>
          <html>
              <head>
                  <script>
                      // Global variable;
                      activeObject = document.body;
                      previousObject = document.body;
                      function setActive(obj) {
                          activeObject = obj;
                      function clearActive(obj) {
                          previousObject = obj;
                      function blurAll() {
                          if activeObject != document.body {
                              activeObject.blur();
                                  clearActive(activeObject);
                          document.blur();
                      function reFocus() {
                          document.focus();
                          if previousObject != document.body {
                              previousObject.focus(); // calls setActive(previousObject)
                          if(code === 13) {
                        txtTest.value= val;
                  </script>
              </head>
              <body onmouseout="blurAll();" onmouseover="reFocus();">
                          onfocus="setActive(this);" onblur="clearActive(this);">
                    </optgroup>
                    </optgroup>
                  </select>
              </body>
          </html>
          If this scenario works, you can set the onfocus and onblur handlers for all <select> elements via an iteration loop after the page loads.
            driven
            @dan rathbun said:
            Let us try some tests to see if we can get Chrome to close the select drop lists.
            using Enter or a Click closes them, if not, there is a javascript over-ride preventing default behaviour...
            • Dan RathbunD
              Dan Rathbun
              You missed the point John, he's doing neither. He is simply leaving the droplist and grabbing the window caption bar and moving the entire window. This is leaving the droplists behind (as if torn off) as shown in the screenshots above.
              My attempt to fix it would detect when the mouse leaves the body of the html document, and blur the <select> element hopefully making it close it's droplist.
              • G
                Garry K
                Thanks guys - I haven't had time to look into this yet. But what I see looks encouraging.
                  driven
                  gotcha, you mean bug SU-35701.
                  • Dan RathbunD
                    Dan Rathbun
                    Let us know if any of the suggestions work.
                    • medeekM
                      medeek
                      I have some issues with Mac users and my webdialogs. Unfortunately, I don't have a Mac computer at my disposal so I can't directly test and debug the issues but it appears to be some behavior with the blocking not working correctly in MacOS.
                      Does anyone have any suggestions on a work around for this problem.
                      I've been tempted to switch to HTMLDialog from WebDialog but I have too many people using the plugins who have older versions of SU.
                      I also don't see any distinct advantage to switching unless it will fix my MacOS problem.
                      Nathaniel P. Wilkerson PE
                      Medeek Engineering Inc
                      design.medeek.com
                      • medeekM
                        medeek
                        Here is my code for my webdialog for the timber truss feature that I recently added. I think the issues with Mac users may have to do with the dialog not being "modal" even though I am using the show_modal method:
                        # Create the WebDialog instance
                        if @Licensemode == "trial"
                          dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin - (trial version)", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
                        else
                          dlg1 = UI;;WebDialog.new("Timber Truss Geometry - Medeek Truss Plugin", true, "SelectionInfoPrefKey", 1210, 860, 500, 250, true)
                        dlg1.add_action_callback("PUSHTOHTML_SETTINGS") {|dialog, params|
                          js_command = 'pushdata( "' + @Trusstype.to_s + '|' ....  .... '|' + @Panel.to_s + '" );'
                          # puts js_command
                          dialog.execute_script(js_command)
                        dlg1.add_action_callback("GET_SETTINGS") {|dialog, params|
                          params = params.to_s
                          # puts params
                          paramlist = []
                          paramlist = params.split("|")
                          @Trusstype = paramlist[0]
                          @Span = paramlist[1]
                          if @Span == ""
                            @Span = @TrussSpan_ft
                          else
                            @Span = @Span.to_f
                          @Panel = paramlist[20]
                          if @Panel == ""
                            @Panel = @Span * 12.0 * 0.25
                          else
                            @Panel = @Panel.to_f
                        dlg1.add_action_callback("CLOSE_DIALOG") {|dialog, params|
                          dialog.close
                        # Find and show our html file
                        dlg1.set_file File.dirname(__FILE__) + "/html/web_dialog_timber_truss.html"
                        dlg1.show_modal()
                        design.medeek.com
                          driven
                          can you add a link to the version showing issues...
                          without the html and params it's impossible to guess the issue...
                          I doubt it has anything to do with modality of the window...
                          • medeekM
                            medeek
                            The html code is rather large due to the insane amount of javascript that is used to generate the SVG preview so rather than post it on the board it can be viewed here:
                            404 - File or directory not found.
                            (design.medeek.com)
                            Just take a look at the source code of this page.
                            The version of the plugin having the issues is 1.9.8, download here:
                            (design.medeek.com)
                            design.medeek.com
                              driven
                              are they seeing errors like this?
                              the `onLButtonDown' doesn't finalise before the dialog shows, and then creates and new dialog when you click again...
                              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
                              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
                              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
                              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
                              /users/johns_imac/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
                              • medeekM
                                medeek
                                I will check with the user who reported the error and see what I come back with. Thank-you for helping me look into this.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Error; #<NoMethodError; undefined method `*' for nil;NilClass>
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1064;in `create_timber_geometry'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;801;in `get_truss_geometry_timber'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;1103;in `main_menu'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5705;in `calculate_obj'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5718;in `update_state'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_roof_truss.rbs;5726;in `onLButtonDown'
                                  Error; #<TypeError; String can't be coerced into Float>
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `+'
                                  /users/momdad/library/application support/sketchup 2017/sketchup/plugins/medeek_truss_ext/medeek_timber_roof_truss.rbs;1355;in `create_timber_geometry'
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    The error codes posted above.
                                    design.medeek.com
                                    • Dan RathbunD
                                      Dan Rathbun
                                      ... are occurring (according to your error messages,) in " medeek_roof_truss.rbs", line 5726, in callback method onLButtonDown.
                                      In the first you are calling a *() method upon an object that is referencing the global singleton nil object. Since the NilClass does not have an "asterisk" method, a NoMethodError is raised.
                                      The second method is caused by your code expecting a Float object, but getting a String object instead.
                                      The answer is simple. Whenever an object reference could reference disparate types (classes) of obejcts, use a combination of type validation and Ruby rescue clauses with the onLButtonDown callback method.
                                      • medeekM
                                        medeek
                                        Okay 95% of that just went over my head, but I'll try and decipher into terms I can understand.
                                        But why would this error only be raised for SketchUp running on MacOS and not Windows?
                                        design.medeek.com
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Basically I'm trying to prompt you to learn how to read Ruby error and backtrace messages.
                                          “filename:lineNo: inmethod”‘ or “filename:lineNo.”`
                                          http://ruby-doc.org/core-2.2.4/doc/syntax/exceptions_rdoc.html
                                          http://ruby-doc.org/core-2.2.4/Exception.html
                                          Data validation - Wikipedia
                                          (en.wikipedia.org)
                                          An example in Ruby of testing if an object reference is pointing at an object of a certain class:
                                          if obj.is_a?(NilClass)
                                          ... or ...
                                          if obj.is_a?(Float)
                                          An example in Ruby of validating that an object reference call responds to a certain method call:
                                          if obj.respond_to?(:methname)
                                          ... and testing for the "asterisk" method specifically:
                                          if obj.respond_to?(:*)
                                          I don't know (offhand) as I avoid Macs myself. (But OSX and MS Windows use different sets of keycodes.)
                                          Actually, looking at the backtraces (in your original error listing) the errors are kicked off by a LButtonDown keypress, but are occurring in the `` create_timber_geometry()`' method, lines 1064 and 1355.
