    How to remove a chamfer on a box?
    34 Posts 9 Posters 4.7k Views 9 Watching
      The icon "F" of the Join Push Pull Interactive by Fredo makes the trick
      for 2 faces around a chamfer! πŸ˜„
      A sort of smart Push Pull! πŸ€“
      So all faces in addition to the 2 faces
      around the chamfer can have any orientations!
      Maybe 2 Guides lines are necessary for the intersection!
      because seems interferences don't works inside the plugin itself!
      Alas it's only 2 faces by 2 faces! πŸ’š
      • chippwaltersC Offline
        chippwalters
        [attachment=0:x9keu75d]<!-- ia0 -->GIF_iconef.gif<!-- ia0 -->[/attachment:x9keu75d]
        Brilliant! Once again, creative thinking by the French! And the solution I was hoping for by posting this challenge. Much appreciated πŸ˜„
        Currently working with Cross-Reality technologies
          chippwalters
          @kimi kimi said:
          Here is my method (I'm not good at making GIFs):
          1. Select all the main or big faces
          2. Copy
          3. Select everything
          4. Delete
          5. Paste in place
          6. Offset, offset, offset on the outside, all of them
          7. Clean up with CleanUp
          8. Select all- intersect with selection
          9. Select those big faces again
          10. Copy
          11. Select all
          12. Delete
          13. Paste in place.
          Seems complicated, but it isn't.
          Another fine fine solution. Thanks for your help!
          • JQLJ Offline
            JQL
            I usually do the following:
            1 - select all;
            2 - remove big faces from selection;
            3 - group and delete group;
            4 - use tak2hata extend trim faces plugin;
            5 - then cleanup plugin if needed for merge faces and repair edges.
            Step 4 is the one that needs getting used to.
            www.casca.pt
            Visit us on facebook!
              When you say
              it's not more little faces so the chamfer(s) ?
              No clean up necessary!
              Cool but again it's face by face! πŸ˜‰
              Here zoom is needing for more precision to click the face + segment! πŸ€“
              • JQLJ Offline
                JQL
                @pilou said:
                When you say
                [attachment=0:2ikvu9kh]<!-- ia0 -->GIF_extend.gif<!-- ia0 -->[/attachment:2ikvu9kh]
                sorry I fotgot about the generate faces plugin. I use the one from tools on surface.
                And I really meant rwmove big faces from selection. They are easier to pick and if you remove them when you create the group, it becomes composed pnly of all small faces. Then, When you delete the group you delete only the small faces and keep the big ones.
                1 - select all;
                so, after review, I still thin the fastest method is:
                1 - select all;
                5 - Generate faces using a plugin (tools on surface is my choice)
                6 - then cleanup plugin if needed for merge faces and repair edges.
                It does require manual work, but all do until now, and this is the easiest I know, and I tried a lot.
                www.casca.pt
                  chippwalters
                  @jql said:
                  @pilou said:
                  When you say
                  [attachment=0:3jt9ho9s]<!-- ia0 -->GIF_extend.gif<!-- ia0 -->[/attachment:3jt9ho9s]
                  1 - select all;
                  1 - select all;
                  Interesting. This looks like a good strategy for removing both fillets and chamfers from more complex shapes. My favorite so far!
                    1 - select all;
                    A little video of these 6 steps will be fine!
                    I am a little losted in the fog! πŸ˜„
                      chippwalters
                      Frenchy,
                      One of the reasons why I really enjoy using SU... the community. I figured by posting this simple challenge, I might be able to learn some new stuff-- and I certainly have! This is a really great workflow by JQL (thanks!) and here's a video of how it works.
                        A little more enlighting! β˜€
                        • JQLJ Offline
                          JQL
                          yes, video is better thqn talk, however there are a lot of steps in the video that could be faster.
                          I'll try making a little gif after holidays
                          www.casca.pt
                          • 2 / 2
