    How to round narrowing line?
    7 Posts 4 Posters 1.0k Views 4 Watching
      dihe
      Hi there,
      I'm looking for some solutions maybe plugins with help me to round narrowing lines.
      Round corner wan't round prettily when two lines meets in sharp corner.
      http://i63.tinypic.com/eprkfb.png
      now
      http://i65.tinypic.com/2eai6i8.png
      after round corner
      I want to achieve this effect:
      http://i63.tinypic.com/zn0pae.png
      Have you some idea how to made that?
      • pbacotP Offline
        Is that really what you want? By your photo I would think it'd be something like the attached pic. Round corner can do the rounding--as long as the faces are not too small. If too small scale it up temporarily for the operation. But for what you show in the model I don't have a plugin. I think it might require subdivision and smoothing operations.
        • HieruH Offline
          Hieru
          If you do actually need a completely smooth transition, then you'll have to use SubD or Artisan.
          Here's a quick basic shape to play with.
          Wedge.skp
          www.davidhier.co.uk
            dihe
            Thank you Hieru,
            Quad modeling will be what I need. Your model is very ditailed. do you use some other specyfic plugins to speed up the proces of quad preparing?
            • HieruH Offline
              Hieru
              I think the model is deceptively detailed...it only took a couple of minutes to create using the Line tool, Offset and the Split Tools plugin.
              For more complex forms I use Quad Face Tool, Vertex Tools, Split Tools and Zorro extensively. Solid Inspector is also handy for finding unwanted faces and internal geometry.
              www.davidhier.co.uk
              • fredo6F Offline
                Some users believe that RoundCorner could help in creating a control mesh for subdivision.
                So I started a discussion here.
                First thing is to understand how this would work in some general cases, though simple.
                  dihe
                  Thanks Fredo,
                  I think if you would like to improve something in plugin, maybe is to allow change diameter of round corner when two lines (maybe selcted) will be approaching each other.πŸ˜„
                  But use round corener to construction for quad faces method is also atractive. Unfortunately I heard yesterday about quadfaces, and my knawledge about this method is... hmm poor
