    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 58.4k Views 40 Watching
    • sfto1S Offline
      sfto1
      I have a similar problem with SketchUV
        kaas
        same with PB and Artisan.. must be bought-plugins-with-multiple-email-accounts-problem again...
        • jujuJ Offline
          juju
          A quick fix for this problem is to, from within SketchUp, log out of your SketchUp / Trimble account and log back in.
          • FrederikF Offline
            Frederik
            Already tried that trick - unfortunately without any success... πŸ˜•
            Even re-started SU and also tried signing out, closing SU, restarting Windows, started SU, signed in to the Extension Manager - no luck... 😞
            I don't have any issues updating other extensions like Skatter, Skalp, SUbD, Laubwerk, 3skeng Thea4SU etc... etc...
            I'm far from a novice with this, yet I can't get the update for Profile Builder 2 to work... 😞
            Cheers
            Kim Frederik
            • PixeroP Offline
              Pixero
              @Frederik: Have you tried deleting the session.dat file here?
              C:\Users\user\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp
              Also log out from your browser if you are logged in there as well.
              I think it is embarrasing for the SketchUp Team that they can't get this to work.
              The SketchUcation extension manager works soo much better IMHO.
              • FrederikF Offline
                Frederik
                I had not tried that until now...
                There wasn't any "session.dat" file...
                (Before you ask... Yes, I know it's a hidden folder, but I have enabled viewing hidden files and folders and I know where to look, what to do etc. but the file wasn't there...)
                I know you wanted to help me, Jan, which I appreciate, but still no luck... 😞
                I fully agree...!
                But why is this the only extension I have this issue with...? πŸ˜•
                I have Profile Bulder 2 (2.1.5)
                Can someone confirm that there's a newer version available...?!?
                Cheers
                Kim Frederik
                • jujuJ Offline
                  juju
                  I had the same as you Frederik, but the logging out and back in worked for me (phew!).
                  I don't know what changes were made to PB2 and Artisan with the updates, versions report as follows:
                  • Artisan: 1.3.0
                  • PB2: 2.1.7
                  • FrederikF Offline
                    Frederik
                    Cheers, Juju! πŸ‘
                    I also have Artisan and it updated without the message, so I've got Artisan 1.3.0
                    But the update of PB2 certainly won't work for me... πŸ˜•
                    Cheers
                    Kim Frederik
                    • W Offline
                      Whaat
                      @frederik said:
                      Cheers, Juju! πŸ‘
                      Hello everyone,
                      The Extension Manager can only be used to updated PB2 if you have purchased PB2 from the Extension Warehouse. Otherwise, you can always download the latest version of PB2 from here:
                      Download Profile Builder
                      Profile Builder 4 (profilebuilder4sketchup.com)
                      Note: Version 2.1.7 (just released) just contains a few minor bug-fixes.
                      More information can be found here:
                      http://profilebuilder4sketchup.com/faq/
                      • FrederikF Offline
                        Frederik
                        Thanks, Whaat...! πŸ‘
                        Everything works fine now and I don't get the nagging window informing me that I have an outdated extension that needs to get updated... πŸ˜„
                        Cheers
                        Kim Frederik
                          rv1974
                          Whaat will we see a new major version in 2017?
                            rv1974
                            Whaat please add reverse toggling (with keyboard) while creating.
                            • pep75P Offline
                              pep75
                              I'm having an issue with Profile Builder which is very annoying. When browsing in profile folders I can't see their names in the upper row. Can I change this? Is there a solution?
                              • jujuJ Offline
                                juju
                                your monitor setup, do you use some sort of scaling factor / %?
                                • W Offline
                                  Whaat
                                  You just need to stretch out the size of the window. The size of the window should be saved for next time you open it. Is this not happening for you?
                                  • pep75P Offline
                                    pep75
                                    Thanks for you replies! Scaling is set to 100% (I've a 2560x1440 screen). When I drag the window and try to scale it the upper folder names stay hidden...that's doesn't do anything. I'v tried a lot to solve this however...😞
                                    • W Offline
                                      Whaat
                                      Can you post a screenshot or a video of your window with the window width increased?
                                      • pep75P Offline
                                        pep75
                                        Hey Whaat...when click on the full-screen button in the window(square button) it's fully visible...and when I reopen the dialaog it's okay again (??!). Well fixed. Sorry to have you bothered!!! Feel like a noob now! πŸ˜• Thanks!!!
                                        • W Offline
                                          Whaat
                                          OK then! Thanks for letting me know it is working!
                                          • pep75P Offline
                                            pep75
                                            πŸ˜„) Thanks again!
                                            • 11
                                            • 6 / 11
