    Geo-location and Solar North
    14 Posts 3 Posters 2.5k Views 3 Watching
    • pbacotP Offline
      Why should you need to set the Solar North angle if the model is geo-referenced? (I'm assuming there's reasonable accuracy in this SU feature)
      Perhaps the north (green axis) in "Find Location" is the local grid north--which isn't the same as solar north--or am I mistaken? Would be nice if Trimble could provide more technical information on this. Maybe this should be handed over to your surveyors to figure out. If our present day surveyors can't match Stonehenge we're in trouble.
        Hmmm... I wrote a reply and it disappeared. 😞
        Solar North and True North don't necessarily coincide. Maps are set up for True North, not Solar North.
        Solar North occurs when the sun is at its zenith. We generally think of that as occurring at noon but the actual time it occurs depends upon where in the time zone your model is geo-located.
        • sfto1S Offline
          sfto1
          So, I should reasonably expect real world shadow behavior similar to the shadows generated in a geo-located model if I convey construction staking coordinates based off of True North???
            Yes. I would think you should.
            • sfto1S Offline
              sfto1
              Thanks Dave!
                You're quite welcome. I hope the monument gets installed correctly. You could mount it on a large lazy Susan so it can be rotated to face the sun as needed. Sort of a real life Face Me component. πŸ˜„
                • pbacotP Offline
                  Thanks Dave. Good to know.
                  • sfto1S Offline
                    sfto1
                    It might come to that β˜€
                    One more question. The Longitude and latitude appears to be in decimal format. Is that everyone else's understanding? As in 45.37770 degrees not 45 degrees 37 minutes and 77 seconds.
                    Surveyor asked for a clarification.
                      Yep. Decimal format for Lat/Long.
                      • sfto1S Offline
                        sfto1
                        Then I believe I'm set.
                          Perfect.
