    3D Truss Models
    1.5k Posts 31 Posters 977.2k Views 30 Watching
    • medeekM Offline
      medeek
      Here we go again:
      Just a moment...
      (www.kickstarter.com)
      After a dismal turnout for the original truss plugin campaign I never thought I would consider another kickstarter campaign. However, I have recently been contacted by various companies/organizations seeing if I could further develop the plugins so they could use them on a almost daily basis. Based on these conversations I can see there is a real need for this type of modeling and the momentum appears to be picking up.
      Another critical piece is my own level of knowledge and skill set with the SketchUp API. After spending the last two years working through the truss plugin I feel that I've finally reached a point on the learning curve where I am able to bring a lot to bear and ultimately push the development to a critical mass.
      My limiting factor now is only my time and in order to devote more time to the project I need some backing.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        MtnArch
        Added my (continued) support to your Kickstarter campaign!
        Highest Regards,
        Alan T. Hendry, RA
        Architect
        • medeekM Offline
          medeek
          Thank-you, to everyone who is supporting me on this latest Kickstarter Campaign. I'm approaching it with guarded optimism.
          There is so much more that needs to be done I almost don't know where to start some days.
          This morning I was thinking about a face/polygon tool for the floor joist / floor truss feature in the plugin. I now have all of the widgets in my tool belt to make this happen. That one should actually be a fairly easy endeavor, I might hit it hard this weekend and see if I can knock it out.
          The potential complication with a polygon outline and floor trusses is how best to handle the chase that typically runs through the middle third of the truss. With a polygon outline you will have multiple groups of trusses at different spans, does the central chase typically line up across all these various truss spans. Any clarification or examples on what is typically seen in construction would be helpful.
          With I-joists and solid sawn floor joists no such problem exists so it is a simple matter to set this up now that I have the boolean operation problem licked.
          design.medeek.com
          • medeekM Offline
            medeek
            I was about to start work on the Wall Plugin and then the straight skeleton sucked me back in. The implementation is probably going to take some time since I'm in uncharted territory but should prove interesting.
            design.medeek.com
            • facerF Offline
              facer
              Medeek Const Library - Kickstarter Status at: 1 Jul
              Just a moment...
              • medeekM Offline
                medeek
                I've been looking at some floor truss layouts and it appears that within a given truss set or assembly the chase will line up across multiple spans as I have shown here:
                http://design.medeek.com/resources/images/truss_su248_800.jpg
                View model here:
                3D Warehouse
                (3dwarehouse.sketchup.com)
                Generating a new truss component for each separate span is not too difficult, similar to generating a new step down hip truss component every 24". One thing to note is that a polygon outline will only work for floor trusses if the angles are all orthogonal, at least the bearing walls where the trusses terminate.
                I'm a little unclear how to deal with the ladder trusses at the transition between different spans, perhaps someone has a 3D model or pictures giving me some clarity in these areas.
                It took me about 15 minutes to create this complex floor truss set using the rectangular floor truss tool (3 separate truss sets) and the trim tool, not terrible but it would be so much better if I could achieve the same result in a matter of seconds with no manual editing.
                Cutting holes in the floor and having the hole cutting tool able to regen the proper trusses is also a hot item related to this discussion. That would make the floor truss feature actually functional as a real world design tool.
                Another issue is multiple chases within a truss set. One central chase seems the most typical but two chases positioned within the central third of the truss span also appears to be quite common. So far I have not seen more than two chases in a given floor truss span, probably for good reason. The ability to create two chases rather than just one is now on the "todo" list.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Tutorial 5: Hip Truss Sets (24:32 min.)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    On my Kickstarter campaign there was a recent comment regarding the pricing of my plugins. I have been giving this some thought recently and I thought I might also share my remarks on the board as well:
                    I agree that there is certainly an argument that I charge too little for these plugins and I have wrestled some with this problem. Others have also privately messaged me or emailed me with similar remarks and recommended that I bump my prices, sometimes tenfold.
                    The current reasoning behind my low pricing structure can be summarized with the following points:
                    1.) All of these plugins are currently in a developmental phase. Unfortunately, I have not been able to exert my full time efforts at this development so progress has been slow. I find it hard to charge a "fair amount" for a product that in my mind is still flawed and imperfect. My "todo" list is currently about 60 items and written out covers about 2 pages. To charge a "professional" price requires that one provide a "professional" service or product, I don't feel like I'm there yet.
                    2.) I have looked at some of the competition such as Pluspec and others who charge considerably more than I do. Again the sophistication of the their product exceeds my own so the price differential is warranted. But more importantly I'm not a huge fan of pricey design software, that is what has led me to SketchUp in the first place. The SketchUp community in general has adopted this mindset (in my opinion) and I don't feel that they would get behind an expensive solution.
                    3.) I am also trying to keep the plugin within the reach of the casual user (DIY'er), someone who simply wants to model up a single house or garage for their own personal use. In some cases the trial version of the plugin(s) will work for that but I have recently limited it quite strictly so any serious design work will require a registered license.
                    4.) I have also considered a subscription model, but my own distaste of that licensing mode has kept me from going down that road. Once your purchase a software you should be able to use it indefinitely as it stands. Additional payment should only be required if you are requesting an update or added functionality.
                    5.) What better way to discourage copy cats and the competition to price it too low as to make it worth their while. No one in their right mind will try to recreate what I have done with trusses when the payback is so little and the effort is so large.
                    With all of that being said I do think that the sweet spot, which still meets the requirements of the above points, may still be a bit higher than what I am currently charging. I need to find the correct amount to charge so that the above points are carefully balanced with the fact that I need to be able to justify the amount of time and effort I spend in developing these products.
                    design.medeek.com
                    • pbacotP Offline
                      Good points. Nathan. I like your approach, Keeping it powerful but simple.
                      • facerF Offline
                        facer
                        Medeek (aka Nathaniel Wilkerson)
                        I agree with your arguments Medeek.
                        As your software develops and has gained a "foothold" you can always
                        offer the "Pro Version" which will have applications suited for professional users
                        but at a "higher price".
                        I also think you just "love construction engineering" and want to share it with the world 😄
                        By dropping your "pebble" into the universe who knows where it will lead.
                        Keep up the good work!
                        Your Kickstarter is "best value for money yet"!
                        • medeekM Offline
                          medeek
                          If I ever do build my office I was thinking of doing some sort of cedar siding and then putting my logo or some of my other designs on the exterior:
                          http://design.medeek.com/resources/images/truss_su249_800.jpg
                          View model here:
                          3D Warehouse
                          Some of my other designs are here:
                          http://www.wilkersonart.com
                          design.medeek.com
                          • facerF Offline
                            facer
                            Medeek Const Library - Kickstarter Status at: 8 Jul
                            Just a moment...
                            • medeekM Offline
                              medeek
                              Version 1.9.4 - 07.08.2017
                              • Added energy/raised heels for triple howe truss (3 variant: wedge, slider and vertical w/ strut).
                              • Metal plate connectors now enabled for triple howe trusses.
                              http://design.medeek.com/resources/images/truss_su250_800.jpg
                              Below would be a typical example of a 60' span using a triple howe truss.
                              http://design.medeek.com/resources/images/truss_su251_800.jpg
                              However, in most cases where the design calls for taller walls one would probably go with a steel building or CMU block walls. This was the case on a building I designed about 10 years ago (Wasatch Building Supply, Utah) that had 20 ft. walls. Its too bad I don't have an interior photo showing the trusses inside the warehouse roof, its quite a sight to behold.
                              http://design.medeek.com/gallery/COM10060_LINDON_2006/COM10060_LINDON_2006_480.jpg
                              Google Maps
                              Find local businesses, view maps and get driving directions in Google Maps.
                              Google Maps (www.google.com)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I'm trying to roll a new revision of the plugin but the Extension signing page is not working:
                                SketchUp Extension Warehouse
                                Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                (extensions.sketchup.com)
                                It won't generate the 2015 and earlier encryption for some reason, any one else notice this problem?
                                design.medeek.com
                                  glro
                                  @medeek said:
                                  ...I'm not a huge fan of pricey design software, that is what has led me to SketchUp in the first place. The SketchUp community in general has adopted this mindset (in my opinion) and I don't feel that they would get behind an expensive solution.
                                  just a few ideas i had, after reading your post:
                                  you only think about the price user would have to pay for using your plugins, but it is not the only parameter; there is another one, as important, and it is how much money the user can make by using your plugin; so that the real price of your plugin is not the price the user pays, but the difference between the money he makes minus the price he paid
                                  this leads me to another idea: writing code is fun, but it may be contradictory to the goal of making a business through coding; one have to be clear: if really it is about making a business through coding, development should be focused on what makes added value for the user, so that he might be willing to pay for the plugin.
                                  your plugin is very specific to wood structure in USA; i work as a structural engineer in Europe, so i have some knowledge about wood structures, but i don't understand the words you use to explain the specificites of your plugin. If you want to make your audience larger, maybe a good idea would be to use more generic words and concepts.
                                  Those are just ideas, i don't pretend anything, but i am puzzled by the contradiction between the amount of work you put in this plugin, and the low audience you get so far
                                  • medeekM Offline
                                    medeek
                                    Version 1.9.5 - 07.11.2017
                                    • Added energy/raised heels for quad fink truss (3 variant: wedge, slider and vertical w/ strut).
                                    • Metal plate connectors now enabled for quad fink trusses.
                                    http://design.medeek.com/resources/images/truss_su252_800.jpg
                                    This concludes the updates needed for common trusses. I still have a number of updates for all the other truss types to bring them up to speed.
                                    design.medeek.com
                                    • facerF Offline
                                      facer
                                      Medeek Const Library - Kickstarter Status at: 15 Jul
                                      https://www.kickstarter.com/projects/128644708/medeek-construction-plugin-library
                                      • TandemT Offline
                                        Tandem
                                        Excellent news for all licensed users of the Medeek Truss Plugin.
                                        Nathaniel just added additional pledges to the Medeek Construction Library KickStarter project.
                                        If you have an existing Truss Plugin license and pledge $20 or more you will receive a license for the upcoming Construction Library.
                                        The Construction Library will include:
                                        • Truss Plugin
                                        • Foundation Plugin
                                        • Wall Plugin (Pre-release)
                                          with the following plugins to be added in the future:
                                        • Structural Plugin (Engineering)
                                        • Deck Plugin
                                        • Stair Plugin
                                        • RC Plugin (Reinforced Concrete)
                                        • medeekM Offline
                                          medeek
                                          Making a slight detour back to the wood gusset plate question and nail spacing:
                                          What I would like to compare is the following:
                                          http://res.cloudinary.com/engineering-com/image/upload/v1500572300/tips/nailpattern_bffbuj.jpg
                                          Same amount of nails in each test specimen. The tighter nail spacing allows for 66.6% the gusset length versus the 2 row configuration.
                                          Any one want to venture a guess which one is stronger and by how much?
                                          I just need to figure out a test rig and then load these two up and see what happens.
                                          For a DF main member and OSB (7/16) I get 173.7 lbs per fastener (double shear) or a total of 1,389.6 lbs for eight (8) 10d fasteners.
                                          I'm wondering how much the connection will stretch at this design load (loaded in pure tension, parallel to grain of main member) and at what load will it fail, then compare the results from both configurations.
                                          design.medeek.com
                                          • TandemT Offline
                                            Tandem
                                            My guess would be that the offset nailing pattern would be stronger in tension maybe by 20%.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 75
                                            • 76
                                            • 22 / 76
