    Select by Material?
    11 Posts 8 Posters 16.3k Views 8 Watching
    • chippwaltersC Offline
      chippwalters
      Is it possible to select all faces for a given material? So that I could delete them, or copy them, or group them? TIA, Chipp
      Currently working with Cross-Reality technologies
        Go to your material browser > In model and right click on a material and choose "Select". It will then select all faces with the same material but only in the context you are in i.e. if the faces are within a group, and you have painted them within the group's context, they will not be selected. If you have painted the group as a whole (from outside) however, the whole group will be selected. This will work even if some faces were painted from inside and then you closed the group and painted the rest from outside.
          chippwalters
          Thanks. So, then I suppose there's not an easy way to select all the faces in disparate groups which have the same material. It makes sense as editing faces in groups is modal.
            If you want to change the material on all faces, you can always reload another one instead. If the faces are in components, they can be edited easier - you just edit one and the changes will be made in all instances.
            • plot-parisP Offline
              plot-paris
              can you tell me how to reload a colour? I only know how to edit it.
              ah, yes. and is it possible to exchange one?
              (eg. you have three colours. now you want colour1 to be painted in colour2 - meaning, every face in colour2 will stay that way, but every face in colour1 will be painted in colour2)
                Well, for textures, you can always choose an option in the Edit dialogue to use a texture selected from elsewhere (this is kind of "reloading").
                For simple colours, there is the "match colour on screen" or "match colour of object in model" when you would end up using your colour2 although there would still be two colours listed in the material dropdown in your model. Even is you rename the second one to match exactly the name of the first one, there are two of them
                True that this would lead to "sloppy modeling" but at the very end (say before deadline), with a complex model you may be happy with it. πŸ˜’
                  alz
                  Related option: http://www.smustard.com/script/Repaint
                  • F Offline
                    fullyfledgeded
                    this isn't mine. cant remember where i got it from either, but works on the latest version of SU
                    material_selection.rb
                    • ntxdaveN Offline
                      ntxdave
                      I have been trying to clean up the materials in a model. I have tried this several times and it only seems to work part of the time. I have several materials that when I select them, right click on the material, then click on Select nothing shows. I have tried purging the model of unused items and these materials still hang around. I really need to clean up the materials in my model but so far have found nothing that really works.
                      I am running 2017 Pro on Windows 10. Any suggestions?
                      Press F1...thank me later
                      • F Offline
                        faust07
                        For this purpose I first use thomthoms Material Tools (v2.7.1):
                        "Remove From All Edges", "Remove All Backface Materials" etc..
                        Then I purge unused materials with the default material tool.
                        • genma saotomeG Offline
                          genma saotome
                          I've always wanted SU to have a native select untextured faces. I'm surprised it has never been added.
