    Black rendering "buckets" + splotchy areas
    renderpluginsextensions
    5 Posts 3 Posters 991 Views 3 Watching
    • omiKronO Offline
      omiKron
      Hello,
      I'm encountering an issue in V-ray 3.4 - some areas of rendering are black and some with splotches - reflection areas etc.
      At first I tried to move the camera, thought it was a camera issue. Then I thought it is because of texture transfer rate - V-ray and SU are installed on my SSD and the model is on the HDD - moved the model to SSD and tried render from there, with no result. And I'm not using Swarm either.
      Any idea what it is and how to solve it?
      • kimi kimiK Offline
        kimi kimi
        To make sure, you let it finish and this is how it turned out? You didn't save the image half way through rendering?
        • omiKronO Offline
          omiKron
          Yes. Event tests have the same result. Tried to separate the model on layers and hide useless objects too, but with no result.
          *attached a complete saved image.
          • omiKronO Offline
            omiKron
            Anyway...
            I solved it. For further notice, watch what models you copy/ import in your sketchup or they might waste your scenes and your nerves.
            The whole thing was a model with some unknown properties that I copied inside my Skp. I made a backup before that change in which V-ray worked without a problem so I'm using it carefully.
            • andybotA Offline
              andybot
              Definitely a good reminder to use the wipe clean tool on models imported from other sources. Glad you figured it out.
