    Wish list for Sketchup 2018
    125 Posts 50 Posters 204.2k Views 50 Watching
    • sicksickisckS Offline
      sicksickisck
      πŸŽ‰ Blender/Cycles render engine + node wrangler/ in Sketchup! this is sound like Christmas...
        pipingguy
        bigger close-out button for model info box.
          TBoy
          In "Metric world" it is usual length to be measured in cm or mm, but area in sq.m or bigger units (not sq.cm or sq.mm) that's why in "Model Info > model units" must be separate independent field for area units.
          • pep75P Offline
            pep75
            Please add Material NAMES in the materials list!!! Now you've to hoover over to see its name. I can't believe that they still haven't done so. 😞
              pipingguy
              A choice for non-instantaneous transitions when toggling between camera views would be good. (just like the adjustable scene transitions)
                pipingguy
                Wish for the ability to automatically re-select previous selection set.
                  pipingguy
                  Ability to snap to an inference when using the move tool to extend or retract the end of a cylinder. Currently, one needs to punch the appropriate arrow key, or hold the shift key, to make this work.
                    pipingguy
                    I wish any contents contained within a group or component's instance field can be automatically omitted as an option when exporting a model in 3D form to AutoCAD. Otherwise, they become displayed as text objects that are not easily erased.
                    • david_hD Offline
                      david_h
                      I've been saying this since version 5. It would be nice to have control of visibility nested components and groups so I can alter a component and see the just next nest level up rather than all or nothing.
                      but. . .maybe I'm the only one.
                      • O Offline
                        onthescene
                        Have default template option that allows Tray Components > "In Model" as default save. I hate having the "Components Sampler" as the default open option.
                        Have default template option that allows Tray Materials > "In Model". Somehow Mine always opens a "wood" folder.
                        I have tried creating a templates, saving the trays with "in model" as last opened, but new files always open to the above mentioned folders.
                          pipingguy
                          Wish for LO to have a previous "camera" view feature like SKP - and with non-instantaneous transition time. Similar to AutoCAD's VIEWBACK command.
                          Wish for LO to get rid of the carriage return associated with copying text from a label or text annotation object. After I paste the string into the destination, I have to hit backspace.
                            pipingguy
                            Wish for LO paper not to be partially concealed by tool tray stack when shift + z is pressed.
                              pipingguy
                              Wish for SKP to permit user to place cursor on row of scene tabs and force them to scroll left or right in unison with mouse wheel sideway's toggle. Applicable mostly with numerous tabs stretching beyond workspace screen, of course.
                                pipingguy
                                Wish for LO to paste clipboard contents wherever the cursor is, like SKP does, instead of shadowing the original object.
                                  pipingguy
                                  Wish for dimension extension line gap at anchor points (offset from origin)to be adjustable.
                                    pipingguy
                                    Wish that the floating trays in SKP and LO can remain in their positions on the canvas as the window is dragged from screen to screen when you have multiple monitors.
                                      pipingguy
                                      Wish that 3d text had the option to be created unglued. even if it lasts for only a session.
                                        Until then... choose the placed 3dText and use the right-click context-menu 'Unglue'.
                                        Or place it in 'open space', where it will be unglued and 'flat'...
                                          pipingguy
                                          I never realized 3d text becomes automatically unglued when placed in open space
                                            pipingguy
                                            Wish that vertical z axis inference color could be cyan as the current blue can be construed as the black inference color.
                                            • 3 / 7
