    Creating TINs
    13 Posts 4 Posters 1.7k Views 4 Watching
      Sandbox is not inside the normal install of 2017 ? ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
      You must load it from here!
      Installed...But I don't see it! ๐Ÿ˜ฎ
      It's only for Pro version ?
      • filibisF
        filibis
        No, it's available in Make too.
        I just prefer Bezier Surface for creating such curved slopes etc.
          Else another method ๐Ÿ˜„ ("Bac ร  Sable" = "Sand Box" )
          Projections by Didier Bur
          Draw a curve with an arc circle then...
            After some headaches I have found the trick! ๐Ÿ˜›
            You must press the Button en the bottom right : "Apply Modification" of the Applications manager!
            ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
            • G
              garystan
              @sfto1 said:
              Draw a series of straight lines perpendicular to the profile you have drawn.
              Then select all of the lines and from the DRAW pull down menu, select Sandbox tools, draw from contours.
              You should then have a grouped TIN.
              Thanks. That sounds simple enough.
              garystan
              • G
                garystan
                [attachment=4:3gz1c2i8]<!-- ia4 -->tin01.jpg<!-- ia4 -->[/attachment:3gz1c2i8]
                [attachment=3:3gz1c2i8]<!-- ia3 -->tin02.jpg<!-- ia3 -->[/attachment:3gz1c2i8]
                [attachment=0:3gz1c2i8]<!-- ia0 -->tin03.jpg<!-- ia0 -->[/attachment:3gz1c2i8]
                [attachment=2:3gz1c2i8]<!-- ia2 -->tin04.jpg<!-- ia2 -->[/attachment:3gz1c2i8]
                [attachment=1:3gz1c2i8]<!-- ia1 -->tin05.jpg<!-- ia1 -->[/attachment:3gz1c2i8]
                Hmmmmmm........I'm gonna try that. Thanks
                garystan
                • G
                  garystan
                  [attachment=4:2keuyoli]<!-- ia4 -->tin01.jpg<!-- ia4 -->[/attachment:2keuyoli]
                  [attachment=3:2keuyoli]<!-- ia3 -->tin02.jpg<!-- ia3 -->[/attachment:2keuyoli]
                  [attachment=0:2keuyoli]<!-- ia0 -->tin03.jpg<!-- ia0 -->[/attachment:2keuyoli]
                  [attachment=2:2keuyoli]<!-- ia2 -->tin04.jpg<!-- ia2 -->[/attachment:2keuyoli]
                  [attachment=1:2keuyoli]<!-- ia1 -->tin05.jpg<!-- ia1 -->[/attachment:2keuyoli]
                  Will this method work with Sketchup 8 ? The reason I ask is because of the "Extrude curve with Projection" step.    Thanks
                                              garystan
                  • G
                    garystan
                    UPDATE ----------
                              I just tried your method.  Works like a charm !!!  Simple as the proverbial "1 2 3 ".
                                                          Much thanks
                                                              garystan
                      Projections by Didier Bur was existing at least from Version 6 ! ๐Ÿ˜‰
                      • sfto1S
                        sfto1
                                                              Much thanks
        garystan
                        sometimes simple is the best trick, however, as you begin to model with TINS more and more, there are some excellent plugins available to take you to higher levels of terrain modeling.
