    3D Truss Models
    1.5k Posts 31 Posters 1.5m Views 30 Watching
    • medeekM Offline
      medeek
      Version 1.9.0 - 05.27.2017
      • Added flat truss type, configurations: flat, monopitch, pitched.
      • Metric input enabled for flat truss types.
      • Added gable end trusses for flat truss types.
      • Enabled the following end details for all flat truss types: None, Overhang, Cantilever, Mansard, Parapet, Mansard w/ Parapet.
      http://design.medeek.com/resources/images/truss_su223_800.jpg
      Plates and advanced options are still in progress. With the amount of configurations available with this truss type it will probably be a while before these next elements are in place.
      The flat truss type is very configurable and with a little adjustment of parameters you can also easily create a (non-attic) gambrel truss using the flat pitched option.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Here is an example of a small commercial building with a flat truss roof (parapet):
        http://design.medeek.com/resources/images/truss_su224_800.jpg
        Download model here:
        https://3dwarehouse.sketchup.com/model/d8413377-4287-4fb3-99b9-3d200441a2fe/Commercial-Building
        design.medeek.com
        • medeekM Offline
          medeek
          The flat truss is the first new truss type added to the plugin in 11 months. This brings the total number of truss types to approximately twenty two depending on how you classify the variants of the flat truss:
          http://design.medeek.com/resources/images/truss_su225_800.jpg
          View model here:
          https://3dwarehouse.sketchup.com/model/317af74e-a52c-470b-a612-1ba7c06617f0/Medeek-Truss-Yard-4
          design.medeek.com
          • medeekM Offline
            medeek
            The flat double pitched truss allows for a user driven asymmetric ridge location as well as differing left and right heel heights. This opens up virtually any possible truss geometry even a negative pitch if one is so inclined:
            http://design.medeek.com/resources/images/truss_su226_800.jpg
            http://design.medeek.com/resources/images/truss_su227_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              I thought I was done with flat trusses but it was pointed out to me that I also need to consider top chord bearing configurations for this truss type.
              I've created a simple matrix below with top and bottom chord bearing flat trusses. I'm not sure if these make sense, please review and feel free to comment.
              http://design.medeek.com/resources/images/truss_su228_800.jpg
              The model can be downloaded here:
              https://3dwarehouse.sketchup.com/model/acee31ef-9e54-4eca-83d7-02747815ed29/Flat-Truss-End-Details-3
              Top chord bearing usually involves the following steps:
              1.) Trimming the heel web up a specific vertical amount (vertical offset).
              2.) Insertion of a secondary heel web next to the trimmed (bearing) heel web.
              3.) Trimming the bottom chord back to the secondary heel web.
              4.) The diagonal web next to the heel is slightly altered by the addition of a secondary heel web.
              5.) Certain configs require an additional heel web on the outside of the trimmed heel web: Mansard, Cantilever, Mansard w/ Parapet.
              I can easily make this all happen and open up the option for top chord bearing flat roof trusses however I want to make sure it is right first.
              design.medeek.com
              • medeekM Offline
                medeek
                The top chord bearing option is almost complete for the flat trusses. Here is a preview with a Mansard /w Parapet on the left side and a cantilever on the right side. The bearing widths can be set independently as can the parapets heights now.
                http://design.medeek.com/resources/images/truss_su229_800.jpg
                I'm not entirely satisfied with the UI for this truss type, a proper html UI would be much more intuitive but time consuming to create. Yet another important item on the todo list.
                The plugin is starting to stray into some fairly exotic truss territory.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Wood Gusset plates are on my mind this morning (for those of us crazy enough to build or own trusses):
                  http://design.medeek.com/resources/images/truss_su230_800.jpg
                  Of course this option would be pretty much useless without the engineering to size the plates and check the fasteners. I will be giving this some more thought in the near future.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I think a lot more people fab their own trusses than we realize. I don't disapprove but I do think that quality control is imperative. One bad joint in a truss can cause the entire truss to fail which in turn may cause a catastrophic failure of the roof system.
                    Some jurisdiction will require an engineer's stamp on any site built trusses, as they should, but there are many situations (ie. agri structures, small buildings) where there is no oversite by a building official or engineer. For those situations it would be useful to have an easy to use truss calculator that even the lay person could utilize and understand.
                    From my side there is some risk and liability associated with this, especially since I have no way to confirm the workmanship of the construction. If someone were to utilize my calculator and design a truss with plywood gussets, and assuming that they built it per the calculations and input the correct snow loads etc... but the construction was shoddy and it failed would I still be liable? Probably so. That is why I have hesitated on releasing the wood gusset portion of my Truss Designer (web based).
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I think I've beaten the flat truss to death but I noticed after perusing through a number of flat truss shop drawings that the modified warren is also a popular web configuration. Its not too big of a deal to enable this configuration. The flat truss will then have the option between a pratt or mod warren web configuration.
                      http://swscorp.net/wp-content/uploads/2014/08/trusses.jpg
                      design.medeek.com
                      • facerF Offline
                        facer
                        Medeek,
                        The following is not a criticism but a reflection of the difficulty of managing priorities.
                        I think the following article may apply at this stage to your development of the Truss Plugin:
                        Following article is from:
                        https://www.briantracy.com/blog/personal-success/how-to-use-the-80-20-rule-pareto-principle/
                        And yes it applies to all of us! 😄
                        *The 80 20 Rule Explained
                        Personal Success 80/20 Rule
                        The 80 20 rule is one of the most helpful concepts for life and time management.
                        Also known as the Pareto Principle, this rule suggests that 20 percent of your activities will account for 80 percent of your results.
                        This being the case, you should change the way you set goals forever.
                        What Is The 80 20 Rule?
                        As I just mentioned, the 80 20 rule is also called the “Pareto Principle.” It was named after it’s founder, the Italian economist Vilfredo Pareto, back in 1895. He noticed that people in society seemed to divide naturally into what he called the “vital few,” or the top 20 percent in terms of money and influence, and the “trivial many,” or the bottom 80 percent.
                        Later, he discovered that virtually all economic activity was subject to this principle, in that 80 percent of the wealth of Italy during that time was controlled by 20 percent of the population.
                        We can take Pareto’s 80 20 rule and apply it to almost any situation.
                        In particular, we can apply it to goal setting and productivity.
                        Download my 14-Step Goal-Setting Guide to put the 80 20 Rule into action!
                        How Does It Work?
                        If you have a list of ten items to accomplish, two of those items will turn out to be worth more than the other eight items put together.
                        The sad fact is that most people procrastinate on the top 10 or 20 percent of items that are the most valuable and important, the “vital few,” and busy themselves instead with the least important 80 percent, the “trivial many,” that contribute very little to their success.
                        How To Apply The 80 20 Rule To Goal Setting
                        Here’s what you should do in order to effectively apply the 80/20 rule to goal setting and to your overall productivity.
                        First, take a piece of paper and write down ten goals. Then ask yourself: If you could only accomplish one of the goals on that list today, which one goal would have the greatest positive impact on your life?
                        Then pick the second most important goal. What you’ll find is, after you complete this exercise, you will have determined the most important 20 percent of your goals that will help you more than anything else.
                        You should continue to work at those goals that you’ve chosen as the most valuable all the time.
                        Eat The Biggest Frog First
                        You often see people who appear to be busy all day long but seem to accomplish very little. This is almost always because they are busy working on tasks that are of low value while they are procrastinating on the one or two activities that could make a real difference to their companies and to their careers.
                        The most valuable tasks you can do each day are often the hardest and most complex, but the payoff and rewards for completing them can be tremendous.
                        Before you begin work, always ask yourself, “Is this task in the top 20 percent of my activities or in the bottom 80 percent?”
                        The rule for this is: resist the temptation to clear up small things first.
                        If you choose to start your day working on low-value tasks, you will soon develop the habit of always starting and working on low-value tasks.
                        Always Work Towards Your Main Goal
                        Finally, I want to tell you about a study that has just been done about the attitudes of rich people versus poor people in regard to goal setting. What they found is that 85% of rich people have one big goal that they work on all the time.
                        So, if you want to be wealthy, do what wealthy people do. Pick one big goal and work on it all the time, and if you do, it will change your life*
                        • medeekM Offline
                          medeek
                          Enabled mod warren webs for the double pitched flat truss configuration:
                          http://design.medeek.com/resources/images/truss_su231_800.jpg
                          The truss shown above is an asymmetric double pitched top chord bearing flat truss with a mod warren web configuration and cantilever ends. That is quite a mouthful.
                          I have not added the top chord bearing option and the mod warren webs to the other flat truss configurations yet (flat, monopitch, pitched), however I will if specifically requested.
                          As Facer has duly noted priorities are critical and there a much hotter items on the plate.
                          The stepdown hip truss set is the big one, that is next, and yes it will be a game changer.
                          The flat truss was just a primer to warm up my programming chops, its been almost a month since I was able to touch the truss plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Since about version 1.6.0 I've been tracking every installation of the plugin. The funny thing is that I see more installations of previous versions of the plugin than I do of the current version. I am wondering why that is and also where the previous version is being distributed from. It's not a huge deal but it does have me wondering.
                            design.medeek.com
                            • jujuJ Offline
                              juju
                              That is a sign of a software being worthwhile, it gets pirated (unfortunately). Maybe chat to some of the other devs (ThomThom / Whaat / etc.) about how they go about curbing this scourge.
                              • medeekM Offline
                                medeek
                                I don't know that its a sign of hacking as much as people not having access to the most recent version of the plugin. Possibly two reasons:
                                1.) The user downloads a version of the plugin and then installs it months later.
                                2.) Other websites are redistributing the plugin (older versions).
                                I don't provide links to previous versions on my website since the latest version is always better than the last, so again this doesn't make much sense to me.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  In the global settings I've added a setting to switch between metal and wood connector plates. Initially I will only enable wood plates for some of the more typical common trusses (ie. fink, howe, queen and king), if this feature proves to be popular I may enable it for more truss types.
                                  http://design.medeek.com/resources/images/truss_su232_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.9.1 - 06.09.2017
                                    • Added plywood gusset plates for common fink trusses.
                                    • Enabled a "WOOD" plate type option in the global settings.
                                    http://design.medeek.com/resources/images/truss_su233_800.jpg
                                    *Note that the wood gussets are currently only available for the Fink truss, if anyone needs them enabled for a different truss please let me know.
                                    View model here:
                                    https://3dwarehouse.sketchup.com/model/f6e1ea1b-f485-41b3-9d11-cd6d2c71087c/Wood-Gusset-Connected-Trusses
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Added plywood gusset plates for raised heel common fink trusses.
                                      http://design.medeek.com/resources/images/truss_su234_800.jpg
                                      View model here:
                                      https://3dwarehouse.sketchup.com/model/b21431bc-c3b6-4038-a81e-f27fc78f69b1/WGC-Truss
                                      Note that there are currently no calcs associated with these WGC trusses. If you are going to build your own trusses I would strongly suggest you find a local structural engineer to assist in specifying the plates sizes and fasteners, especially if the truss span is greater than 16 feet and your snow loads are greater than 25 psf in your region.
                                      When I engineer WGC trusses I will also call out a waterproof glue as well however I don't take the glue's strength into the calculations. This provides another margin of safety and also the rigidity of a glued and nailed gusset plated truss is superior in my opinion to your typical MPC truss.
                                      Every member is critical in a truss, however some are more stressed than others. Your top and bottom chords should never be anything less than a No. 2 DF. I would suggest No. 1, No. 1 & Btr. or Select Structural. The webs of a typical truss are usually stressed quite a bit less than the chords and sometimes you can get away with stud grade lumber but I would suggest DF No. 2 on all webs as well. A strategically placed knot can easily ruin an entire truss.
                                      Just as important as the materials is the level of care taken in cutting the members and assembling the truss. All joints should fit tightly together so that members in compression can bear directly on their adjacent members. Also realize that tension members may experience load reversals in high wind or seismic events so even tension members are no exception to the rule.
                                      The correct fasteners and fastener size is critical. The nails will be in single or double shear and the joint connection is relying entirely on this shear strength of the fasteners to hold together. Fasteners too close to the edge or ends of a member are not as effective, so fastener placement is also critical.
                                      I am curious how the two truss types would compare in a burn test, which one would stay intact longer. My suspicion is that the plywood gussets would char and slowly burn however the metal plates would heat up and loose their strength quickly and fail.
                                      I know most people don't do this but I would personally stress test each truss before installing it on the intended structure. Mostly what you are looking for is a uniform deflection across all the trusses so that they can load balance properly. If a truss is defective this test should help ferret out this data even though visually the truss may look acceptable.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Just for the record the algorithm to size and position the mid top chord to web plate (Plate 2) is a real piece of work:
                                        gamma2 = 3.14159265358979 * 0.5 - @Phi
                                        length2 = @Pldim2 * 0.5 -1
                                        p3x = @Swx4 + length2 * (cos(@Theta2) / cos(gamma2 - @Theta2))
                                        p3y = @Swy4 - length2 * (sin(@Theta2) / cos(gamma2 - @Theta2))
                                        p2x = p3x - (@Tcd + length2) * cos(gamma2)
                                        p2y = p3y + (@Tcd + length2) * sin(gamma2)
                                        p1x = p2x - @Pldim2 * cos(@Phi)
                                        p1y = p2y - @Pldim2 * sin(@Phi)
                                        length4 = sqrt((@Strx4 - p1x)*(@Strx4 - p1x) + (@Stry4 - p1y)*(@Stry4 - p1y))
                                        zeta2 = atan((p1y - @Stry4)/(@Strx4 - p1x))
                                        length3 = length4 * sin(zeta2 + @Theta3) / sin(3.14159265358979 * 0.5 + @Phi - @Theta3)
                                        p4x = p1x + length3 * cos(gamma2)
                                        p4y = p1y - length3 * sin(gamma2)
                                        if @Theta2 > gamma2
                                          p2x = p3x - ((@Tcd + length2) / (cos(@Theta2 - gamma2))) * cos(@Theta2)
                                          p2y = p3y + ((@Tcd + length2) / (cos(@Theta2 - gamma2))) * sin(@Theta2)
                                        Actually had to use the Sine Law: https://en.wikipedia.org/wiki/Law_of_sines
                                        Its funny because my 15 year old daughter just covered trigonometry in her math class and she told me she would never use this stuff so why learn it.
                                        design.medeek.com
                                        • pbacotP Offline
                                          Nice additions to the plugin. Impressive work too. I guess you have engineering training but what else has helped you tackle these programming problems?
                                          Peter
                                          • medeekM Offline
                                            medeek
                                            There is really very little engineering going on in this plugin, at least for now. Most of it is boolean algebra (conditional statements and a few loops) and a lot of geometry most of which can be solved with simple trigonometry. In a few cases I have to implement an iterative solution so convergence is sometimes an issue. The rest of it is simply manipulating the SketchUp API so that it produces the correct output, that is my Achilles heel.
                                            design.medeek.com
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 75
                                            • 76
                                            • 36 / 76
