    Replace Several Textures?
    32 Posts 3 Posters 9.5k Views 3 Watching
    • TNTDAVIDT
      TNTDAVID
      **Sorry TIG to come back so late, but this time I finally have time to devote myself fully to ruby. ☀
      I would have to put "@@" into all the variables, but that is certainly not the solution you advise me. 💚
      Here is the basic code written by Sdmitch, which is almost perfect:
      def handles
            @mod = Sketchup.active_model
            @ent = @mod.active_entities
            @last3 ||= '1'
            @next = @last3.next
            @next = '1' if @next == '19'
            last3_name = "#{@last3}-HANDLE"
      	  next_name = "#{@next}-HANDLE"
            if @mod.definitions[last3_name] && @mod.definitions[last3_name].instances[0]
            cd = @mod.definitions[next_name]
            unless cd
            cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{next_name}.skp")
            cd = @mod.definitions.load cmp
            @mod.definitions.find{|d|d.name==last3_name}.instances.each{|ci|ci.definition=cd}
            @last3 = @next
            else
            UI.messagebox "#{last3_name} not found."
      Before exploring your idea TIG:
      Can your solution manage multiple SKP files or the status of the handles are different for each file?
      For example :
      My Project 1 has been saved with the definition in "9-HANDLE".
      If I open this file the code must look for the definition "9-HANDLE", to replace it with "10-HANDLE".
      My Project 2 is saved in "4-HANDLE".
      If I open this file the code should look for the definition "4-HANDLE", to replace it with "5-HANDLE".
      Another example:
      If I go back with Sketchup, the code that is "4-HANDLE" will return to the "3-HANDLE" state.
      If your idea fulfills all these conditions can you write an example?
      Another idea would be to replace all the definitions that are called "Handle" in their definitions.
      For example:
      "1-Handle", "2-Handle" or "3-Handle" etc ...
      Are replaced because they contain the name "Handle" in their definitions.
      Is this easier to apply?
      If so, how will you change the code?
      Thank you in advance for your help.
      David**
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • TNTDAVIDT
        TNTDAVID
        **Hello,
        To replace several definitions with the "next name" definition, I tried this:
        def handles
              @last3 ||= '1'
              @next = @last3.next
              @next = '1' if @next == '4'
              last3_name = ['1-HANDLE','2-HANDLE','3-HANDLE']
              unless cd
              {next_name}.skp")
              @last3 = @next
              else
        But the code does not work for a list of definitions between these brackets "[]".
        How to replace a list of definitions with the definition "next name" ?
        Any help would be of great help to me.
        Cordially
        David**
        • TNTDAVIDT
          TNTDAVID
          **There is news ☀
          As my code is in a class, I tried to apply the advises of TIG, put in "@@".
          Now "@@ next" continues to evolve from 1 to 19, even if the definition that needs to be replaced is not found.
          Even if the situation is better than before, it is not perfect because the code restarts to
          "1-Handle" every time SketchUp runs.
          If the handles on the stage are defined "5-Handle", you have to click 4 times on the icon to change the handle.
          Thank you in advance for your help.**
          def Handle
              @@mod = Sketchup.active_model
              @@ent = @@mod.active_entities
              @@avant ||= '1'
              @@next = @@avant.next
              @@next = '1' if @@next == '19'
              @@last1 = "#{@@avant}-HANDLE"
              @@next_name = "#{@@next}-HANDLE"
           if @@mod.definitions[@@last1]
              @@cd = @@mod.definitions[@@next_name]
              unless @@cd
              {@@next_name}.skp")
              @@cd = @@mod.definitions.load cmp
              @@mod.definitions.find{|d|d.name==@@last1}.instances.each{|ci|ci.definition=@@cd}
              @@avant = @@next
           else
              UI.messagebox "#{@@last1} not found."
          • sdmitchS
            sdmitch
            I would suggest using attributes to keep tract of "next".
            @@avant = Sketchup.active_model.get_attribute("Handles","Last","1")
            Sketchup.active_model.set_attribute("Handles","Last",@@next)
            http://sdmitch.blogspot.com/
            • TNTDAVIDT
              TNTDAVID
              **Great Thanks sdmitch.
              The general change of all the Handles furniture is finally perfect. 😉
              I will do the same for all the components of a kitchen, sink, taps, oven etc ...
              Thanks to your help, "Click-Cuisine 2" will be even easier than ever.
              A small remark without great consequence:
              The current code does not replace the unique handles, such as "1-HANDLE # 1".
              Is it possible to circumvent the problem, if so how?
              The 2nd Great Steps is to replace the Handles of a single piece of furniture selected, without affecting other furniture.
              How would you do that?
              Any help from you is very good news to me. 😄
              Thank you
              David**
              • sdmitchS
                sdmitch
                @@mod.definitions.find{|cd|cd.name=~/#{@@last1}?/i}.instances.each{|ci|ci.definition=@@cd}
                This would be difficult indeed. The easiest way would be to move the single piece to a new model, make the changes then import it back.
                David
                • TNTDAVIDT
                  TNTDAVID
                  **Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
                  Maybe I made a mistake somewhere?
                  def poignee
                      @@last1 = "#{@@avant}-POIGNEE"
                      @@next_name = "#{@@next}-POIGNEE"
                      unless @@cd
                      {@@next_name}.skp")
                      @@avant = @@next
                      else
                  Perhaps it is more interesting not to reload the rendered unique models to find a solution to my 2nd Objective?
                  Here is a simpler idea for the 2nd Objective:
                  1 - I select a piece of furniture.
                  2 - I Click on the icon "Freeze the model". (The method that is executed makes all unique components and subcomponents of my selection.)
                  3 - I can execute the first code without changing the handles of the furniture made unique.
                  How to write this method?
                  Thanks in advance for your help.**
                  • sdmitchS
                    sdmitch
                    @tntdavid said:
                    [size=110]Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
                    def poignee
                    >     unless @@cd
                    >     {@@next_name}.skp")
                    >     end
                    >     @@avant = @@next
                    >     else
                    >   end
                    > end
                    I think you need to use the same @@mod.definitions.find when checking for existence also.
                    if @@mod.definitions.find{|d|d.name=~/#{@@last1}?/}
                    	@@cd = @@mod.definitions.find{|d|d.name=~/#{@@next_name}?/}
                    	unless @@cd
                    		cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{@@next_name}.skp")
                    	@@avant = @@next
                    else
                    • sdmitchS
                      sdmitch
                      Thanks in advance for your help.[/size]
                      Could you post or PM me a sample model,version<=2016, that I could test.
                      • TNTDAVIDT
                        TNTDAVID
                        **It does not work yet. 😲
                        For the code that makes it unique all of it is found. 😉
                        Here is the example of the updated cube:
                        TESTE 2.skp
                        TNT_Teste.rbz
                        **1.**Open the SKP file Teste 2.
                        2. Install the extension.
                        **3.**Click on the color icon. (All cubes will change texture.)
                        **4.**Click the cube icon. (This will reload the subcomponents.)
                        5. Select the middle cube and click on the padlock.
                        6. Click the cube icon again, you will see that the sub-components of the middle cube will no longer change.
                        7. Click on the color icon, the texture of the middle cube no longer changes. (Unfortunately this is not yet the case and I need your help to write this method.)
                        Thank you
                        David**
                        • sdmitchS
                          sdmitch
                          1. I'm not sure why this works at all since we changed to pattern matching of the name to over come the problem with names containing '#'!
                          2. This is never going to work because there is only a single 'color' involved and making a component unique has no effect on the material applied.
                          I'll keep thinking about it but I'm not optimistic about finding a solution.
                          • sdmitchS
                            sdmitch
                            I have PM'd you a possible solution to #7
                            • 2 / 2
