    Replace Several Textures?
    32 Posts 3 Posters 6.3k Views 3 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      The textures should not be in the folder, "C:\Users\Dada\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\TNT_ClickCuisine2\Materials" ? 😲
      If not, in what folder should the images be?
      Thank you
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • sdmitchS Offline
        sdmitch
        That would be correct if the plugin is in "C:\Users\Dada\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
        http://sdmitch.blogspot.com/
        • TNTDAVIDT Offline
          TNTDAVID
          The plugin is in the right place!
          I think the problem has to be tied to something else.
          Can you share your "rbz" file?
          Your soluition is great and very interesting.
          Thank you
          David
          • sdmitchS Offline
            sdmitch
            Thank you
            David
            Hope this helps.
            mats.rbz
            • TNTDAVIDT Offline
              TNTDAVID
              Thank you very much! 😄
              Moving from one material to another with Click-Kitchen 2, will be much faster and easier with your code. 😉
              I would make a small demo as soon as the code is applied to the plugin.
              Ps: My error was indeed the path to the materials file.
              File.join (File.dirname (__ FILE __). Gsub ('\\', '/'), "TNT_ClickCuisine2 / Materials /"
              Corrected like this:
              File.join (File.dirname (__ FILE __). Gsub ('\\', '/'), "Materials /"
                NEVER include a <space> between a method and its parenthesized arguments !
                AND you show some weird Capitalization and added spaces !
                So it IS NOT:
                BUT:
                File.join( File.dirname(__FILE__).gsub('\\', '/'), "Materials/" )
                In fact it'd be better as:
                File.join( File.dirname(__FILE__).tr("\\", "/"), "Materials" )
                Then the path can be joined to the files without the trailing '/' ??
                Suitable for all OSs.
                BUT the exactly correct way would be:
                File.expand_path( File.join(File.dirname(__FILE__), "Materials") )
                Which always uses / rather than \ ...
                • TNTDAVIDT Offline
                  TNTDAVID
                  **OK TIG 😉
                  How to do the same for components?
                  Example:
                  I have 3 boxes, "1-Box", "2-Box", "3-Box", they are in the folder "Plugins/ Click-Cuisine2/Components".
                  I want to create an icon that calls a method of this type:
                  1st Click
                  Selects all components with the definition "1-Box ##", and replaces with "2-Box", which is in the "Components" folder.
                  If no component with the definition " 1-Box" was found, send the message, "Import a Clik-Cuisine 2 furniture, to replace these components ".
                  2nd Click
                  Selects all components with the definition "2-Box ##", and replaces it with "3-Box".
                  3rd Click
                  Selects all components with the definition "3-Box ##", and replaces with "1-Box".
                  Final objective:
                  Click-Cuisine 2, will offer more than 20 IKEA handles that I want to interchange with one click.
                  This can be done in Dynamic Components, but it is not suitable for such a large number of 3D models.
                  If you can help me write this method, I would be very glad. ☀**
                  thank you
                  David
                    Clicks 1/2/3:
                    Find all component instances matching a certain name.
                    If none then messagebox, but if some are collected, then check if the particular replacement component definition exists and use that, otherwise load it from your SKP subfolder... swap the collected instances' definitions for the desired one...
                    Here is an outline - assuming your clicks are suitably trapped in a Tool, or are buttons on a webdialog etc...
                    Currently this is for filtered selected objects only:
                    path_to_SKP_folder = "????????"
                    # you must set this from knowing your File.dirname(__FILE__)
                    # which can be joined with the SKP subfolder's name etc
                    model = Sketchup.active_model
                    defns = model.definitions
                    ss = model.selection
                    name = "Box-1" # we'll match the start of the names only /^.../
                    instances = ss.grep(Sketchup;;ComponentInstance).find_all{|e| e.definition.name =~ /^#{name}/ }
                    unless instances[0]
                      UI.messagebox("#{name} NOT matched !")
                      return
                    else
                      rname = name.next # e.g. Box-2
                      unless defn = defns[rname]
                        defn = defns.load(File.join(path_to_SKP_folder, rname+".skp")) # you set up SKP path earlier !
                      instances.each{|e| e.definition = defn }
                    If you want to do it globally, then you need to grep model.entities and then all defns' entities in turn - filtering out .image? - to process only groups and component contexts...
                    • sdmitchS Offline
                      sdmitch
                      @tntdavid said:
                      **OK TIG 😉
                      Example:
                      1st Click
                      2nd Click
                      3rd Click
                      Final objective:
                      thank you
                      David
                      This seems to work for me.
                            @mod = Sketchup.active_model
                            @ent = @mod.active_entities
                            @last ||= '1'; @next = @last.next; @next='1' if @next=='4'
                            last_name = @last + '-Box'; next_name = @next + '-Box'
                            cmp_folder = File.join(File.dirname(__FILE__).gsub('\\','/'),"TNT_ClickCuisine2/Components/")
                            cis = @ent.grep(Sketchup;;ComponentInstance).find_all{|ci|ci.definition.name[0..4]==last_name}
                            unless cis.empty?
                              for ci in cis
                                cd = @mod.definitions[next_name]
                                unless cd
                                  cmp = cmp_folder+"#{next_name}.skp"
                                  cd = @mod.definitions.load cmp
                                ci.definition = cd
                              @last = @next
                            else
                              UI.messagebox "#{last_name} not found."
                      • TNTDAVIDT Offline
                        TNTDAVID
                        **Great! Your two examples work perfectly. ☀
                        TIG with the method, I must manually select "Box-1", so that "Box-2", replaces it.
                        How to automatically select all the "Box-1" components, even those that are nested in a piece of furniture?
                        And How to switch from "Box-2" to "Box-3"?
                        Sdmitch your code is very surprising! 👍
                        All "1-Box", "2-Box" and "3-Box" components are selected and replaced automatically.
                        This works for all components at the first level of the structures list.
                        For "Boxes" that are inside a group or components, this does not work anymore.
                        How to solve the problem ?
                        Sorry, I forgot to specify this detail. 💚
                        The objectives are more and more precise:
                        1 - The user clicks on the icon "Change the Handles", to replace all the handles present in all the furniture. ( We are almost there. )
                        2 - If the user no longer wishes to modify some handles, he must select the furniture that he no longer wishes to modify then click on the icon "Freezing the Handles".
                        ( This action must rename the definition of all the handles present inside the selected furniture. )
                        Rename Definitions = Prevent the first code from acting on the handles.
                        How do you write this method?
                        Great thanks to both of you for your help.
                        See you.
                        David**
                          instances = model.entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                          model.definitions.each{|d|
                            next if d.image?
                            next unless d.name =~ /^#{name}/
                            d.instances.each{|e| instances << e }
                          Now you have an array 'instances' that match that name pattern.
                          To process different names have your method take an argument - e.g.
                          def swapper(name=nil)
                            return unless name
                            ### 'name' is set when calling the method
                            ### main code here
                          You then run the method as swapper("Box-1") or swapper("Box-2") etc...
                          Provided that you always swap by incrementing the name it works as the name.next turns "Box-1" into "Box-2" for the replacement etc...
                          To process just a selected instance's definition you use a context-menu that tests for ss.length==1 && ss[0].is_a?(Sketchup::ComponentInstance) ...
                          Then it runs some 'freezer' method code...
                          name = "some_name_???" ### how is this to be set ?
                          defn = ss[0].definition ### selected instance
                          instances = defn.entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                          ds = []
                          instances.each{|e| ds << e.definition }
                          ds.uniq! ### all matching definitions
                          ds.each{|d| d.name = 'x' + d.name }
                          ### or however you will rename each definition...
                          • sdmitchS Offline
                            sdmitch
                            @tntdavid said:
                            **> How to automatically select all the "Box-1" components, even those that are nested in a piece of furniture?
                            David
                            Following up on TIG's idea of collecting instances, I think this solves the problem of the embedded components.
                                  @last ||= '1'; @next = @last.next; @next = '1' if @next == '4'
                                  last_name = "#{@last}-Box"; next_name = "#{@next}-Box"
                                  if @mod.definitions[last_name] && @mod.definitions[last_name].instances[0]
                                    unless cd
                                     cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{next_name}.skp")
                                    @mod.definitions.find{|d|d.name==last_name}.instances.each{|ci|ci.definition=cd}
                                    @last = @next
                                  else
                            • TNTDAVIDT Offline
                              TNTDAVID
                              **I'm sorry to take so much time to answer you but I'm overworked.
                              First tests on the cubes, all seems to work wonderfully.
                              I will test your codes directly on Click-Cuisine 2 and post here an example of the revolutions that it will bring to my tool.
                              I do not know how to thank you because your help allows me to move forward as never before.
                              See you soon.**
                              David
                              • TNTDAVIDT Offline
                                TNTDAVID
                                **Hello, ☀
                                After some tests of your codes on Click-Cuisine 2, I noticed a small problem that I hope to solve with your help.
                                The change of component changes perfectly from 1 to 2 then to 3, except if one goes backwards.
                                Here is an example in image:
                                http://i.imgur.com/J316OLS.gif
                                Same problem, if I close and I open the file because the script restarts to "1-Component".
                                How to work around the problem?
                                I think it is best to delete the error message, even though "1-Component" is not found.
                                You can download skp example below:
                                TESTE.skp
                                And below the rbz plugin:
                                TNT_Teste.rbz
                                Thank you in advance for your help.
                                David**
                                  Without even looking at the code consider this...
                                  The 'file's suffix is to change thus:
                                  1 >>> 2
                                  2 >>> 3
                                  3 >>> 1
                                  So you don't use 'next' to increment the suffix just a 'case'...
                                  In 'pseudo' code...
                                  case suffix when '1'; suffix = '2' when '2'; suffix = '3' when '3'; suffix = '1' end#case
                                  Attach the suffix the the files' base names as you look through...
                                  If you want to remember the last used 'suffix' then use @suffix in a module or @@suffix in a class.
                                  Then the next time the tool is used the last used enduring variable is recalled...
                                  OR if you are getting the current value from a DC each tim then you can skip the enduring variable route ?
                                  • TNTDAVIDT Offline
                                    TNTDAVID
                                    **Sorry TIG to come back so late, but this time I finally have time to devote myself fully to ruby. ☀
                                    I would have to put "@@" into all the variables, but that is certainly not the solution you advise me. 💚
                                    Here is the basic code written by Sdmitch, which is almost perfect:
                                    def handles
                                          @last3 ||= '1'
                                          @next = @last3.next
                                          @next = '1' if @next == '19'
                                          last3_name = "#{@last3}-HANDLE"
                                    	  next_name = "#{@next}-HANDLE"
                                          if @mod.definitions[last3_name] && @mod.definitions[last3_name].instances[0]
                                          unless cd
                                          @mod.definitions.find{|d|d.name==last3_name}.instances.each{|ci|ci.definition=cd}
                                          @last3 = @next
                                          else
                                          UI.messagebox "#{last3_name} not found."
                                    Before exploring your idea TIG:
                                    Can your solution manage multiple SKP files or the status of the handles are different for each file?
                                    For example :
                                    My Project 1 has been saved with the definition in "9-HANDLE".
                                    If I open this file the code must look for the definition "9-HANDLE", to replace it with "10-HANDLE".
                                    My Project 2 is saved in "4-HANDLE".
                                    If I open this file the code should look for the definition "4-HANDLE", to replace it with "5-HANDLE".
                                    Another example:
                                    If I go back with Sketchup, the code that is "4-HANDLE" will return to the "3-HANDLE" state.
                                    If your idea fulfills all these conditions can you write an example?
                                    Another idea would be to replace all the definitions that are called "Handle" in their definitions.
                                    For example:
                                    "1-Handle", "2-Handle" or "3-Handle" etc ...
                                    Are replaced because they contain the name "Handle" in their definitions.
                                    Is this easier to apply?
                                    If so, how will you change the code?
                                    David**
                                    • TNTDAVIDT Offline
                                      TNTDAVID
                                      **Hello,
                                      To replace several definitions with the "next name" definition, I tried this:
                                      def handles
                                            @last3 ||= '1'
                                            @next = @last3.next
                                            last3_name = ['1-HANDLE','2-HANDLE','3-HANDLE']
                                            unless cd
                                            {next_name}.skp")
                                            @last3 = @next
                                            else
                                      But the code does not work for a list of definitions between these brackets "[]".
                                      How to replace a list of definitions with the definition "next name" ?
                                      Any help would be of great help to me.
                                      Cordially
                                      David**
                                      • TNTDAVIDT Offline
                                        TNTDAVID
                                        **There is news ☀
                                        As my code is in a class, I tried to apply the advises of TIG, put in "@@".
                                        Now "@@ next" continues to evolve from 1 to 19, even if the definition that needs to be replaced is not found.
                                        Even if the situation is better than before, it is not perfect because the code restarts to
                                        "1-Handle" every time SketchUp runs.
                                        If the handles on the stage are defined "5-Handle", you have to click 4 times on the icon to change the handle.
                                        Thank you in advance for your help.**
                                        def Handle
                                            @@mod = Sketchup.active_model
                                            @@ent = @@mod.active_entities
                                            @@avant ||= '1'
                                            @@next = @@avant.next
                                            @@next = '1' if @@next == '19'
                                            @@last1 = "#{@@avant}-HANDLE"
                                            @@next_name = "#{@@next}-HANDLE"
                                         if @@mod.definitions[@@last1]
                                            @@cd = @@mod.definitions[@@next_name]
                                            unless @@cd
                                            {@@next_name}.skp")
                                            @@cd = @@mod.definitions.load cmp
                                            @@mod.definitions.find{|d|d.name==@@last1}.instances.each{|ci|ci.definition=@@cd}
                                            @@avant = @@next
                                         else
                                            UI.messagebox "#{@@last1} not found."
                                        • sdmitchS Offline
                                          sdmitch
                                          I would suggest using attributes to keep tract of "next".
                                          @@avant = Sketchup.active_model.get_attribute("Handles","Last","1")
                                          Sketchup.active_model.set_attribute("Handles","Last",@@next)
                                          • TNTDAVIDT Offline
                                            TNTDAVID
                                            **Great Thanks sdmitch.
                                            The general change of all the Handles furniture is finally perfect. 😉
                                            I will do the same for all the components of a kitchen, sink, taps, oven etc ...
                                            Thanks to your help, "Click-Cuisine 2" will be even easier than ever.
                                            A small remark without great consequence:
                                            The current code does not replace the unique handles, such as "1-HANDLE # 1".
                                            Is it possible to circumvent the problem, if so how?
                                            The 2nd Great Steps is to replace the Handles of a single piece of furniture selected, without affecting other furniture.
                                            How would you do that?
                                            Any help from you is very good news to me. 😄
                                            Thank you
                                            David**
