    Replace Several Textures?
    32 Posts 3 Posters 9.5k Views 3 Watching
      If you want to do it globally, then you need to grep model.entities and then all defns' entities in turn - filtering out .image? - to process only groups and component contexts...
      instances = model.entities.grep(Sketchup;;ComponentInstance).find_all{|e|
        e.definition.name =~ /^#{name}/
      model.definitions.each{|d|
        next if d.image?
        next unless d.name =~ /^#{name}/
        d.instances.each{|e| instances << e }
      Now you have an array 'instances' that match that name pattern.
      To process different names have your method take an argument - e.g.
      def swapper(name=nil)
        return unless name
        ### 'name' is set when calling the method
        ### main code here
      You then run the method as swapper("Box-1") or swapper("Box-2") etc...
      Provided that you always swap by incrementing the name it works as the name.next turns "Box-1" into "Box-2" for the replacement etc...
      To process just a selected instance's definition you use a context-menu that tests for ss.length==1 && ss[0].is_a?(Sketchup::ComponentInstance) ...
      Then it runs some 'freezer' method code...
      name = "some_name_???" ### how is this to be set ?
      defn = ss[0].definition ### selected instance
      instances = defn.entities.grep(Sketchup;;ComponentInstance).find_all{|e|
      ds = []
      instances.each{|e| ds << e.definition }
      ds.uniq! ### all matching definitions
      ds.each{|d| d.name = 'x' + d.name }
      ### or however you will rename each definition...
      • sdmitchS
        sdmitch
        @tntdavid said:
        **> How to automatically select all the "Box-1" components, even those that are nested in a piece of furniture?
        David
        Following up on TIG's idea of collecting instances, I think this solves the problem of the embedded components.
              @mod = Sketchup.active_model
              @ent = @mod.active_entities
              @last ||= '1'; @next = @last.next; @next = '1' if @next == '4'
              last_name = "#{@last}-Box"; next_name = "#{@next}-Box"
              if @mod.definitions[last_name] && @mod.definitions[last_name].instances[0]
                cd = @mod.definitions[next_name]
                unless cd
                 cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{next_name}.skp")
                 cd = @mod.definitions.load cmp
                @mod.definitions.find{|d|d.name==last_name}.instances.each{|ci|ci.definition=cd}
                @last = @next
              else
                UI.messagebox "#{last_name} not found."
        http://sdmitch.blogspot.com/
        • TNTDAVIDT
          TNTDAVID
          **I'm sorry to take so much time to answer you but I'm overworked.
          First tests on the cubes, all seems to work wonderfully.
          I will test your codes directly on Click-Cuisine 2 and post here an example of the revolutions that it will bring to my tool.
          I do not know how to thank you because your help allows me to move forward as never before.
          See you soon.**
          David
          [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
          • TNTDAVIDT
            TNTDAVID
            **Hello, ☀
            After some tests of your codes on Click-Cuisine 2, I noticed a small problem that I hope to solve with your help.
            The change of component changes perfectly from 1 to 2 then to 3, except if one goes backwards.
            Here is an example in image:
            http://i.imgur.com/J316OLS.gif
            Same problem, if I close and I open the file because the script restarts to "1-Component".
            How to work around the problem?
            I think it is best to delete the error message, even though "1-Component" is not found.
            You can download skp example below:
            TESTE.skp
            And below the rbz plugin:
            TNT_Teste.rbz
            Thank you in advance for your help.
            David**
              Without even looking at the code consider this...
              The 'file's suffix is to change thus:
              1 >>> 2
              2 >>> 3
              3 >>> 1
              So you don't use 'next' to increment the suffix just a 'case'...
              In 'pseudo' code...
              case suffix when '1'; suffix = '2' when '2'; suffix = '3' when '3'; suffix = '1' end#case
              Attach the suffix the the files' base names as you look through...
              If you want to remember the last used 'suffix' then use @suffix in a module or @@suffix in a class.
              Then the next time the tool is used the last used enduring variable is recalled...
              OR if you are getting the current value from a DC each tim then you can skip the enduring variable route ?
              • TNTDAVIDT
                TNTDAVID
                **Sorry TIG to come back so late, but this time I finally have time to devote myself fully to ruby. ☀
                I would have to put "@@" into all the variables, but that is certainly not the solution you advise me. 💚
                Here is the basic code written by Sdmitch, which is almost perfect:
                def handles
                      @last3 ||= '1'
                      @next = @last3.next
                      @next = '1' if @next == '19'
                      last3_name = "#{@last3}-HANDLE"
                	  next_name = "#{@next}-HANDLE"
                      if @mod.definitions[last3_name] && @mod.definitions[last3_name].instances[0]
                      unless cd
                      @mod.definitions.find{|d|d.name==last3_name}.instances.each{|ci|ci.definition=cd}
                      @last3 = @next
                      else
                      UI.messagebox "#{last3_name} not found."
                Before exploring your idea TIG:
                Can your solution manage multiple SKP files or the status of the handles are different for each file?
                For example :
                My Project 1 has been saved with the definition in "9-HANDLE".
                If I open this file the code must look for the definition "9-HANDLE", to replace it with "10-HANDLE".
                My Project 2 is saved in "4-HANDLE".
                If I open this file the code should look for the definition "4-HANDLE", to replace it with "5-HANDLE".
                Another example:
                If I go back with Sketchup, the code that is "4-HANDLE" will return to the "3-HANDLE" state.
                If your idea fulfills all these conditions can you write an example?
                Another idea would be to replace all the definitions that are called "Handle" in their definitions.
                For example:
                "1-Handle", "2-Handle" or "3-Handle" etc ...
                Are replaced because they contain the name "Handle" in their definitions.
                Is this easier to apply?
                If so, how will you change the code?
                David**
                • TNTDAVIDT
                  TNTDAVID
                  **Hello,
                  To replace several definitions with the "next name" definition, I tried this:
                  def handles
                        @last3 ||= '1'
                        @next = @last3.next
                        last3_name = ['1-HANDLE','2-HANDLE','3-HANDLE']
                        unless cd
                        {next_name}.skp")
                        @last3 = @next
                        else
                  But the code does not work for a list of definitions between these brackets "[]".
                  How to replace a list of definitions with the definition "next name" ?
                  Any help would be of great help to me.
                  Cordially
                  David**
                  • TNTDAVIDT
                    TNTDAVID
                    **There is news ☀
                    As my code is in a class, I tried to apply the advises of TIG, put in "@@".
                    Now "@@ next" continues to evolve from 1 to 19, even if the definition that needs to be replaced is not found.
                    Even if the situation is better than before, it is not perfect because the code restarts to
                    "1-Handle" every time SketchUp runs.
                    If the handles on the stage are defined "5-Handle", you have to click 4 times on the icon to change the handle.
                    Thank you in advance for your help.**
                    def Handle
                        @@mod = Sketchup.active_model
                        @@ent = @@mod.active_entities
                        @@avant ||= '1'
                        @@next = @@avant.next
                        @@next = '1' if @@next == '19'
                        @@last1 = "#{@@avant}-HANDLE"
                        @@next_name = "#{@@next}-HANDLE"
                     if @@mod.definitions[@@last1]
                        @@cd = @@mod.definitions[@@next_name]
                        unless @@cd
                        {@@next_name}.skp")
                        @@cd = @@mod.definitions.load cmp
                        @@mod.definitions.find{|d|d.name==@@last1}.instances.each{|ci|ci.definition=@@cd}
                        @@avant = @@next
                     else
                        UI.messagebox "#{@@last1} not found."
                    • sdmitchS
                      sdmitch
                      I would suggest using attributes to keep tract of "next".
                      @@avant = Sketchup.active_model.get_attribute("Handles","Last","1")
                      Sketchup.active_model.set_attribute("Handles","Last",@@next)
                      • TNTDAVIDT
                        TNTDAVID
                        **Great Thanks sdmitch.
                        The general change of all the Handles furniture is finally perfect. 😉
                        I will do the same for all the components of a kitchen, sink, taps, oven etc ...
                        Thanks to your help, "Click-Cuisine 2" will be even easier than ever.
                        A small remark without great consequence:
                        The current code does not replace the unique handles, such as "1-HANDLE # 1".
                        Is it possible to circumvent the problem, if so how?
                        The 2nd Great Steps is to replace the Handles of a single piece of furniture selected, without affecting other furniture.
                        How would you do that?
                        Any help from you is very good news to me. 😄
                        Thank you
                        David**
                        • sdmitchS
                          sdmitch
                          @@mod.definitions.find{|cd|cd.name=~/#{@@last1}?/i}.instances.each{|ci|ci.definition=@@cd}
                          This would be difficult indeed. The easiest way would be to move the single piece to a new model, make the changes then import it back.
                          David
                          • TNTDAVIDT
                            TNTDAVID
                            **Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
                            Maybe I made a mistake somewhere?
                            def poignee
                                @@last1 = "#{@@avant}-POIGNEE"
                                @@next_name = "#{@@next}-POIGNEE"
                                unless @@cd
                                {@@next_name}.skp")
                                @@avant = @@next
                                else
                            Perhaps it is more interesting not to reload the rendered unique models to find a solution to my 2nd Objective?
                            Here is a simpler idea for the 2nd Objective:
                            1 - I select a piece of furniture.
                            2 - I Click on the icon "Freeze the model". (The method that is executed makes all unique components and subcomponents of my selection.)
                            3 - I can execute the first code without changing the handles of the furniture made unique.
                            How to write this method?
                            Thanks in advance for your help.**
                            • sdmitchS
                              sdmitch
                              @tntdavid said:
                              [size=110]Thanks for your Sdmitch solution, but the definitions rendered unique "1-HANDLE # 1" still do not change.
                              def poignee
                              >     unless @@cd
                              >     {@@next_name}.skp")
                              >     end
                              >     @@avant = @@next
                              >     else
                              >   end
                              > end
                              I think you need to use the same @@mod.definitions.find when checking for existence also.
                              if @@mod.definitions.find{|d|d.name=~/#{@@last1}?/}
                              	@@cd = @@mod.definitions.find{|d|d.name=~/#{@@next_name}?/}
                              	unless @@cd
                              		cmp = File.join(Sketchup.find_support_file('plugins'),"TNT_ClickCuisine2/Components/#{@@next_name}.skp")
                              	@@avant = @@next
                              else
                              • sdmitchS
                                sdmitch
                                Thanks in advance for your help.[/size]
                                Could you post or PM me a sample model,version<=2016, that I could test.
                                • TNTDAVIDT
                                  TNTDAVID
                                  **It does not work yet. 😲
                                  For the code that makes it unique all of it is found. 😉
                                  Here is the example of the updated cube:
                                  TESTE 2.skp
                                  TNT_Teste.rbz
                                  **1.**Open the SKP file Teste 2.
                                  2. Install the extension.
                                  **3.**Click on the color icon. (All cubes will change texture.)
                                  **4.**Click the cube icon. (This will reload the subcomponents.)
                                  5. Select the middle cube and click on the padlock.
                                  6. Click the cube icon again, you will see that the sub-components of the middle cube will no longer change.
                                  7. Click on the color icon, the texture of the middle cube no longer changes. (Unfortunately this is not yet the case and I need your help to write this method.)
                                  Thank you
                                  David**
                                  • sdmitchS
                                    sdmitch
                                    1. I'm not sure why this works at all since we changed to pattern matching of the name to over come the problem with names containing '#'!
                                    2. This is never going to work because there is only a single 'color' involved and making a component unique has no effect on the material applied.
                                    I'll keep thinking about it but I'm not optimistic about finding a solution.
                                    • sdmitchS
                                      sdmitch
                                      I have PM'd you a possible solution to #7
                                      • 2 / 2
