    Ornamental bush
    17 Posts 7 Posters 10.8k Views 7 Watching
    • filibisF
      filibis
      @pilou said:
      Only limitation (in free) is size 1920 *1080
      I think monitor must be big enough to render that resolution. Because only option is to render 'real time' and 'capture' the viewport in order to save.
      So here is what i get maximum. (My monitor max resolution is 1600x1200)
      • jujuJ
        juju
        Indigo 4.0.50 (OpenCL)
        Thea for SU 1.5.09.540.1462 (IR-Presto MC)
          I believe that is a difference between "Real Time " render and render an Internal image resolution ?
          Sorry I can't test I have not the Light version πŸ˜•
          So maybe you right...I will ask that πŸ˜„
            Answer to the question! πŸ˜‰
            The solution !
            Yes you can.
            But you must make a simple trick.
            From Preferences -> appearance
            You need to change fixed view size to 1920 * 1080
            Change the view to fixed view
            Start real time rendering
            Then you can save the image, the size of the saved image will be Full HD
            Have fun rendering with free SimLab Composer Light! β˜€
            • filibisF
              filibis
              That solution works, thanks for sharing pilou!
              • HornOxxH
                HornOxx
                A Testing with Shaderlight
                First: Majid, thanks a lot for making and sharing this high quality plant πŸ‘ πŸ˜„ ❗
                I did a fast testing, using Shaderlight render. Instead of placing the bush natively in the model, I first made a simple proxy-frame, which I than replaced within the renderer with your original model.
                and as you see - it runs and looks great ! πŸ˜„
                never trust a skinny cook
                • majidM
                  majid
                  Thanks HornOxx sharing your experience. I think your trick will work with other render engines too am I right?
                  Also if there is a complain about the model it would be the too vivid green color. so one may redefine and tune it before using!
                  • pbacotP
                    Hi Majid, How are you doing? Nice to see you posting again. Thanks for sharing! I don't have time right now to work on rendering, but will check it out. I did run a short time with Visualizer and it looked fine, though I didn't have time to finish the full (6) hours it wanted to do it well.
                    • tuna1957T
                      tuna1957
                      Thanks very much Majid. I'll try and give it a run in Twilight this week.
                      • majidM
                        majid
                        Thanks a bundle dear friend. I am doing well and getting older , right few days ago I pursued my life journey to the 41th year....at the same time I am tooo busy to do visualization jobs with the low pay and economical issues.
                        Here is the last 3year project that I have been included ,mainly in modeling and viz.
                        • pbacotP
                          Majid, That's a great one. Very solid realistic feel to it. I hope they appreciated it!
                          • majidM
                            majid
                            Thanks mate! during the design process we tried to achieve the quality of natural light via facade and the volume inward moves and combine it with unified office space demand and natural ventilation....
                            I hope be lucky to see it built!
